Where can i find gaskets for the 4040 CULNM1.TG ?
I'm not sure about CULNM1.TG restocking, I will try to source some.
There are no gaskets currently available for 4040.
And ask for the culpm1 as well?
I'll try.
Luxeon V 4000K is in stock again, CAT code is V13F (same Vf bin as 5700K so they can be mixed), mixing 4000K+5700K is added as option for all 4x and 6x boards:
https://led4power.com/product-category/leds1/lumiledsluxeon/luxeon-v/
Perfect, thank you.
Neven,
I hope you are doing well. Any update on the 3030 4x 20mm boards?
Due to current situation, those boards will not be available for some time, 16mm 3030 DTP are back in stock, next are 3030,3535,4040 20mm Cu DTPs and 3535,4040 16mm Cu DTPs.
Thanks for the update Neven.
Are there any plans for 20mm triple 3030 MCPCB?
Same answer as in post 1291.
Will you be selling SBT90.2?
Depends on interest, but it's an expensive LED, additional problem is custom DTP PCBs have to be made and those have large min. order quantity, so I'm not sure it's feasible.
If you would just sell the bare led, people could buy the 20mm DTP SST-90 board from kaidomain. But I know that your policy is to always offer the option of the led reflowed on a board.
IIRC it’s law rather than policy, something about not being allowed to be a reseller.
Edit: Yes, explained in post #1233
Thanks, I read that too and forgot about it.
I’m amazed i remembered.
Going back to your point though it doesn’t have to be an MCPCB that’s sold with the LED, it could be sold with just a gasket, or something else for minimal cost. Wire, even.
And L4P could offer them soldered to Kaidomain MCPCB.
Much higher unit price but small MOQ.
Yeah, instead of getting a custom PCB made just buy some of these
http://kaidomain.com/20mm-x-1_5mm-DTP-Copper-MCPCB-for-Luminus-SST-90-2pcs
I would definitely be interested in buying some SBT90.2 if it was reflowed :)
I hate reflowing myself.
Oh wherever Vinh is getting these noctigon MCPCBs for the SBT
Maybe they are MT-G2 PCBs?
