I hit ya up, Skylight.
Here’s my new link:
(Link removed)
Here’s my new link:
(Link removed)
I hit yours, gchart!
Hit. :-)
No links to hit?
Here’s my new one:
(Link removed)
@Barkuti
Uh, after some beers the light turned on. I thought that I can share my winnings with all I clicked … Do not know why this was in my head so long.
Thank you!
@gchart
Started a fresh game using your Link. Again only 0.32$
Here is my Link after I played the game. Will stay active for 8hours from now (0:00AM German Time):
(Link removed)
Thanks! I’m assuming you’re Fk D**R?
How do you redeem the coupons? Do they need to be activated before the link expired?
Anyway, new link: (link removed)
Yep - be sure to hit that Redeem button before the timer runs down. That’ll add it to your AliExpress Coupons list, so it can be applied at checkout. Otherwise, all your accumulated credit is lost!
Yes, before the timer runs out (ideally when all the slots are full or towards the end of the timer when it’s unlikely you’ll get any more clicks) you must hit the “redeem coupon” link. Doing so will add the coupon to your account. It’ll automatically get used when you place an order large enough to qualify. It’ll show you the discount when you select items in your cart before you check out.
For instance, say you “win” $0.32 and you get two more people to click your link and they each “win” $0.32. If you hit Redeem Coupon it’ll add a coupon for $0.96 off a $1.96 purchase to your account and it will be good for the next 3? days. Shipping charges do not qualify. But say you order a $2.00 item, it’ll take $0.96 off and your total will be $1.04 (plus any taxes and shipping).
@gchart
I think so First part is right, but the second is a mixture from my Alias. But should be me.
Have done this like I mentioned in the posting before. But that is the same I have tried before without success. Will now re-install the App every time before I use a Link. Anyway, I am happy that it worked now
edit/deleted
I explained to Skylight what was explained before … No need
Thanks for the explanation, Serlite, gchart and Not so bright. I understand it better now. First credit has been lost.
gchart and fellows in general, if you don't find links to hit maybe you could wait for a little while…
On the other hand, wellp, maybe I should post my links even if at this point I'm not really sure whether if I'll use them, as starting a game without joining is probably a waste.
Still 2+ hours for this gone. ;-)
Sun, 03/15/2020 - 18:57
Sorry Barkuti. I always check the thread for current links before starting a new game. But if I wait too long, I end up moving my “new game” window into the middle of the night and then miss out on some opportunities.
Hello,
Click mine also - thanks!
Just hit your link, DominikM.
Fellows, better be explicit with regards to your active links and their remaining time, some of the information in your posts above is not very clear (better use the forum clock as reference, Not so bright, and bear in mind post times change every time you edit them). I always edit and remove my active game link just before redeeming the coupon, thus if you see my link you can be sure it is valid.
You got a link that needs hit, Barkuti? I’m up for a new round in 18 minutes.
Oh! Well, my current round link is isn't here.
Mon, 03/16/2020 - 03:32
You got it, Barkuti! Sorry it’s only $0.32 but that’s how it goes now.
Here’s my new link:
(Link removed)
Hit your link too, Barkuti!
Me too
Hope I can give some back with this for the great advice, but only 0.32$
But seems you have a “full house”
My new Link (active until I delete):
(Link removed)
