M4D M4X deals - Astrolux WP1 and WP2 LEP
I was stupid and bought one of the ones in the Other Flashlight category last night because I missed out this time. Who knows what the difference between the one in there and the C8+ section item is…
i got the base one with aluminium MCPCB
the driver is a 8x7125 l-m-h-strobe-sos :(
i get 450 Lumen and 139 kCd
Ahh, ok. So that means 2.8 amps. 139 kcd is 745 meters - not close to 1000 meters spec'd. Ouch on the UI! Agree :(
Something is quite wrong there... You are only gonna get so much out of the LED with 2.8 amps. For me that leaves only one option - driver replacement. Was wondering about that alum MCPCB option. Maybe the ones with copper MCPCB have higher powered drivers? I wouldn't risk 4-5 amps on an alum MCPCB, unless it's DTP.
1000 meters is 250 kcd. Dunno, may be do-able with 5 amps W1? Probably...
Funny, not sure you were around in the HD2010 and C8 days, maybe 2012-2013 or so. But the HD2010 was known for it's direct FET driver - a rarity to get high amps out of a stock light at the time. They used the same driver in other lights like C8's, UltraFires, and other brandless lights. The amps were only limited by the springs, LED wires, and battery resistance. So one day I used a hot cell in a C8 with that driver, but of course the LED was on a cheap alum MCPCB, and the LED de-soldered itself while running the flashlight! Thos cheap alum MCPCB's are a heat trap for sure!
He also has copper MCPCB
and i asked hin to get a better driver for next batch ;)
but for the privce a nice host to paly with (or still impressive muggle light!!!)
Will have to disassemble the other one and get a 5A convoy driver… I think I have a 20mm WF1 on copper MCPCB around somewhere. So realistically I’m just buying a host, blah.
C8+ w1 is sold out …. the price is very good at $23.99
I got the one from here:
But yeah nobody wants the Alu one lol
Order placed for the HL3A. Thanks Martin :+1:
All depends on the quality of the alum MCPCB. Charging $4 for a copper one is a bit high but I'd rather pay it then take chances with a pricey Good LED on a unknown aluminum one.
instant blue @ 5.4 A ;)
wut? I thought official limit is 4.5-5 amps, but to push it, up to 6 amps is being used. Instant blue? You mean if it's on a poor alum MCPCB?
what about this:
Now torture test. Torture for this emitter will be any cell in Samsung 30Q rang or better if used in FET DD setup which of course will pull a lot of current. So in mine test emitter survived over 7A of current draw for more than 3 minutes(for couple of times). After cool-down it did not loose initial properties(performance remained the same) which implies that emitter is very robust. This were mine results. I also found that mine test subject had best performance at around 5.8-6A (1200FC)
This was posted here in the OP: https://budgetlightforum.com/t/-/53735
What driver did you recommend they use? If sticking with 8x7135 at least offer it with the 12 group 55 mode driver from the xpl c8. The 4 mode 5a driver from the sst40 convoys would be sweet
Is the current driver the one where its lo-mid-hi and it blinks on low after 3 seconds?
How many amps is the current w2 model getting?
do you get what you ordered? bg is working normally?
neal and banggood send what is on stock
only some manufacturers (their suppliers) are delayed with new items)
Amazon.DE: Sofirn BLF SP36 nur €48.99
Servus mitnand!
Ich habe mal wieder einen Deal von Sofirn bekommen:
(Bitte den Affiliate-Link unten nutzen)
Die BLF SP36 hab ich inzwischen lieber als die Q8 ;)
Sofirn BLF SP36
Anduril, USB C, 5650 Lumen, 352m
4x Samsung LH351D (5000K 90CRI)
im Set mit 4 18650 Button top Batterie
mein Code: B4KVLQWV euer Preis: €48,99
Amazon.DE deal
40% off for
Sofirn C8F kit
(with charger and battery on Amazon DE)
Code : 7VY3UR3J
https://amzn.to/2IGbrtw
Hello my dear friends!
today (March 13 2020) Olight has another sale and offers
the LIMITED OD GREEN M2R PRO and the sale starts 00:01!!
better stay awake – i am sure those are sold out fast…
M2R Pro Warrior OD Green
unfortunately my regular discount codes do not work while a flash sale is active,
but you can use my links below anyway to “send” me your traffic at no costs!
that way i will get better discounts for you in the futrure ;)
click for: Olightstore.DE
on regular days: 15% OFF Code: M4DOL15
click for: Olightstore.COM
on regular days: 10% OFF CODE: M4XOlight10
find all my my Reflinks here
THANK YOU !
remember: NEVER pay full price on any flashlight!
Support my work and save money!
Use my deals on http://m4dm4x.com
you can become a Patron of my work!
https://www.patreon.com/M4DM4X
Martin…
I hesitated on the SP36 deal…
Any chance of a $50 code for a BLF SP36 XPL light?
Hi ” M4D M4X “.
I have used your codes to buy a HAIKELITE MT09R on 3 separate occasions with no luck. 2 times it was out of stock, and the last time it was in stock when I ordered it, it was shipped and was confiscated by customs and now Banggood says it is out of stock again. I requested a refund for the 3rd time. Are they not wanting to sell this one with your discount ?
I previously purchased 3 flashlights with your discounts with no problems. :open_mouth:
hmmmmmm
:slight_smile:
