What is on your Want / Need / Got to have List ?
I'm looking at a few items, this being one of my next purchases.....that is unless anyone can recommend something better (?)
BD-1P
Features
1. Replacement Stainless steel strike bezel
2. Strong metal clip attached on both side.
3. Double AA for stronger beam and longer runtime
4. Mil-Spec Type III Hard Anodized finish.
5. Made from Aluminum alloy, really strong.
6. Water proof to IPX-8 standard.
7. Fully-regulated circuit, Broad input voltage (1.0V– 4.2V) and battery compatibility (i.e. alkaline, NiMH, 14500)
8. Precision Aluminum reflector (Orange Peel)
9. Simple operation. High-Medium-Low. No SOS and strobe modes
10. Tail standing
11. Tactical switch for momentary on.
12. Prominent runtime
13. Anti-reverse protection.
14. Candle mode
15. Advanced Cree XML-T6 LED
16. Extension part can be removed and the torch can be changed to BD-1(1*14500/AA)
Specifications
1. Dimension: Head diameter 24mm, Tail diameter 24mm, length 159mm
2. Cree XML-T6 LED
3. Lumen and runtime:
Double AA:
Maximum output of 180 lumens for 2 hours
Minimum output of 6 lumens for 100 hours
4. Material: Aircraft Aluminum Alloy T6061
5. Weight: 90g (without battery)
7. Battery: double AA or single AA /14500
8. Accessories: O-rings, user’s manual, lanyard(optional accessories), holster(optional accessories)
I'm going to purchase a quark aa soon. With 2aa extension tube for battery storage and to use with primarys if I run out of 14500's for some reason. Also a deep carry pocket clip. I love the quark UI. I almost bought the thrunite neutron a1. But I realized it had mode memory Which I hate. Besides that I think I'd prefer the thrunite.
My last quark was actually stolen a while back. So I gave the mini aa a chance. I liked the small form factor. But I missed the moonlight mode and the ui. The ring they supplied eventually wore out, causing the mini to disappear.
Great choice, i owned one and i love it. Just one thing make it more perfect : a SMO reflector
