That is fantastic! Absolutely amazing and incredibly tiny detailed work. I guess the PWM has been set fast enough where it isn't noticeable or are there problems setting it so high for so little output?
The PWM frequency is 1.1 kHz. The light is rock-steady on lowest. The actual PWM output design values are 0x04 - 0x0F - 0x3A - 0xFF. There are no problems in lowering the low value down to 0x01 but the output is not quite linear at the lowest values. To make 1 lumen I would guess the output should be 0x02.
About the mem_after_off, it is sensible to bad connections and could shift level by knocking on the light. Perhaps 10uF across the chip could help. But it sure is my preferred kind of memory.
Again I have to issue a warning. This time it is the NANJG 105 driver from KD . They have changed it to 105A and it has a PIC processor (luckily I have two of the old 105 with ATtiny for my upcoming XM-L's). Here are pics of the two sides:
At least it has stars so it is possible to make a 3-mode (I hope). I expect it has memory after ON plus 2 sec.
Now to the big question: are drivers with ATtiny about to die out?
That would be a real bummer, the Atmels are the easiest to re-program. OTOH, I've got a PIC-Kit2 programmer on the way, so this is a strong incentive to port the BLF-VLD to the PIC platform ;)
Hi, I followed this thread with great interest, and I already programmed some kind of flashlight driver (a somewhat special thing for geocaching though, not a general flashlight; wanted to do that next).
I too got the new 105A from KD (unfortunately a 5-pack), while I earlier got two 105 ones. And fortunately I have still some AK101 and AK47 around.
I just got into programming AVRs (WinAVR/AVR Studio), I don't know if I really want to adapt to PICs, too.
I wonder about code efficiency... The 12F629 has space for 1024 instructions (of 14bit each...), which is more than the ATtiny13 (1024 Bytes for 512 two-byte-instructions), but tiny13 has a bigger (more powerful?) instruction set (120) than the PIC (35). The available free compiler (Hi-tech PICC lite) probably will optimize less than the avr-gcc - So I'm looking forward to your porting reports.
Furthermore the 12F629 doesn't have ADC nor PWM (as far as I know). -- I prefer AVR I guess :)
Did you order a 'real' PICkit2 (~33 EUR, ebay) or a cheaper clone (~17 EUR, ebay)?
Hi and welcome to the BLF DrJones!
Hope you will enjoy your stay : )
Hey DrJones, Glad to have you here!
I knew about your site many many months ago! Thanks for your help!
Welcome to BLF DrJones. I wonder, is this the same DrJones of DX forum fame? :)
Hi and welcome DrJones.
Good to have another active programmer here.
I have been reading this forum since almost two months ago and I like the fact it is for BUDGET lights. I like budget flashlights because I like to play with them replacing leds and drivers, something I won't do with expensive flashlights. The expensive flashlights I have are collecting dust just because I almost don't use them.
Considering some people here is wanting to use PIC microcontrollers I am posting this information I posted some time ago in another flashlight forum.
I have written and tested this PICAXE source code to implement multi-level functionality in DX SKU 15880 or any driver using Microchip PIC12F629 microcontroller.
The test was done using a regular LED instead in the actual driver. It must work in the actual driver.
You need to replace the stock microcontroller with a PICAXE-08M Surface Mount AXE007MSM device. You will also need to do some pin swapping and lifting since PICAXE-08M uses pin 5 to do PWM and DX SKU 15880 uses pin 7.
I used PICAXE mainly because there is no necesity for a programmer to burn the program into the device. A computer with a serial port (or USB to RS232 converter) and 2 resistors is all needed to program the device.
For more PICAXE information visit PICAXE's site.
This is the program's source code:
'LED PWM Driver software.
'Writen by Juan C Galvez
' the following EEPROM entry contains the desired level percentages
' The first entry contains the level position to use the next time the driver is powered.
' Next are the desired level percentages.
' The last position next to the last desired level must be zero. It is used as end indicator
' Example EEPROM entries:
' 1, 1, 50, 100, 0 means 1%, 50%, 100%
' 1, 10, 100, 0 means 10%, 100%
' 1, 10, 30, 50, 100, 0 means 10%, 30%, 50%, 100%
' No SOS nor STROBE implemented.
EEPROM 0,(1, 5, 50, 100, 0 )
symbol LEVEL_SHIFT_PERIOD = 3000
' b0 keeps the current level positi b0 = b0 & $0F
' bit7 If 0 then keep the current level. If 1 then go to next level. Note: bit7 if the MSB in field b0
' b1 Current level value (%)
read 0,b0 ' Read next level position
if bit7 = 0 then ' If bit 7 not set the keep the current level.
read b0, b1 ' Read current level value
else
b0 = b0 & $0F ' Turn bit 7 off before reading position value
do
b0 = b0 + 1 ' Go to next level
read b0, b1 ' Read next level value
if b1 = 0 then ' If next level value is zero then start over.
b0 = 0 ' Reset position
end if
loop while b1 = 0 ' Keep until a valid position has been
end if
bit7 = 1 ' Turn bit 7 on. This means that the next time the driver must go to the next level
write 0, b0 ' Write the value to EEPROM position 0
w1 = b1 * 4 ' Multiply level value times 4
pwmout 2 , 99, w1 ' Turn the LED using the current/calculated level
pause LEVEL_SHIFT_PERIOD ' Wait n seconds
bit7 = 0 ' Turn bit7 off so the next time the driver is powered it will keep the current level
write 0, b0 ' Write current level position to EEPROM
b0 = 1 ' Enter an infinite loop
do
pause 2000 'Used to allow firmware upgrade while running.
loop while b0 = 1
As written, the code implements 3 brightness levels 5%, 50% and 100% but that can be easely changed. Also, the level change occurs if the driver is powered for 3 seconds; I mean, if you turn the driver on and keep is for at least 3 seconds then the next time you turn the driver again it will start in the last used time. I you turn the driver on and turn it off before 3 seconds then the driver will use the next level the next time it is turned on. To change this 3 seconds just modify the line containing:
with the milliseconds you want to use.
I hope this code is useful to some one.
Juan C.
Fantastic info, Linterno...and welcome to BLF!
Aloha and welcome to BLF DrJones and linterno!
PICAXE is interesting and somewhat strange... From the specs it seems that the flash memory only contains the PICAXE interpreter while the user program is loaded and stored in the EEPROM (probably tokenized) and interpreted by the (flashed) interpreter. I have seen something like that in an ATtiny2313-based educational set.
Edit: Yes, I'm the DrJones at DX :) Hello all :)
Glad to have you here DrJones... The info in your site has been very usefull for me
Welcome linterno to BLF! (I guess 'linterno' is spanish for 'lantern').
Very interesting with the picaxe, just a pity one have to unsolder and solder SMD multilegged chips.
Thank you all for giving me a welcome.
In fact in spanish is “Linterna” but that is female. Since I am a man I prefer to use “Linterno”
My plan for building that driver is to actually keep the µC running for a while after the user has switched the light off. I'm going to use a bigger capacitor parallel to the µC, so when the battery power is off, it runs from that. Some battery sense pin is required to check if the flashlight is on or off, and sleep with watchdog is engaged as soon as power goes down (via interrupt). This allows timing the 'off' taps for mode changes etc. Since programm logic will be simpler, it might even use up less memory and leave more space for fun ("Hey look, that light says my name in Morse code!" :) )
When I first thought about the the BLF-VLD, I wanted to keep the MCU running too, but I soon realised that this just wouldn't work with the standard PCBs available. For one, almost all ATtiny based PCBs have voltage dividers for battery monitoring, that will suck a buffer cap empty in a matter of milliseconds. Second, to actually detect the power-off, one would have to add a wire directly from the battery's positive end to an I/O pin, circumventing the protective diode. As a major design goal was to have a driver program that could be flashed into a stock PCB, that was the end of that idea ;)
AFAIK, most PIC based PCBs don't have the voltage divider problem, as the 12F629 doesn't have an ADC and therefore can't monitor the battery's voltage. But you'd still need to add the wire for detecting power loss and would probably have to upgrade the buffer cap.
Have noticed your posts on DX forums , they stand out and have been helpful just knowing that your advice is a step above the norm..
I also have to admit to having a thing for Mrs. jones ..
We gotta thing goin' on ...
BLF-VLD version 0.4 is available for download here. Special thanks to sixty545 for giving valuable feedback and spotting a few bugs. This release is not as thoroughly tested as I would like, but I do have a lot on my plate right now. Bug reports and suggestions are still welcome, but it might take some time before I get around to fixing anything.
Here is the section from the ChangeLog:
2011-01-10 Tido Klaassen <tido@4gh.eu>
* BLF-VLD: release v0.4
* driver.c: fixed initialisation of ADC
* driver.c: added support for mode switching based on an I/O pin's
state
* driver.c: fixed driver getting possibly stuck in extended mode if
compiled without extended mode support and EEPROM gets corrupted.
* driver.c: added compile time option for gradually lowering light
level in low battery situation
