CC/CV mode depends on the load you connect. For example, if you are charging a battery, it will be CC mode first, and then CV mode when the voltage reaches the max value, the output voltage will be constant and the current decreases.
Your #67 post above has a formatting problem. The customer feedback text line is full of non-breaking spaces ( ), this is wrong and causes the line to span far outside of the forum text box in small screen devices like mobile phones (you can see the non-breaking spaces if you edit your #67 post and switch to plain text); it's the following sentence, which I've edited and removed all non-breaking spaces. If you care please edit your post, completely remove the sentence and replace it with my edited one, that or manually removing the non-breaking spaces fixes the problem:
Perfectly packaged power supply. How would I buy something from Apple;) Equipment of very high quality. I can't connect to my iPhone 8 via Wi-Fi. Correct it. I recommend the seller.
(you need to turn on the location service or consult us)
Packed in a box in polyethylene with bubbles. It works up to 60V. Naturally, it will not be able to deliver above the applied voltage, because it is a buck mode, there is a separate "+" jack for battery charging connection.
The items were just as described. Best packaging. Device assembly was straight forward and there was exactly correct amount of all components. With suitable power supply the device worked correctly.
the module is just super! The build quality and soldering at the highest level! Low ripple and high accuracy of the output parameters, I am delighted! Thank you seller.
The product arrived well packaged, everything perfect and consistent with what is written in the advertisement. I am satisfied, very good. delivered before the deadline, thank you.
(seller: if you are charging battery, you had better to use the battery charging terminal, I see the settings, 4.2V is peak voltage for one 18650 battery)
the packaging is great. satisfied with the product. thank. the power supply will come and write in more detail. and you need to purchase the battery separately.
Are there any plans for this kind of unit to be available in a higher current? I love the DPS5020 and have been considering it, but I really like the interface on the RD6006, along with the case to hold it all with the PSU.
