on my unit the tint is pretty much cw with a slightly warmer corona
I’m a tint snob and very picky, but this is ok in my book (but only for throwers - I hate cw for all my other lights)
I like that it has two modes. On low, can it be used to shine at something 5 feet away? Or is the hot spot still so intense that it hurts the eye? Does the switch have momentary on?
It has a forward clicky, so yes, momentary is possible but this will also switch modes. I would have been okay with single mode - as for throwers this is basically all I need.
I would love to have the option of choosing between 1-mode and 2-mode by a series of rapid clicks (20+) or a similar method.
Low can be used 5ft in front of you, but the hotspot is very small and still kinda intense, thus I would rather pick my D4 for that task.
Could you get some more photos of night shots?
Would be helpful for hundreds of people wanting to get one.
Yep, anybody can post some more pics, my m1x is on its way, and so far not many beamshots out there…
The thrill of the wait and expectation…
Nice… Not to hot of a flashlight or hard to find any info on it I should say… Not a single Youtube vid… but I like my Jetbeams… Never had one fail! Had many Nitecores take a crap… Thanks for sharing!
Mine showed up today… I said WOW what a light package!! Then said I thought they put zip ties on these and what would you know an empty box.!!!
SO………. UPSET!!! Just emailed BANGGOOD about this… Tried to look up weight but it doesn’t show… Just says Lightweight…
Did anyone actually measure theirs?
Mine doesn't hit 800Kcd by far.
It does 'only' about half of that
Hi Chibim!
at which distacnce did you take your measurement?
i received a loaner this week
will try and measure the kcd asap
Hi,
I measured it this time at 10 meters.
Although it performs about the same as the Fenix TK30, I expected much higher numbers.
Mine did 413,000 cd instead of the claimed 800,000.
If I know other people's measurements I can decide whether mine is really faulty or not. Looking forward to your measurements. thanks
From a banggood review:
Measured at 5.5m
W30: 130 000 lux
M2S: 30 000 lux
GT Mini: 12 000 lux
The OP claims it outthrows his imalent R90C which is rated at 1679m but one bg reviews say it’s outperformed by even the T7L 1100m. What if the first few samples performed better for some reason? The rating does seem a lot higher than similarly sized LEP lights so it could just be overrated. LEPs I guess are hard to focus cause sometimes they perform much better than the rating . Some ppl measured 2.2
Yes, my M1X measured at 2.3Mcd, but the M2S is only doing just over 410Kcd, while it is supposed to do 800Kcd
Hopefully, there are more people sharing their insight as I'm very curious on how good/bad/normal 410kcd is.
I don't say 410 kcd is bad for this type of light, I just expected way better.
the weather was nice to me...
at each distance i took 3 values (15 sec) - the highest made it into the list below
started with full cells (vapcell 5000mAh) both down to 4.07V at the end
reading | cd@1m | throw | |
M2S @ 5m | 16890 | 422250 | 1300 |
M2S @ 10m | 4240 | 424000 | 1302 |
M2S @ 15m | 1779 | 400275 | 1265 |
M2S @ 20m | 1050 | 420000 | 1296 |
M2S @ 25m | 680 | 425000 | 1304 |
M2S @ 30m | 444 | 399600 | 1264 |
W3 Pro @ 5m | 14790 | 369750 | 1216 |
W3 Pro @ 10m | 3610 | 361000 | 1202 |
W3 Pro @ 15m | 1660 | 373500 | 1222 |
W3 Pro @ 20m | 889 | 355600 | 1193 |
W3 Pro @ 25m | 587 | 366875 | 1211 |
W3 Pro @ 30m | 382 | 343800 | 1173 |
left: jetbeam M2S / right: Weltool W3 Pro
uote=M4D M4X]
[/quote]
Thank you. So my measurement are comparable to yours. I wonder if both of us have a faulty one or if this normal. I hope more people can measure theirs and chime in to triple check.
Thanks again for testing.
:beer:
you are welcome!
Is Jetbeam spoofing the cd values?
I would like to know that as well ;)
anybody else can chime in on the M2S?
I could stop ordering. Thanks to you.
I was just checking the Chinese manual, and it looks like the manual says: 250,000 cd.. but the box says 800,000 cd. Something is misleading here.
For 250,000 I would have never bought it!
Fenix TK30 and acebeam W10 GenII have also near 400kcd
they all share quite the same LEP engine and lens size - i guess the marketing of JB was funny that day
