I believe that is another “loss in translation”, and would be what I call, overdischarge… that is, when the voltage of the battery gets too low, and there is risk of polarity reversal, and venting with flames upon recharge.
given you are just learning about LiIon, I think you should avoid lights that cannot use protected cells. Unless the light has built in Low Voltage Protection (dont assume the light has that feature unless specifically stated).
jon_slider, you can take a cheap white flashlight with linear or direct drive driver (an SK98, for example), insert an unprotected cell inside, turn it on and leave it that way for a few days. Since the very minimum led Vf is ≈2.4 - 2.5 V (besides voltage drops in driver and etc.), the cell won't go below that voltage. Tested by myself.
I had no knowledge about modern flashlight and Li-ion. Bought lights on eBay before I knew BLF forum. Now the headlamp has been delivered. I think it doesn’t have low voltage protection. Not even a warning LED to signal when voltage is low. The product description doesn’t mention anything about voltage protection.
Just tried it yesterday and the medium brightness mode is plentiful enough for my need. Because of the lack of low voltage protection, I wonder if this headlamp would run until it kills the batteries. I have no idea about the runtime of the provided 18650 cells ($2 extra cost). And have no way to monitor when the headlamp is reaching low voltage. I plan to buy a better headlight such as Sofirn SP40, Skilhunt H04.
In the meantime, I’d like to salvage this headlamp. Because my need is pretty modest, this headlamp works OK in terms of lighting in medium brightness. Especially after I added diffusion film (#7 + orange filter bought from Boaz user in this forum). I think 2x protected 18650 cells would help to compensate for the lack of low voltage protection of the headlamp. And it looks like the battery case has enough room to accommodate 18650 cells with longer length. Do you think it is reasonable to use this headlamp with protected cells?
Why do you think there is no protection? What is written on the side of the cell, as seem in the picture above?
[edit] On second thought they look like these ultrafire fakes—are you cells ultrafires? They don’t appear be Sanyo cells or to have the extra crimps at the top that a pcb cell would have.
I have no idea. I don’t feel the flat wire (of the PCB?) linking the top & bottom as seen in photos of protected 18650 cells. Furthermore, the description on cheap Chinese products is not always accurate. Like exaggerated lumen units or mAh capacity. I just assume those batteries have no protection against running below low voltage .
Reading about PCB in the link given by member Barkuti above, it seems that the protection will work the way I hope. ie it has built-in Low voltage protection, which the headlight cannot provide. It just the description in the 18650canada.com store about tripping PCB which got me confused.
BTW, knowing the risk of killing a Li-ion cell if run below low voltage, I wonder who would design a flashlight without LVP and without a warning LED. If I knew those technical details I would never buy such a product.
It is something to keep in mind when gifting a flashlight to someone without a DMM who will not test the batteries periodically. But for myself, the other features of the light are more important than protection. Testing voltage and charging batteries is part of the hobby.
I couldn’t say one way or another but from the written wording it does appear to be useless if tripped.
That’s not how a normal LVP battery circuit works. Never heard of one like this, unless they are talking about the factory CID or PTC.
They say it stops the battery from working and can not be reset. Even if a LVP circuit fails you can still unwrap the battery and take off the circuit board and use the battery unprotected. So it could still be used if they are talking about a circuit board.
If they are talking about the CID or PTC then its no different than any other factory battery that uses these features, which most do.
Its really not clear what protection it has.
Unprotected cells (≈65 mm lenght). Protected cells are always a few millimeters longer, usually between 68 to 70.5 mm.
That headlamp is unlikely to over-discharge the cells. If in doubt, stop being adamant and test it. See what I said above in #7. Leave the lamp powered on with cells inside for 2 - 3 days, the emitter will be barely lit after that time. I am pretty sure it uses some sort of unregulated and/or linear driver, current drain drops as battery voltage drops and collapses over the emitter Vf. You'll need a multimeter to check cell voltages. You can check cell voltage from time to time if you will.
well, lets assume there is no protection in the batteries and no protection in the light, for sake of example
now imagine you are using the light and it starts to get very very dim. Noticeably very very dim… I mean DIM!
well, thats a warning that the battery is reaching exhaustion.
the prudent thing to do, if you are going to use LiIon, is to have a way to test the battery voltage. Especially when the light gets DIM!
avoid draining the battery below 3.6 volts… but when the light gets dim, the battery may already be at 2.7 volts. The only way to use unprotected LiIon safely, is to measure the voltage periodically, even before the light gets Dim…
As jon-slider says the light is going to become very dim when the battery voltage is low.
You can look at TA’s xp-l2 test data and look at the vf (blue) vs Output (orange).
This is the actual voltage to the led. A battery will have voltage sag under a current load.
This is only a example, leds have different vf’’s at the same current but they are typically close.
At a loaded battery voltage of 2.5v your going to be almost in the dark. Once the load is removed the battery voltage will bounce back.
You should be able to recognize the battery is getting low visually way before the battery is at 2.5v loaded.
This does depend on what mode your are in though. If your using the light in low mode and only drawing a few ma’s then your probably not going to notice much change in output until the battery is below 2.5v loaded. Best to check voltages but using in a higher mode will let you know once you have done it a few times.
Thanks jon-slider and you too 007. Now this explains everything (bold emphasis added). I am much less concerned now because I am confident I will be able to detect visually when the light get uncomfortably dim. I don’t have an instrument to measure voltage and even if I have, I prefer not to bring it with me during a hike.
I didn’t know that a LED will stop functioning around 2.5V. I thought it uses the Li-ion cell like a gas tank. It stops when the tank is empty which to me is equivalent to 0V and means dead cell. With this gas tank analogy, a cell around 2.7V to 2.5V is more than 50% full. So I thought the LED should continue to work perfectly, even though it is about to kill the battery.
So then problem solved. Usually I finish the hike before the light gets noticeably dim. When it did, I switched to a backup light. Nevertheless, I will follow your advice to buy a multimeter. For the sake of learning to get acquainted with caring Li-ion cells.
Better yet, get a flashlight with Anduril UI. Three clicks gives an approximation of battery voltage… close enough for practical purposes. Check it with a cheap DMM (Harbor Freight under five bucks) if you want a correction. Carry an extra battery and change it at your desired discharge voltage, maybe 3.4 or 3.5V or whatever you wish. Your battery will last longer by avoiding deep discharge cycles that cause increased anode degradation.
Those two batteries you received with the headlamp are unprotected. It’s the same wrap used on protected and unprotected, Sofirn used the same wrap on the first version without protection until someone on BLF mentioned it. Their battery now has a black wrapper.
I’d just plain stay away from anything that cheap. Usually a safety risk
Any of you grabbed some led MCPCB and did the diode test with a multimeter? Diode test current is quite a low value (<2 mA), and you should see a value of ≈2.45 V on the multimeter's screen at that current. When you add a tiny driver plus other parts voltage drop overhead, you know cell voltage is quite unlikely to drop below 2.5 V even if left unattended for a while, and definitively will never drop below 2 V which is the absolute minimum value for li-ion cells safety wise. I tested what I say here attaching a couple of old cells to an led with some thin wires and magnets, and waiting until the die would very barely glow.
I won't repeat myself with this @#$%. And don't be anal with the too low voltage on a cell (as some of you take it), it's a bs thing in my opinion. I do not mean to say it may not matter, but ask yourself how much actual time will a cell remain at 2.5 - 3 V in a flashlight, probably very little if at all.
Anduril isn’t everyone’s cup of tea, way too many options and config being only 4 clicks, is annoying for some. It’s way too close to everything else. NarsilM was 16s hold and couldn’t be accessed by accident
I enjoy Anduril myself but would prefer config to be changed
The only thing that is a exception to this (light output is getting dim my battery voltage is low) is a light that excepts alkalines, Nimh and li-ion.
They contain a boost driver for Alkaline or Nimh. Once the battery falls below the vf of the led at a current load, the boost circuit kicks in and tries to maintain the current to the led. Most of these type drivers dont have any kind low voltage warning for li-ion. They can’t distinguish between if your using a Nimh or a very low voltage li-ion.
Barkuti is my battery management guru, but on this one point I disagree based upon a study. It has more data than I care to assimilate, but some of it is worth reading.
From another thread:
docware wrote: The study is dated 19.4.2017, cells are Panasonic NCR18650PD. You can read the whole study here :
It reads:
Rdc,10s (related to the charge transfer resistance of the NCA cathode) has increased by ca. 60% when discharging to 3.4 V, whereas it has increased by more than 200% when discharging to 2.5 V (from 4.1v. at 25C). Hence, microcracks of the NCA cathode and weakened particle contacts are assumed to aggravate with larger cycle depths and cause the marked impedance increase.
While I agree with anyone that says terminating a charge early or not draining a cell to low will prolong life of a cell.
My thoughts are that I usually only cycle any one particular battery of mine a few dozen times a year. I just have several batteries with several different lights.
So any one battery doesn’t get used that much per year. Then about every two years or so out comes a better battery in the same format. Like most people I buy a few to replace my out dated cells. I never really use any cells longer than about 4 years with a few hundred cycles on them, I have newer better cells to use.
So while draining them to 2.5v that’s suggested lowest in most data sheets could be considered abusing them. I will probably never see the day when it actual matters becuse I have already replaced them with something better.
Not everone will feel this way, and some people will want the cells to last as long as possible which is fine. Nothing wrong at all having health cell practices.
I have mixed feelings about what I read in datasheets and some test data. When you use cells outside what the test data showed or outside what’s in the datasheets things change a little, kind of uncharted territory in the cell data world. There were a few peolpe that experienced this uncharted territory in this thread.
That’s a interesting thread on battery voltage being to low.
Most of us received batteries that had been setting on a shelf for 3 years never used and measured 1.9v upon arrival. As comfychair said ” they appeared to be just taking a little nap”. I still have those cells at 11 years old now. Its about due for another discharge test.
If I was using them hiking and needed the light to see, it definetly wouldn’t bother me to squeeze ever last lumen out of the cell.
