Test/review of Review Charger Xtar X4
10 posts / 0 new
HKJ
HKJ's picture
Last seen: 18 hours 50 min ago
DSC_2270
DSC_2271 DSC_2272
A four slot LiIon and NiMH charge with automatic current selection and both mains and USB power input.
DSC_2118 DSC_2119 DSC_2120 DSC_2121
The charger was in a cardboard with specifications on it.
DSC_2266
The box included the charger, a USB cable and a instruction sheet.
DSC_2265
Xtar included two of their batteries, but with only one of each I will not test them.
DSC_2273
The charger has input for both USB power and mains power and output for a power bank function.
DSC_2276
There is a single button on the charger, it can be used to turn backlight on or restore backlight to full power.
It will also switch the display between the slots, this is only required when charging more than two batteries.
DSC_2496
During power on all segments will be shown.
DSC_2491
No batteries in the charger.
DSC_2492
Two LiIon in slot #1 and #2, charge current is 1A for both, this is the case with either USB or mains power.
DSC_2493
Two LiIon in slot #1 and #4, charge current is 1A for both, because charge is USB powered.
DSC_2497
Two LiIon in slot #1 and #4, charge current is 2A for both when charger is mains powered.
DSC_2494
Two NiMH in slot #1 and #3, charge current is 0.5A for both.
DSC_2489
USB output is on.
DSC_2526
The charger has specifications on the back, with black text on black background.
DSC_2278 DSC_2280
The connection are the common slider style that can handle from 31mm to 72.3mm, this means all batteries except protected 20700 will fit.
supportedBatteryTypes
supportedBatterySizes DSC_2498 DSC_2499 DSC_2500
DSC_2501 DSC_2502 DSC_2503 DSC_2504
DSC_2505 DSC_2506 DSC_2507 DSC_2508
The charge current is on the high side for 10440 batteries.
Measurements charger
  • When not powered it will discharge a LiIon battery with about than 0.5mA on a regular slot, but 16mA in USB slot.
  • When powered the charge will charge with less than 1mA when finished.
  • Below 2V the battery is assumed to be NiMH, above LiIon.
  • Charger will restart if battery voltage drops below 3.9V.
  • Voltmeter has a minimum reading about 0.8V and will show that from about 0.3V
  • Voltmeter is within 0.04V
  • LiIon can be charged with 0.5, 1A or 2A.
  • NiMH is always charged with 0.5A
  • With 1.3V on battery the meter will show 1.41V
  • The display show 0.5A when charging NiMH, but the actual current is around 0.8A
  • Slots change charge current at 52mm length.
  • Background light goes to low brightness after 60 seconds.
  • USB input will supply some power when charger is mains powered, this is not very good.
  • Mains cable is 33mOhm for each wire, this is fine.
  • Power consumption from mains when idle is 0.37 Watt with backlight on full brightness an 0.18 Watt at low.
  • Power consumption from USB 5V is 52mA when idle full backlight and 21mA at low.
Charging LiIon
Xtar%20X4%20%28SA18650-33%29%20%231
A nice CC/CV charge curve with termination around 100mA. The char current is 2A in this slot.
Display shows 2993mAh
Xtar%20X4%20%28SA18650-33%29%20%232
Display shows 2870mAh
Xtar%20X4%20%28SA18650-33%29%20%233
Display shows 3024mAh
Xtar%20X4%20%28SA18650-33%29%20%234
The charger curve in the other slots are similar, it looks like slot #2 has lower termination current than the other slots.
Slot #2 and #3 is 1A charge current, #4 is 2A charge current.
Display shows 3041mAh
Xtar%20X4%20%28PA18650-31%29%20%232
Display shows 2651mAh
Xtar%20X4%20%28SA18650-26%29%20%232
Display shows 2432mAh
Xtar%20X4%20%28BE18650-26%29%20%232
The different batteries is handled nicely in the charger.
Display shows 1886mAh
Xtar%20X4%20%28KP14500-08%29%20%231
A shorter battery forces the slot into 0.5A charge mode.
Display shows 944mAh
Xtar%20X4%20%28AP18650-26%29%20%231
Xtar%20X4%20%28SA20700-30%29%20%231
A larger battery with low internal resistance is charged fairly fast at 2A.
Display shows 2900mAh
Xtar%20X4%20usb%20%284xSA18650-33%29
Charging four batteries with USB power reduces the charger rate to 0.5A
Display shows 2938mAh, 3296mAh, 2995mAh, 3185mAh
Xtar%20X4%20%284xSA18650-33%29
Using mains power the charger will charge with 1A.
Display shows 2979mAh. 3091mAh, 3098mAh, 2912mAh
Temp7476
M1: 36.9°C, M2: 39.3°C, M3: 39.6°C, M4: 36.0°C, M5: 41.6°C, HS1: 46.0°C
Temp7477
M1: 42.5°C, HS1: 49.8°C
PoweronLiIon
The charger needs about 6 seconds to turn on.
Unpowered%20voltage%20sweep%20%231
The charger will discharge a full LiIon battery with about 0.5mA.
Unpowered%20voltage%20sweep%20%232
Except the USB slot where it will discharge with about 16mA (55mA while display is at full brightness).
It do turn the current draw off when the battery is empty, i.e. it will not over discharge batteries.
Charge%20Solar%20LiIon
The charger will not work with a unstable voltage.
Charging NiMH
Xtar%20X4%20%28eneloop%29%20%231
The charger uses a 10 minute precharge, before turning the full charge current on. The charger uses -dv/dt termination here and a two hour top-off charge at a fairly low current of about 50mA.
Display shows 1919mAh
Xtar%20X4%20%28eneloop%29%20%232
Display shows 2004mAh
Xtar%20X4%20%28eneloop%29%20%233
Display shows 1948mAh
Xtar%20X4%20%28eneloop%29%20%234
The other slots are similar.
Display shows 1880mAh
Xtar%20X4%20%28eneloopPro%29%20%231
Display shows 2395mAh
Xtar%20X4%20%28fujitsu%29%20%231
Display shows 2462mAh
Xtar%20X4%20%28leise25%29%20%231
The 3 high capacity cells are also handled the same way.
Display shows 2606mAh
Xtar%20X4%20%28eneloopAAA%29%20%231
The AAA is charge with the same current as the AA cells.
Xtar%20X4%20full%20%28eneloop%29%20%231
Detecting a full cell takes about 20 minutes, half of it used on the precharge. This cell also gets the two hours top-off charge.
Display shows 144mAh
Xtar%20X4%20%284xeneloop%29
Four cells is handled with the same speed.
Display shows 1953mAh, 1989mAh, 2022mAh, 1849mAh
Temp7482
M1: 36.6°C, M2: 37.8°C, M3: 38.0°C, M4: 36.0°C, M5: 35.7°C, HS1: 40.5°C
Temp7483
HS1: 49.0°C
PoweronNiMH
The charger uses the same time as for LiIon, before it starts on the precharge.
PoweronNiMH2
Including the precharge the startup time is 10 minutes.
TopOffCharge
Top-off charge 1s at 1A every 20s or an average of 50mA.
Charge%20Solar%20NiMH
The charger handled unstable voltage considerable better with NiMH cells.
USB output
  • When not powered it will discharge a LiIon battery with about than 15mA.
  • USB output is coded as USB charger (DCP).
  • USB output is turned off when charger is powered.
Xtar%20X4%20load%20sweep
The USB output can easily deliver the rated 1A.
Xtar%20X4%20usb%20out%2010ohm
It maintains the output voltage until the battery is empty with a 0.5A load.
Xtar%20X4%20usb%20out%205ohm
And also with a 1A load.
noohm
When unloaded there is some noise on the output, it is 51mVrms and 220mVpp
10ohm
Loaded with 10ohm (about 0.5A) is about the same 49mVrms and 225mVpp when
5ohm
At it increases slightly with a 5 ohm load (About 1A) to 62mVrms and 262mVpp.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
The charger worked fine for all my test batteries, current will depend on length of battery, battery chemistry, power source slot and number of slots used.
The power bank function only use one battery and has a good boost converter, i.e. it can deliver rated current until the battery is empty.
I will rate it as a good charge and power bank.
Notes
The charger was supplied by a Xtar for review.
malkoff junkie
malkoff junkie's picture
Last seen: 6 days 22 hours ago
Thank You.
Darryl.
Malkoff !
Terry Oregon
Terry Oregon's picture
Last seen: 1 day 11 hours ago
Is this unusual for a charger - that something under the slider is measuring length?  I always wondered if higher end chargers looked at the size of the battery - but haven't noticed that feature listed in other chargers.
My reviews: , My personal collection of lights LINK,  J5 Tactical V1 Pro review LINK,  Thirteen Optical Sensors review LINKZebralight SC700d review LINK,  Ray-O-Vac Super Power Sportsman review LINK,  Convoy S2+ color combos LINK,  How To flash D4V2 LINK,  Convoy S21A LINK
HKJ
HKJ's picture
Terry Oregon wrote:
Is this unusual for a charger – that something under the slider is measuring length?  I always wondered if higher end chargers looked at the size of the battery – but haven’t noticed that feature listed in other chargers.
It is not unique, NiteCore has been using it on some of their chargers.
When used to switch between 0.5A and 1A it means that you will stay within specifications for the batteries most of the time, but sometimes you will get a charge current below specifications (The switch do not know if you use a high current battery that can handle higher charge current).
whatsthepoint
whatsthepoint's picture
"The connections are the common slider style that can handle from 31mm to 72.3mm, this means all batteries except protected 20700 will fit."
So that means Xtar did not send you the newer version of the X4 for review that can charge  protected 20700 and 21700
never underestimate the power of stupid people in large groups
HKJ
HKJ's picture
whatsthepoint wrote:
“The connections are the common slider style that can handle from 31mm to 72.3mm, this means all batteries except protected 20700 will fit.”
I do not know if they have updated the design after I got this charger for test.
d_t_a
Last seen: 53 min 38 sec ago
Does this (older) version of Xtar X4 have 2×2A charging?
Specs seem a bit confusing (2× 1A or 2× 2A?) (I think Xtar just copied & pasted the info from the Xtar X2 model for this picture…)
The news announcement for the “Extended version” (ie. longer slots to fit protected 21700) Xtar X4 is dated on 2020-02-20 so I suppose it may take a while for the extended versions to be available (I suppose shops that still carry the older version would likely try to sell the older version first..)
http://www.xtar.cc/news/X2×4-Extended-Version,-AC-%26-USB-Input-NiMH-Li-ion-Battery-Charger-153.html
Is the info about “IR” measurement in the “Round Cell Charger Index” correct? (Xtar X4 doesn’t appear to measure IR)
https://lygte-info.dk/info/roundCellChargerIndex%20UK.html
Quote:
Xtar X4 4 (2) 31-72 10-26 1 2 0.5 NiMH, LiIon 4.2V USB, Mains V, mAh, Power Bank, IR
HKJ
HKJ's picture
It will charge with 2A on the two outer slots.
It was a error and is fixed.
Deputy Dog
Deputy Dog's picture
Last seen: 3 months 3 days ago
Well, I decided to try an X4 charger. I ordered it from BatteryJunction.com after I spilled coffee on in my VC4, which still works fine, but it couldn’t have helped it any.
stephenk
stephenk's picture
Last seen: 3 hours 28 sec ago
Thanks for all of your efforts in reviewing. My XTAR DRAGON VP4 Plus purchased just after it was launched is still going strong!
