Maybe. Iāve been meaning to move it to git for a while, because itās much more widely used. I just really donāt like some things about Git. In particular, I want to find a way to get its branching to do what I need first. Gitās branch features are one of its weakest points, and although it recently got something vaguely similar to how Bzr works, itās a shallow implementation which leaves a lot to be desired.
I generally have at least a dozen different branches in progress, many of which are long-term and/or private, and each has its own working tree with meaningful state that shouldnāt be part of the repository. Thatās trivial to do in Bzr because itās the default and recommended workflowā¦ but it goes against much of Gitās design so things quickly get awkward. Itās also weirdly tricky to interact with other instances (like GitHub) in terms of single branches instead of entire repositories. It generally grabs or sends all branches and checks out master, which is frequently the wrong behavior.
It looks like if I want similar branch functionality, Iāll probably end up with many many local copies of the entire repositoryā¦ and then merges end up being much more of a pain.
In general, Iāve found that the default behaviors in Git are almost always the opposite of what I want, so I end up needing a lot of overrides and workarounds. This has greatly slowed down the migration process. Iād love to go back to 2005 and slap Linus around a bit to convince him to change the design.
Probably not. I canāt run it, so I canāt maintain it.
Yes, a recent update slowed down the rainbow mode because people thought it attracted too much attention.
About 3-click actions not responding, there seems to be an issue of some sort which is very difficult to reproduce on purpose. Usually it can be resolved by cleaning the electrical contacts and making sure the parts are put together tight enough.
However, there are some brand new builds which might help too. Iāve tried to make it much more tolerant of electrical noise, and it may react better now when there is a weak ground contact or something.
There are many requests for that and I think it would be really worthwhile to support Atmel Studio. Though personally I donāt understand why because my personal experience with it was very bad.
What kind of maintenance would it need?
What if there were members interested in maintaining it?
I implemented to DarkHorse indicator led, lockout and candle mode support from Anduril for my headlamp drivers, but i dint find out how to enable LVP for indicator led
Hi everyone I need your help, I have tried the Star-Momemtary code, wonderful code, but I have to ask if you can change some points, I use it with a piezo button and I find it too sensitive, how do I increase debounce for avoid accidental ignition, or you have other things to propose, I also accept your ideas
Thank you so much
Thank you very much
why do you think I canāt use a piezo button? Iām using them made of stainless steel that are very good, and also underwater, that you would have other ideas
I didnāt say that you canāt use it
I just asked whether youāre using it to build a diving flashlight.
I used a piezo switch for a diving flashlight years ago, it was great.
I notice that there are quite a few people who know nothing about coding yet are able to flash firmware. The recent introduction of flashing pads greatly expands this number.
Yet the latest Andruil is not available to them in a binary form. They have to compile the sources which is problematic to quite a few a needless nuisance to a number of others.
I think it would be worthwhile to have some continuous building processā¦.
Sorry I ask a question, do not kill me, itās only recently that I discovered this forum thanks to all, I found this part where you have gathered all the firmware, but there is the possibility of finding some driver projects that you can create, thanks
