So a bit below 12 hours to go for me, and a bit below 11 for Serlite.
My next link:
Wed, 03/04/2020 - ≈16:15
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
“The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom.” - Isaac Asimov
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
This time I also tapped on polarweis', his round should now be well set.
No links for me now, still to realize what to use for the coupons I have. Will still chip in from time to time.
How many orders did you guys make with these coupons so far?
I’m at 13! But that’s because the majority of my coupons have been pretty small ($1-$2); cumulatively, I’ve spent relatively little.
I think I’ll be done soon too – just a few more orders and my cart will be clear.
You know that feeling when you got your cart empty and few days later its again +25 items in it that you are just keeping your eye on or atleast thats what you say to yourself?
Haha, I sure do! I feel like more than a couple of my flashlights can be directly attributed to that habit…
Hello! My round is still going, with ≈4:15 hours to elapse. Single free slot, you can tap here. Thanks.
Fri, 03/06/2020 - 01:12; Fri, 03/06/2020 - 01:47
Used your #175 link, Serlite. And $#@%€, cos I just can't get what the @#$% is going on with the autoclicker software thing. The previous time I changed the tap rate to a tiny bit less than 9 taps per second and it nearly maxed out the bar, but this time it was like getting stuck for some reason, and even if it reached like a half bar by the end the final score was €0.28. Had to yell. Maybe these bastards have implemented some code to prevent autoclicker software from working properly unless you reconfigure cadence ratio each time. It probably is best to tap by hand then. God knows…
Interestingly, when I tried to claim my last coupon, it said I couldn’t because there was “insufficient balance to redeem”. Wonder if that was a one-off, or if means the promo is winding down?
Anyway, not going to share a link this round since I’m actually running out of things to buy! But I’ll still help out people when I can with a $0.98 contribution.
Mmm, tapped on gchart's game link, he should now be in good shape.
My next link:
Viruses DON'T cause diseases! They are better called exosomes, and they are cell cleaners! Watch Virus Theory vs Exosome Theory video and awaken to this truth! Check this article by MD Andrew Kaufman. Read the book “Béchamp or Pasteur” by Ethel Hume for in-depth information.
Barkuti, used you link.
New for me:
https://a.aliexpress.com/_dVPouyR
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
I hit your link, XXX.
Here’s my new one:
(Link removed)
I pressed yours gchart.
https://a.aliexpress.com/_BOxmyt
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
Clicked yours, polarweis!
Here’s my new link: [Link expired, thanks!]
I hit your link, Serlite.
Here’s my new link:
(Link removed)
I got your link gchart. Here’s mine:
https://a.aliexpress.com/_dTFIYeT
And clicks.
EDIT: Full
Just tapped over MoreLumens' link.
My new one is gone down. Thanks.
Thu, 03/05/2020 - 18:07
Clicked yours, Barkuti!
My new link: https://a.aliexpress.com/_dXAl1Ar
Edit: 1 slot left!
Clicked yours, Serlite!
Keeping the train going:
(Link removed)
side note… the “share” text now calls it “Money Gun” instead of “Coupon Pals”?!
Only like 7. Maybe 2 more and then I’m done.
Clicked.
https://a.aliexpress.com/_dTc8ECR
Thanks all! Full again and 3.47 € off from 4.36 € order. I can click someone in under 2.5 hours.
clicked yours serlite. Not sure if you were full allready but its only 87 cents.
Thanks people.
https://a.aliexpress.com/_B0PvSv
Barkuti, clicked your link. I hope this time it works.
New for me:
https://a.aliexpress.com/_dTz3aWb
2 places left
My reviews:
Two slots left, thanks
https://a.aliexpress.com/_dVtlXK3
I used your link XXX-Man, since it looks like you needed a click!
Here’s my new link: https://a.aliexpress.com/_dUI03qb
Clicked!
Edit: deleted my link
Filled a slot.
I hit your link, MoreLumens.
Here’s my new link:
(Link removed)
I tapped yours, gchart!
gchart
Clicked your link.
My new
https://a.aliexpress.com/_dSWcLov
My reviews:
