MascaratumB, like LB was saying originally, it is best to measure this using a DMM if possible. I have one capable of measuring “uA” while most of the rest can at least measure “mA”. Essentially you remove the tailcap, put the DMM in uA or mA mode, and put the leads in between the battery and the body (replacing the path of the tailcap). This will tell you the rate of drain.
Many times if something active is happening (like a blink) the MCU may be left running at normal speed instead of sleeping. This can have a very high drain. Like 10mA vs 5uA (0.005mA).
Ok, now I got it! Like I said, yesterday I was sleepy and my brain was not doing the right connections!
So, the drain may not be linear, then the estimated time to drain the battery can be over or underestimated.
Thanks LB
Thanks gchart! I tried with my Uni-T UT33D multimeter but I guess it doesn’t read such small values. I need to get a decent one or a DMM to make this type of measurement!
Also, as I am not familiar with some of these measurements and concepts (theoretically and empirically) I was relying more on the type of “action/tests” i did above.
Now I see they may not be worth due to the aspects you guys mentioned
Thanks again for the clarification!! :+1:
I’m not sure, but it looks like your model does measure mico amps. It’s marked 2000u at about 7’oclock on the selector dail.
That should be plenty good enough for parasitic drain measurements.
You might give the next setting or two a try (20mA or 200mA). The 2000uA setting is max 2mA. The lights might be max’ing that out. Especially the SF14 being a clicky, the flashlight will try turning on and will likely be using more than 2mA.
Even the M150 will probably be over 2mA. The MCU will try turning on and unless they’re using a really low power mode, it’ll initially be quite a bit over 2mA.
Just tried what you mentioned with 4 different lights (Skilhunt M150 and M200, OTR M3 Pro, and Sofirn SF14).
I tried all 4 on the three settings (2000, 200 and 20) and the results are always “Zeros” :zipper_mouth_face:
I guess the multimeter is damaged :zipper_mouth_face:
I went to look for an older post I did and it was working… not now .
So I will not have results with this and this function is ruined…
Thanks again for your support on this and for your explanations!!!
It may be that the current probe fuse has blown on your meter. Easy to do this accidentally by trying to measure something that exceeds the rating (200mA in your case).
Try the 10A probe hole for the positive lead and the 10A setting on the dial, then reduce the setting one step at a time to see the reading.
The fuse should be an easy fix if you have a spare fuse—sometimes there is a spare in the case. You will have to open the cover, likely some screws on the back cover to access the battery and fuses.
I tried it on both, middle and left, and on the different settings above. Nothing works… Sometimes the - appears, but it disappears then…
I believe it is “poof” :person_facepalming:
Then like others have said it’s about got to be the fuse.
You can just jump the fuse to get it working but I wouldn’t try to actually measure current draw with the light full on unprotected like that.
Even a lesser value fuse would work for measuring the parasitic drain.
The red probe lead will have to be in the left side hole though.
Given the current situation I may have to wait some weeks to take it to the store where I bought it and check if they have fuses there. It is a small shop, but the guy seems savy on this.
Stupid fuse … or stupid me :rage:
Now I won’t be able to entertain myself measuring this :person_facepalming:
Take a 9V battery and hold one lead, touch the other lead to one nipple (on the battery, duh), then touch the other nipple with your opposite hand. Ie, use yourself as a resistor. See how much current flows through the meter. You can throttle it by squeezing harder on the leads and lightening up, too.
The SF14 is a tail-clicky, no? So making any connection is essentially turning it on, full blast. The fuse won’t blow, but it’d show overrange “0L” or similar.
The sense resistance at the lowest scale might be too high to even let it get started, dunno.
So… first check the ammeter through a large resistance (multimeg). The “10A” socket is only used at the 10A range, and is unfused. That can make your meter go pouf, but V/Ω/mA should be fused.
I hate to say it but the current measurement part of your meter maybe toast.
That’s a little dissapointing that they obmitted the fuse to save a few cents.
I went back and looked through the owners manual of the Uni-T UT33D and all current measurements are made on the far left red probe hole. Which is the far right hole on the back of the pcb where the fuse should have been. The actual board has been designed to jump the fuse by a added trace. The trace could be cut and a fuse added but if it’s toast there’s no point unless you had one that worked. They had to actually go back to their gerber files and add that trace to jump the fuse and have that new file submitted to the pcb manufacture with new boards being made just to admitt the fuse to save some pennys.
It also says as a warning that if the fuse blows it could still damage the meter.
Well, yours did not have a fuse to start with, so it could be damaged.
Reading from page 17 of the manual.
According to the front of your meter, the red should be in the left for > 200mA and that port is not not protected by a fuse. For < 200mA use the center port. It is fused. But if you use it for > 200mA (easy to do) you could blow the fuse.
Thanks for checking it!!
I was a bit :o when I noticed that mine didn’t have the fuse…
I will have to go to the store where I bought it and ask the seller about this.
Not knowing how this things works completely, I may have screwed up the only fuse it has, so my fault is there too.
However, it seems that the other fuse could have been useful avoid some damage, no?…
The rest of the functions seem to work well, so far. I tested LEDs and battery voltage. So far they seem to be working except this… :weary:
I will have to get a DMM as it seems more appropriate to the type of measurements we do concerning flashlights.
Thanks again folks for your help and for checking this stuff! I still have a lot to learn…
The big bare wire is the current sense shunt for the 10A range and it is certainly okay. It looks like your fuse is intact too? So no blown components.
My guess is that either the wipers of the rotary switch are not making a good contact to complete the circuit, or the Chip On Board (COB) controller is broken. You should be able to inspect the wipers to see if they contact or have a gap.
You should be able to read current with the left or center probe socket, the sensitivity and fusing is the only difference, but try the left with a known low-level current and then work your way on the settings.
