Yes, before the timer runs out (ideally when all the slots are full or towards the end of the timer when it’s unlikely you’ll get any more clicks) you must hit the “redeem coupon” link. Doing so will add the coupon to your account. It’ll automatically get used when you place an order large enough to qualify. It’ll show you the discount when you select items in your cart before you check out.
For instance, say you “win” $0.32 and you get two more people to click your link and they each “win” $0.32. If you hit Redeem Coupon it’ll add a coupon for $0.96 off a $1.96 purchase to your account and it will be good for the next 3? days. Shipping charges do not qualify. But say you order a $2.00 item, it’ll take $0.96 off and your total will be $1.04 (plus any taxes and shipping).
@gchart
I think so First part is right, but the second is a mixture from my Alias. But should be me.
Have done this like I mentioned in the posting before. But that is the same I have tried before without success. Will now re-install the App every time before I use a Link. Anyway, I am happy that it worked now
edit/deleted
I explained to Skylight what was explained before … No need
gchart and fellows in general, if you don't find links to hit maybe you could wait for a little while…
On the other hand, wellp, maybe I should post my links even if at this point I'm not really sure whether if I'll use them, as starting a game without joining is probably a waste.
Sorry Barkuti. I always check the thread for current links before starting a new game. But if I wait too long, I end up moving my “new game” window into the middle of the night and then miss out on some opportunities.
Fellows, better be explicit with regards to your active links and their remaining time, some of the information in your posts above is not very clear (better use the forum clock as reference, Not so bright, and bear in mind post times change every time you edit them). I always edit and remove my active game link just before redeeming the coupon, thus if you see my link you can be sure it is valid.
Also waiting for a Link. If nobody jumps in, I will start a new game and post my Link.
Or do you like starting a game, where I can give you a hug?
edit
You wrote while I posted. Yes, thank you!
I will use your Link in a few minutes
edit2
OMG Received the following after clicked Link from gchart:
“It’s your turn to be Group Leader! You can only play with the same friend 3 times.
Play on your own, or invite another friend to play and win together”
