✌ FREEME - ASTROLUX MF01S-UV & MF01mini-UV Flashlight Group Buy - ALIVE
Hmmmmmmmmmm, interested as I like to live on the edge…
Interested.
how is this light supposed to be useful to an average blfer here?
Interested, depending on the final details.
Interested.
interested…I guess
This light needs a remote control in my opinion.
Set the light in position,leave the room then turn it on.
That being said,I am interested.
Interested
https://giphy.com/embed/d2Zhwr7rW2PpeCOc
you don’t need safety glasses as UVC does not penetrate all the way to the retina, but anything like skin gets a terrible time being sterilized
good UVC LED like Klaran 50mW costs about 20$ in quantity naybe 10$, then 20$ for the quartz glass window, likely they use a plastic aluminum coated reflector
so looking just on LED and optics we hit 200$
If they go cheap with 3-5mW LEDs there is no purpose using 18 of them if 2 Klaran can do the same output
below 300nm you need quartz glass (fused silica) borosilicate will block UVC
Ask Schott how much B2O3 it contains, it has to be a glass that has almost none in it or it would block UV
such glass composition is called quartz not borosilicate
Borosilicate glass is 80-90% silica(SiO2), the main chemical component in quartz
Interested!
yes interested
Interested
Rocks!
UVA in the S2+ UVC makes a lot more things glow
Most of the time yes UVA will glow, I can think of 1 thing that im forgetting the name of that glows in UVA only
I am really interested in it.
I bought decent UVC LED BAR LIGHT for killing germ in mask.
it seems work well.(it reduces bad smell)
I would like to know how light sterilizers kill the germs hidden in cracks and crevices.
Seriously.
Seems like they are marginally OK for countertops.
Food, no, clothes, no, skin, no,
mouth/nose - double no, plus harmful
plus even if there are no cracks etc, how do you know you are exposing the right amount to kill the bad germies - on every square mm?
seems like clorox would work better
plus not blind or sun burn you.
wle
