Here is a video Toykeeper made showing the tint change between a single 7135 chip and a FET. It uses special software to cycle between 100% of the 7135 chip and about .35A on the FET. This means they are the same brightness level. The light on the right switches back and forth between the two channels every half second. The light on the left is just a reference to keep the camera from trying to compensate for the tint change. This big tint shift is what you would see if you ramp up smoothly and the 7135 chips turned off as the FET took over. I’m pretty sure people would complain.
So the 7135 is more green than the FET? I could not tell which is which. Is it LED dependent? For example, SST-20 vs. LH351D vs. XPL-HI vs. SST-40 for example?
If the 7135 is more green, than a single channel FET Anduril driver would be the best tint option? At the lower output levels, Anduril will lower the clock speed, so "I think" this means more stable output from a FET at low output PWM levels. In NarsilM, i didn't lower the clock speeds and had trouble with the ramping being smooth on a FET only driver. I was fiddling with single FET drivers on the 6V extremely high amp modded lights I was working with.
They sure jacked the prices up on these unless you order the 1 model/color/temp that is shipping from the US. Thats too bad. And the coupon expired. Oh well.
Jason and All, has anyone seen an official Runtime chart for the Mini? Or do they not exist for ramping lights?
We talk about the poor runtimes on Turbo due to the inadequate heat handling with many, including myself, reporting 30 secs or less. But this is compared to what? Has Astrolux ever claimed that Turbo should last longer than that?
I am aware of MoL’s mod plate and installed it in my two Minis. But are there official runtimes we can compare our before and after results to? Are we meeting spec? How would we know?
There are no official run time specs. The mini uses a FET driver so both brightness and Turbo runtime is influenced by what leds it has and what battery you use.
In general, a 7135 chip at 350mA will be warmer than a FET using PWM to get an average of 350mA. On many LEDs, like SST-20 and LH351D, the 7135 chip will also be more green. Those LEDs get lower duv as the current increases, but not all LEDs follow that pattern.
So if you want the tint of a SST-20 or LH351D light to be colder and less green, using just the FET can be an effective solution.
However, it’ll also reduce efficiency, make the output not flat, make the bottom of the ramp really coarse, eliminate moon mode, and might age the LEDs faster. But it can still be worthwhile to get rid of the green tint.
OK… i know i am 2 years late to this, but the MF01 mini is easily one of my favorite lights and i just started reading this to find whcih Bin sst20 4000k was used. was it FA3? or FD2 by the way?
I like my silver version a lot, and i want the green. But HOW, HOW did blue or purple or red not happen? they look SO GOOD. makes me want to buy some more silver and anodize them myself… If taking the head apart wasn’t so difficult… OK, im done with my complaining.
I think I remember someone saying they had 1000 pcs of the FA3 but they weren’t going to use them in the MF01S. They were saving them for another light or something.
Has anyone ordered the aluminum w/copper head recently? Does it come with the plastic spacer insert around battery + or the new Brass spacer insert Astrolux has been using?
I’ve read in the threads that it was coming with plastic, but wondered if they updated the copper headed version like the did the all aluminum version, by adding the brass insert for better heat Mgmt
