I have a few 2*18650, 4*18650 and 8*18650 enclosed storage cases. And only the 2* storage cases are relatively strong.
My 4 and 8*18650 cases are close to worthless. The lips of the lock-system are hard to open and the part that keeps both sides of the case together starts cracking/have cracked.
Does anyone know of high quality 8*18650 or even better 12 or 16*18650 storage cases?
I'm not interested in 2-4-6*18650 storage cases. The more that fit the better.
I have these cases:
I found a few 10*18650 on Aliexpress but they look low-quality as well.
On 8 or more pieces I do not have, but here such container for storage 6x18650 very much likes, hermetically, made qualitatively. The model is called MecArmy B18.
I have this Plano Box, I haven’t fit 18650’s into yet. When I get home tonight from work I’ll give it a try.
Plano makes a variety of boxes, I bought this shot shell box which is too short to hold protected 18650’s
You could look into a pelican case, those are too expensive for me though.
I don’t like rigid boxes.
Nitecore NBM40 is the best because it’s made from silicone so it’s soft. You can throw it on the ground and it won’t damage batteries
I got the 8-fers like up-top, with the little hooky-thingy on top. Look like LDPE and have some flex to ’em, but those kinds of cases, 9 times out of 10 when I get cells in ’em (in the mail), they’re cracked in one/more places, usually the corners.
Unfortunately, none of those are enclosed 18650 dedicated storage boxes.
I'd like one in the OP but of higher quality.
Agro's don't look the same but it's something I probably would be okay with. Not sure if 18650 batteries fit well.
I'd prefer cases with dedicated slots for batteries. I can find many types of enclosed cases without any slots so they roll around. I also would prefer not using an extra kit like MoreLumens show.
So basically I'm looking for a unicorn :-D
Pity
Thanks for the help guys. If anyone know where to get them, please let me know.
I found some water tight small plastic containers at Dollar Tree . They are slightly longer then a 18650. I only have 4 extra cells but there is probably room for 6 in the container.
Much better quality then the dedicated one I got from Aliexpress and I think they were 3 for $1.00
This is the Plano Box, model number 4648-1, 3440 , this box does not have internal separation ribs.
I am able to fit eight 18650 cells along the length, and six more stacked on top. (seven should fit)
The cells are loose in this box , when not full the cells will roll about.
Obliviously this box is not designed for 18650 cells, it is a utility box I was able to purchase at Walmart for under $5
I have an idea which I haven’t tried so I don’t know if it will work, This is a water bottle ice cube tray
I don’t know if the cells would fit in those cavities, but if they do cutting the tray to fit into the box would be a viable custom storage case.
I found a case similar to yours. Although it's stronger than the dedicated 18650 boxes, I don't think I'm liking it so much. Because of what you also said: they roll about when not full. Little sad nobody produces high quality storage cases for 8+ 18650 batteries.
