[Review] Convoy M21C ( XHP70.2, 1 x 21700) - Excellent performance and regulation # Outdoor beamshots included
Why isnt there any level between 35 and 100? For example 70, when you want high output, but not all out turbo…
Wait a minute. Are you saying that this driver has an OUTPUT current of nearly 9A at 6-7V from a single cell? How did you complete your test with the power supply? How and where did you measure current? Were you driving an XHP70.2 on the output?
@JaredM
I have TnC 26650 UltraLux with MantaRay boost driver which measured with Fluke175 at the tail gives 10A. 6V XHP70 is the lased...
I’m under the assumption that this must be input current. The “regulation” on turbo is what I believe to be the driver capping the input current, so that it doesn’t burn up. The output amperage likely falls with voltage proportionally. It can be seen that medium mode has increasing current with decreasing voltage and maintains constant wattage (~5.5W) between 3.2-4.2V. This is proper regulation as far as I can tell. Output current is likely around 6A max.
Please correct me if you did in fact measure the output current. I would prefer to be wrong here because this means I found a driver I’ve been looking for.
SMO and XHP70.2 like seriously. This light needs a op reflector.
BTW the much smaller and lighter Thrunite TC20 stabilizes at 1800lm. I know those two brands are incomparable but nevertheless.
Can you measure the diameter of the driver?
I think it has something to do with the fact that the way we perceive light isn’t linear but logarithmic.
So having a level between 50% and 100% would hardly make any difference.
Keep in mind I could be totally wrong :slight_smile:
Please Simon, give us an OP reflector for this light!
Have you taken the driver out yet?
Are you going to?
I'd like to see photos of it outside the light.
The one photo of it inside the head doesn't reveal much.
What's on the top side?
I don't see it on the AE Convoy Store
@bilakos, could you clarify if you measured current into or out of the driver, please?
Hello Jared and sorry for the late reply!
Yes, I can confirm that I measured just the input current and not the output.
As you’ve mentioned in your previous replies, the driver seems to be capping the max current on turbo in order to not fry itself.
Do you have a size comparison?
This seems like a nice all around light from convoy.
8.87A from a mostly charged battery means about 33W input. Assuming 90% driver efficiency that is 30W to the LED. Looking at the xhp70.2 test (from Texas ace) it looks like maybe it’s sending about 5A to the LED at 6.16V.
For those saying they want an OP reflector, the xhp70.2 beam really looks fine from a smooth reflector so I don’t think that’s a big deal.
No apologies needed! Thank you! :slight_smile:
Is the driver a secret that you cannot post photos of other than the one of it inside the head.
The driver is the heart of the light so info about it is important for full review.
We like pictures!
FWIW the TC20 is much less throwy based on the beamshots here and the size of the reflector.
I second that.
This light has me interested. It’s about time we had more lights using decent switching drivers from good-quality manufacturers like Convoy.
It would be nice to see more photos of the driver, though I’m going to guess from the specs and testing that it’s using the tried and tested TPS61088 .
Would also like to see an OP reflector version. I’m usually an e-switch guy, might drill one of these for a side switch…
ok ,i will produce OP reflectors
How does this compare to an L6?
