[Prototype stage]17mm Buck driver (enhanced MTN MAX)
23 posts / 0 new
Lexel
Lexel's picture
Designed similar to the discontinued MTN MAX driver
completely went from scratch just taking the same Max16820 chip as starting point
Differences to the original MTN Max:
- a lot wider ground ring and part clearance from edge on top side so it fits better with smaller pill cavity
- 6mm spring pad to fit common BLF springs, where the MTN had 5mm
- many cases the 16819 is far better to get a relative low switching frequency (the 16820 is designed for 2Mhz the 16819 has with same values only 666kHz)
- 2 1206 Resistors so its relatively easy to modify the output current, while the original resistor was not stackable at all
- design with optional double amount of Input Caps,
- up to 2 3A fly back diodes depending on the output current (same type but lower forward voltage bin)
- QFN25 Attiny25/85 replaces the MLF10 Attiny 13A
- programming port for my Pogo pin flash key
- switch and indicator Pads for Anduril
- added a low pass filter to protect MCU from any voltage spikes
Using the formulas from the data sheet to optimize part values on 3 examples
It is an interest list to see how much parts I order from mouser beside from prototype ones
Edited by: Lexel on 06/14/2020 - 10:36
Lexel
Lexel's picture
Prices:
18.5€ driver (first 20 drivers then reduced to 16€ to cover development and stock up parts)
+0.8€ double diode and input caps
+3.25€ Coilcraft XEL6060 inductor (for high output currents)
+0.5€ BLF Copper alloy spring
Shipping:
Worldwide
2€ <10mm 50g envelope priority air mail shipping worldwide
+4€ for optional tracking + insurance up to 25€
Soldered long phosphor bronze springs are possible, but it adds about 2.5€ shipping costs (EU more than world because of tax)
+2€ insurance per full 100€ insurance
Germany
1.3€ <10mm 50g
2.4€ thick
add 2.8€ for signed tracking + insurance up to 25€
Lexel
Lexel's picture
reserved 2
Superstocker
Superstocker's picture
Last seen: 7 hours 10 min ago
Lexel, thanks for working on this. I hope a lot of people are interested. Richard, I believe, had an option for 3s input for 6v LEDs. Would that be doable here as well? I’d like to run an sst-70 at 6a with this and have 3 cells in series.
malkoff junkie
malkoff junkie's picture
Last seen: 1 hour 26 min ago
thanks Lexel !
Malkoff !
Agro
Agro's picture
Last seen: 2 min 49 sec ago
Any chance for a migration to 1634?
Hoop
Hoop's picture
Last seen: 10 min 11 sec ago
“+0.8€ double diode and input caps”
Why?
id30209
id30209's picture
Last seen: 20 hours 22 min ago
In for 1. Need to run Rgwn GT-FC40 @12V more than 2A...
Can we order now or need to wait for confirmation?
WTB Titanium 4sevens 2xAA tube
1stein
1stein's picture
Last seen: 1 hour 13 min ago
In for one. Thank you.
Lexel
Lexel's picture
Hoop wrote:
“+0.8€ double diode and input caps” Why?
Because XHP35 build does not stress like a high current XHP50.2
so no need to put unnecessary parts on it that add costs
I have looked for a cheap coil for lower currents like XHP35 because 2.75€ plus tax vs 0.45€ plus tax makes a lot of difference
And stocking up Coilcraft inductors is quite expensive and may create overstock in the end
Sure the Input of 3S is possible, but the more voltage gap the higher are the losses on the schottki diode reducing the efficiency and create heat
If someone can hand me a proper Atmel Studio Project with firmware migrated possibly,
it makes no sense putting an MCU on it as I have no firmware for it
Would be nice to have also more PWM resolution as the buck chip has only one input to control it programmed for moonlight
id30209 wrote:
In for 1. Need to run Rgwn GT-FC40 @12V more than 2A…
I think the design is pretty much final
Next step order prototype boards and solder paste stencil
Then validating at least 2 prototypes with XHP35 setup and one that stresses the buck a lot like 3S to XHP50.2
Agro
Agro's picture
Tom E has integrated it with AS7 recently:
https://drive.google.com/open?id=1jdx8U3LruVaAzHQi7MOk2UqsE5VW7wKK
But it’s out of tree and may not be maintained. Sad
I’ll see, maybe it would be possible to merge that into master?…
Lexel
Lexel's picture
I mean taking real advantage of the MCU features with code enhancing for example the PWM above the stupid low 8 bit
not just have 2 more output pins for 3 colors use in the D4V2
that 17mm build has one unused MCU pin anyway
Agro
Agro's picture
IMHO 3 colors is the killer feature that 1634 brings. Wink
Anyway, I know that Noctigon K1 has 10 bit PWM. And TK worked with loneoceans to enable that in his buck-boost driver.
I don’t think the code has been published yet though, at least a quick glance tells me that there’s no compile target for K1.
Superstocker
Thank you Lexel. I’m interested in one.
Scientist
Scientist's picture
Last seen: 1 week 3 days ago
Your link in the other thread does not lead to this one. FYI.
Please illuminate responsibly
Part time fragmented conciousness technician
UV triple using Sofirn C8F
395nm High Power LED in Sofirn SC31b
Ryzbor
Ryzbor's picture
Last seen: 3 weeks 1 day ago
No 1S 3v?
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 ; Sofrin C01R 660nm, Mf01 Mini Nichia 219B sw35+sw40
mattlward
mattlward's picture
Last seen: 11 hours 41 min ago
Will this be duplicated in either a 20 or 22mm package? I have an XHP50 light that I dearly love, but have been looking for a buck driver that will supply more than the 2.5-2.7 amps that the driver installed can deliver.
EDC rotation:
KR4, SST-20 FA3 4000k (favorite!)
FW3A, Nichia 4000k sw40 r9080 (second favorite)
FW1A, LH351D 3500k (third favorite)
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
Emisar D4V2, brass E21A 3500k (night light of choice)
Lexel
Lexel's picture
for 20, 21 and 22mm I have already Buck drivers on LM3409 on sale, PM me for order
more details here
http://budgetlightforum.com/node/57772
intosite
Last seen: 11 months 6 days ago
Is this still available?
Lexel
Lexel's picture
I have done a 3-week holiday and have only my phone with me to check mail or skype
So the board order with these prototypes on it is still not done
id30209
id30209's picture
Any progress on these drivers?
2 drivers i had from MTN died few days ago. They didn’t survive xhp35...odd...and GXB172 GB is still not moving
Lexel
Lexel's picture
I have ordered the prototypes PCBs
Lexel
Lexel's picture
I got the PCBs now here with the latest order
still need to find somehow time to make and test a prototype
got first to manage orders, then another driver project, a bigger order of 100 custom drivers coming up later this month
