Thanks TK for all the info. I'm definitely interested in the new algorithm you got there. Regarding the voltage divider option, yes - this is required for more than 1S battery setups, or 6V/12V LED output, etc. I recall DEL saying the voltage divider method is more reliable/accurate from one unit to the next. We had a back and forth conversation about this, not sure if it was posts on BLF or pm's/emails. I recall thinking - why did I ever drop the R1/R2 support? For example, standard Nanji drivers had R1/R2. But of course it was to further drop parasitic drain. Now, I use higher resistor values values for R1/R2 for 2S configurations.
In NarsilM, I implemented voltage divider support as well, but also used DEL's method for it. Just checked and I'm not doing any filtering on the voltage divider reading, but I'm using DEL's "crude low pass filter" on the internal reference source.
Have you seen or heard of a need to calibrate the R1/R2 voltage divider lights? Guess I could check the BLF GT threads.
I agree with the shower btw... The take away from those graphs is, wow, we got way too many amps for way too little heatsink. The K1 W1 is the only one doing decent.
The graph on the Q8 looks outstanding though - about perfect, settles down after 7 minutes to a nice sustainable level. Actually most of these all look great and match to the light so well, for example the D4 v.s DVS.
What's the stable temp set for on these, or can it even be defined that simply?
TK - I'm not sure why there's not more posts about this! The more I look at these graphs, the more impressed I am!!
You probably didn't/couldn't keep up but there has been complaining goin on about the thermal mgt in a few of the Anduril lights, but mostly the ones that apparently are not configured properly - no special Anduril configuration. The Astrolux MF01 Mini for example, but "man of light" came out with a nice, somewhat of a fix for it -- a copper heatsink. You should check it out here: https://budgetlightforum.com/t/-/59714. Whether this is doing the right thing or not, not sure (maybe just delaying the inevitable?), but it's helping.
Yes, it still seems to vary… especially on drivers mass-produced for cheap.
I mostly just decided I was okay with a precision of +/- ~0.15V, since it’s not easy to get a mass-produced attiny device to measure more accurately than that… but it would be nice to tighten up those tolerances or make it user-correctable.
TBH, I was surprised it worked. I didn’t even tweak the thermal parameters for each build target. I built in some configurable new knobs designed to be set differently for each model of light, but I didn’t end up needing to use them.
They were all set to the default temperature limit, which in most cases is 45 C. The user can raise that to get more light, but I wanted to do the testing with a relatively low limit because it makes regulation more difficult. The ambient temperature was about 18 to 20 C, and I used factory reset to calibrate the sensor as if it was 21 C.
The K1 has a default limit of 55 C, because most of its heat comes from the driver instead of the LED… and the driver can tolerate higher temperatures than the user’s hand. It has so much thermal mass that the outside of the light usually doesn’t get very warm during use, and most of the heat is concentrated inside at the driver.
I haven’t tested a MF01-Mini with this change yet. Will have to try that. I’m guessing it’ll probably behave similar to a D4S, which was one of the lights with the most thermal regulation problems in older versions.
You are using old MCUs. ATtiny85 datasheet specifies that internal voltage reference 1.1V can be 1V to 1.2V, same with the 1634. The limits of the same internal 1.1 vref in the newer 1-series 3217 is 1.078V to 1.122V. Already there is a huge gain in accuracy. Added bonus is that the internal temperature sensor is factory calibrated. I’ve not needed to calibrate a single one of my 3217 based drivers for either voltage or temperature.
The 85 is getting close to 15 years old. Maybe it’s time to move on?
I can add support for the 1616/1617/3216/3217 chips whenever there’s toolchain support for them, but that’s not really up to me.
Even then though, I still plan to support older hardware… the whole point of having a kernel on these is to abstract out the hardware details as much as possible so hardware and software can be mixed and matched. I don’t want to abandon all the nice lights people already have.
There's no toolchain support? I see those devices listed under AtmelStudio, so I would think the underlying support in the toolchain it uses would be there?
Tests are still running, but so far the MF01-Mini looks totally fine. It regulates to a stable level more quickly than older versions, and then stays pretty flat afterward. So far I’ve tried starting from turbo and starting from the ramp ceiling, with similar results on both. I don’t see any of the bouncing he observed.
However, the stable level on this MF01-Mini appears to be only about 400 lumens… which is pretty embarrassing compared to the D4Sv2’s stable level of ~1200 lumens in similar conditions. Perhaps that’s a matter of having SST-20 in one and XP-G2 in the other, but I think the difference is too big to be explained by just that. The two lights are almost identical in size, shape, and power level… so it’s really weird that one can sustain 3X as much light as the other.
Looking at older tests though, I see the same result. 1000+ lm on both D4S lights I’ve measured, and about 400 lm on this MF01-Mini. It seems man of light had similar results, even with an added heat sink… 400 to 600 lm. So I wonder why it runs so much hotter.
Support in gcc exists but is still in somewhat early stages… like, someone got it working in November, and as of a month ago it appears to still be in “patch it yourself” territory instead of having compiled packages available. Debian still has avr-gcc 5.4.0, and it looks like the newer chips may need 8 or newer, so that’s another thing to figure out. Then there’s also the matter of finding ways to flash the chip, getting it into flashlight driver designs, etc.
It's the zip file with TE v1-1 in the name. Summary of changes:
added a few more config files of custom mods
raised default temp from 45C to 60C
raised max temp from 70C to 90C
added voltage calibration - clicks are for 0.05V increments, 5 clicks is 0.25V, 7 clicks for 0.35V - only for internal reference voltage measurements, not external voltage divider configurations
disabled goodnight mode and beacon mode, added version # display in it's place and changed the version # to a simple 2 digit #, for vn.n format
I added MF01-Mini test results to my earlier comment:
MF01-Mini: I tested both turbo and the ramp ceiling, because this thread indicated regulation problems at the ramp ceiling level. Here are the results for both. I let the second test run until the battery was empty, to see how the rest of the graph would look:
For some reason, this light gets the “brighter on a low battery” thing a lot worse than most. Maybe it’s getting an unusually large portion of its heat from the driver instead of the LEDs? I’m not sure why, but it’s the same pattern I’ve seen on every MF01-Mini test.
If anyone was wondering about those small but sharp-looking stairstep adjustments later on in the graphs, they’re not actually sharp. Here’s a close-up of one. It took 32 seconds to adjust output by about 3, moving up one small step (0.39) every 4 seconds:
Each of those 8 steps is the smallest adjustment possible using the given hardware’s PWM controls. The changes are not visible by eye during use.
Thanks TK for those very useful graphs! I’m surprised the 4 emitter Q8 can sustain a higher output than 18 emitter MF01S. Which emitter did the MF01S use?
Also that mystery light looks sweet. The regulation is really amazing. I’m guessing 7x emitters.
As that because you don’t use Atmel Studio? When using Atmel Studio, programming these chips are just as easy as the good old 85, the 1 series is fully supported.
Chicken or the egg? There is no firmware because there are no boards, or there are no boards because there is no firmware? Aren’t there plenty of people here that design BLF open source boards? It’s wouldn’t be to hard for them, it certainly wasn’t for me. Board design rules are exactly the same.
1-series come in all shapes and sizes. I’ve only been using 3217 which is the same size as 1634, gchart has used SOIC chips.
As mentioned, when using Atmel Studio, programming these chips are just as easy as the good old 85, the 1 series is fully supported. The registers and method of setting them is different, but if you can read an 85 datasheet, then you can read a 1-series datasheet gchart did all the hard work and figured this stuff out, he has released code samples and a port of RampingIOS which are sufficient to get started. Flashing is nicer too, besides MCU power and GND, it just requires 1 wire (UDPI).
That would be up to the author of Anduril. The MCUs themselves support everything the old ones do, it’s just a matter of taking the time to do the porting.
All components are the same expect MCU. Where I buy my MCUs, the 3217 is slightly cheaper than the 85. The added cost is the board for programming them, to my knowledge you can’t use those ISP USBASPs. I use the ATtiny416 Xplained Nano, it costed me about $11.5.
But yeah, not everyone wants to use Atmel Studio or wants to pay $11.5 for a programming board. Maybe linux support and cheaper solutions for flashing will come available, but until then I guess BLF drivers and firmware will be sticking to these older MCUs. They are still in production so they are by no means obsolete.
If I ever could loose my job (might be more likely with the virus), I just might have the time to do or help in the Anduril port. Just need a development/test setup, but again, not sure I'd have the time right now. Working at home now - been sick for the last few day - upper respiratory, they say bronchitis but that was with a 10 min facetime session with a PA...
On the MF01 Mini...
Yes, it is sort of baffling but the copper heatsink seems to make a world of difference. The factory stock plastic driver retainer is horrible. Plus I'd prefer a simpler FET+1. Not sure the extra zone of 7135 bank regulation is worth it.
Maybe they are using a FET clone that doesn't handle the heat as well? Not familiar with the D4S's design.
Factor 3x is incredible. Especially that the weaker light is actually larger.
What is the surface temperature of D4S and MF01 Mini while sustaining high load?
Maybe the latter actually has lower surface temperature at the same MCU temp?
Maybe the latter has less uniform surface temperature, leading the average to be lower further?
I remember the discussion on FET gate being kept only partially open at intermediate modes due to some resistor slowing it down.
This improves efficiency. Maybe Mateminco driver doesn’t have this resistor? (ADDED: probably not, because all-7135 seems too high anyway)
