The Vapcell store is original. The cell is a new one, not yet tested. If it’s really 1000 mAh 10A – WOW, a real upgrade over what we’ve seen so far.
I agree that it’s dishonest to show a test of a different cell.
Dennis updated the OP with this 10A 14500 cell, great development! , it goes with a different chart which is probably correct. So have a look at the first post. Also a very interesting: a 2200 mAh 18500 cell that does 4A.
...and as "proof" in description at aliexpress used this graph of completely different batteries (Vapcell ICR14500 1000mAh (Gold) 2018) rated by HKJ:
Agro wrote:
… If it's really 1000 mAh 10A - WOW, a real upgrade over what we've seen so far. I agree that it's dishonest to show a test of a different cell.
First of all, chances of it not meeting its capacity rating are very high if not guaranteed. And we'll see what happens with the maximum continuous discharge rating, it is doable but if also a little bit exaggerated the 10 A curve will look flat/deflated (low voltage). But well, wow.
Suffice to say I am quite fed up with marketing lies, particularly in the battery industry.
Edit. Forgot to say before, but djozz remembered me: it's not really dishonest to show a perfectly identified test of a different cell, it's just plain stupid.
Fri, 01/10/2020 - 16:35
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I’m not sure that Vapcell is deliberately lying about their batteries, sounds more like clumpsiness that they publish a wrong chart, that shows less performance actually than what the battery in question can do, not a very profitable lie
We'll see once it gets in the way of HKJ's or Mooch's steamroller.
Yup. My guess is they used the old listing for their ICR14500 cells as a template, and didn’t clean it up properly.
We’ll see once it gets in the way of HKJ’s or Mooch’s steamroller.
WOW this performance is incredible! If Mooch or HKJ confirms it, it is the new king of 14500. We should be able to expect 1,200 lumens from a GT Micro and still get good runtimes!
I do not have the cell in queue (I hope it is a yet) and my test station for these batteries are unreliable at the current time.
The problem is either the power supply (used for charging) or the relay (That connect the power supply), I am trying to find out which on and fix the problem, but it will take a couple of days.
Would these work in the GT Micro or is 10amps to much for it? I am using the gold 14500 vapcells and they seem much better then my Efest 700mah in my GT Micro.
Thanks ,H10 14500 10A have much power than gold 14500
… Thanks ,H10 14500 10A have much power than gold 14500
Correction: “H10 14500 10A has much more power than gold 14500”.
Can we say word or two about this in AliExpress Vapcell Store? Is it “real”?
Description: Vapcell original mini lithium 3.7V battery INR 14500 1000mah 10A rechargeable battery for flashlight / power tools
Url: https://www.aliexpress.com/item/4000594740211.html?spm=2114.12010612.814... (AliExpress Vapcell Store)
…and as “proof” in description at aliexpress used this graph of completely different batteries (Vapcell ICR14500 1000mAh (Gold) 2018) rated by HKJ:
link to djozz tests
I think Samsung 18500 can do 5A if i’m not mistaken
WTB Titanium 4sevens 2xAA tube
1000mAh and 10A is awesome if true !
- Yeah, but is it ultra high CRI?
Strangely, Vapcell has two listings for this cell on AE. One references this incorrect graph, and the other one doesn’t. Price is different as well.
https://www.aliexpress.com/item/4000595042850.html
link to djozz tests
Yup, let’s wait and see.
FWIW, I only have two of their cells (16340), and based on what my Lii-500 reports, their capacity is notably lower than what Vapcell claims.
So far Vapcell had a good feedback. Let’s see what HKJ and Mooch will say
Anybody knows which is the actual manufacturer of Vapcell 14500s? The Gold ones for example?
Do you mean the recently released 8 Ampere ones?
I’ve got 4 pcs coming my way, but i wondered why they had a price drop already (which made me decide to order them)
I didn’t know they released an 8A version. Mine are 7A:
http://budgetlightforum.com/comment/1506115#comment-1506115
Oh, you’re right, they are rated 7 Amperes.
Yes, it’s those cells.
Perhaps they’ll have a bit more capacity after a few cycles.
I just retested mine. Capacity is down by a few mAh, but more or less the same as new.
Sorry, that’s too careless
Thank you very much for your reminder
I contact sales customer service to change the picture
Search for the best li-ion battery
https://vapcell.aliexpress.com/store/1084158
https://www.vapcelltech.com
I just received 4 pcs of these, i just put them in my Lii-500 on NOR test.
I’ll report back.
Thx! ^^^
1st run on Lii-500 NOR test (4.2 – 2.8 Volts)
[1] 711 mAh
[2] 721 mAh
[3] 750 mAh
[4] 742 mAh
Doing second run now.
Okay, 2nd run finished.
I swapped the cells in the charger, so that [1] was now in slot 4, [2] in slot 3, [3] in 2 and [4] in 1.
[1] 732 mAh
[2] 747 mAh
[3] 737 mAh
[4] 734 mAh
So it seems there is some difference between the slots of the charger.
Average of 1st run: 731 mAh
Average of 2nd run: 737.5 mAh
It’s ridiculously late here, so i put them in for a 3rd run, i’ll see the results tomorrow.
I put some nickel plated neodymium magnets on the minuses to increase the force of the clamping of the slots.
I must sleep now.
See you tomorrow.
Oh, i forgot about this… ^
The last NOR run was a little better, but not a lot.
I wrote down the results, but i can’t find it anymore..
Anyway, AliExpress page of the new INR14500 shows the graph but it now says “HKJ test” above it.
Hmmm….
hm so not really close the stated 1000mah then? should be marked 800mah then imo.
...where Frugal meets with Flashlight!
つ ◕_◕ ༽つ
Mooch said he'll run some tests on 14500 10A
Doug S.
That is great
