Intl-Outdoor USB Device Charger XM-L T6 Flashlight
111 posts / 0 new
Richie086
Richie086's picture
Last seen: 2 min 42 sec ago
Hi forum, looks to me Hank from Intl-Outdoor has come through with a really nice flashlight/USB charger that I received today.  Typically, my wife and I have been using a NewTrent backup battery charger while on the road in order to keep our Ipod/Ipad, and other devices powered up when away from an electric outlet for charging.  Now we'll be able to have a second portable charger with even greater charging capacity coupled to a powerful XM-L flashlight all in one.
For details, see Hanks website for this flashlight : http://www.intl-outdoor.com/double-usb-mobile-device-charger-318650-xml-t6-flashlight-p-365.html
It came with a paracord lanyard.  The USB charging cable to recharge the flashlight from a computer USB port was several dollars extra, but Hank included it as a gift after contacting him that I forgot to add it to my order.  I did ask him to send me a Paypal invoice, but he included it anyway.  Thanks Hank!
Just a size comparison, Skyray 3800, USB Charger/Flashlight, and Skyray KING
Skyray 3800, USB Charger/Flashlight and Skyray KING - The 38mm reflector appears perfect.  The head unscrews from the body of the flashlight just below the lowest cooling recess.  The tail-cap unscrews to slip out the battery carrier to insert 3x18650's in parallel.  I tossed in some Redilast 18650-3100's from my Skyray KING for testing.  They were slightly tight inserting, and rubbed slightly while inserting into the flashlight tube, but worked great.
Great size diameter and excellent knurling, certainly won't slip out of your hand.  Threads felt really nice and smooth.
Yep, this flashlight has a second business end for sure.  One USB output exclusive to Apple products, and a second USB output to  charge all other devices.  Obviously this will only charge devices within USB specs.  The mini-USB is an input to charge the flashlight itself so you don't have to remove the 3x18650 batteries should you not wish to.
Normally I would always remove batteries to toss on my Pila, but it may not be necessary in this case for several reasons;
1.  Batteries are inserted in parallel not series.
2.  Specially designed internal circuitry within the tail-cap controls charging and automatically cuts charging when a full charge is detected. At this point I don't think it balance charges, but having a parallel battery configuration, they drain exactly the same, and it stands to reason they will charge and self-balance also. However, even with Redilast 18650 3100mAh's, I take nothing for granted and will carefully verify how well it recharges my batteries should I decide to charge them inside the flashlight. It may take as long as 6-8 hours, so leaving them in the flashlight to charge is something I don't think I'd do very often since I'd have to plug it into my computer.  Still, a nice option to have.
A photo of my Ipod Touch recognizing the flashlight and charging.
Photo of my IPAD-1 recognizing the flashlight as a charger.  I also tried it on my wife's IPAD-2, and started charging perfectly.
NOTE: The rear LED's you see illuminated only come on when the small lower button is pressed, which is what activates the charging ports.  They also indicate battery condition and can be used while the flashlight is being used as a flashlight.  The 4 RED LED's indicate the flashlight is nearly fully charged, and if the single BLUE LED is also illuminated, this means the batteries are fully charged.
The one thing that did concern me was that no dust caps are included with the light.  Initially when I purchased it, I had already decided to make my own custom made rear cover to keep moisture and dirt out of the USB & Mini USB openings.  Fortunately before taking on a project like that, I remembered I have soft rubber USB and Mini USB caps on hand.  So I inserted them and problem solved, and it also maintains the cool look of the flashlight.  The dust caps being made of soft material make it extremely easy to insert and remove them.
In addition to the great features of this flashlight, it's also one of the custom "Build-To-Order" lights that Intl-Outdoor offers.  It's available in a 3-mode or 5-mode, and Cool White-T6 1A or
Outdoor beam shots to follow.
Richie
Edited by: Richie086 on 04/30/2012 - 22:34
Richie086
Richie086's picture
Here's a few beam shots showing the USB Charger Flashlight in action.  The comparison flashlights were the new Citycat Big Head K8 offered by CNQualitygoods and a Yezl M6X, also offered by CNQ.  It's not possible for me to get a tail-cap reading on the USB light due to the battery carrier configuration.  But it's rated at 800 lumens.
The Big Head K8, is rated at 900 lumens and driven from a LD-29 driver.  Tail readings were 1.20a HIGH mode with 2x18650 and 2.40a HIGH mode with 1x18650.  No difference in brightness between battery configurations. Tint is NW /XM-L T6-3C.
The Yezl M6X is rated at 800 lumens and rated at 2500mA.  Actual tail readings were 1.88a.  Tint is CW XM-L T6.
USB Charger Flashlight, NW Tint
Big Head K8, NW Tint
Yezl M6X, CW Tint
Richie
gerald_clark
gerald_clark's picture
Last seen: 3 years 6 months ago
What makes Apple USB so special?
kramer5150
kramer5150's picture
Last seen: 7 months 2 days ago
Nice addition!!  I really like the parallel 18650 configuration, and the built in USB charger is a very nice/unique feature.  Looks like a must have for anyone who travels with a laptop.
thanks for sharing!!
CheapThrills
CheapThrills's picture
Last seen: 3 weeks 6 days ago
Ditto, sorry for ignorance but is it different in some way?
BetweenRides
BetweenRides's picture
Last seen: 4 years 2 months ago
Thanks for posting, Richie. Very nice flashlight and functional to boot. What a great travel light.
Can you show pics of the rubber caps out of the light?
pounder
pounder's picture
I know with the Iphone the wall charger is faster than the computer USB ports..500ma vs 1000ma..the Iphone senses the source and charges appropriately..maybe the Apple charging port is capable of the "fast charge" mode and has the correct variables to make the Iphone charge at the faster rate..the other USB port will probably charge it just at the slower rate..
just guessing from my experience with my Iphone though..
Richie086
Richie086's picture
The flashlight has a regulator that can sense charge requirements from 300mA-2500mA. The home charger for my IPAD1 and IPAD2 has an output of 2.1a, but my Ipod touch requires 1a charge current. I don't have an iPhone, but I'd imagine it may require similar charge current as the Ipod Touch, perhaps a bit more. I'd have to assume the "Apple" side has additional circuitry for varying Apple device charging requirements.
Richie
Richie086
Richie086's picture
HI BetweenRides, the 5th photo from the top shows how the light comes without the dust caps I installed.
Richie
Ford Prefect
Ford Prefect's picture
...Has voltage on the data lines
The resistors (and therefore voltage at the data pins) vary between the generations of devices and is used to communicate the current that the device is capable of providing to the idevice.
Shadowww
Last seen: 3 days 1 hour ago
The differences between how Apple charger USB port works and normal one does is described quite detailed-ly here:
http://www.ladyada.net/make/mintyboost/icharge.html
In short: Apple devices require specific voltages on data pins to charge quickly, otherwise only slow charge would be possible.
scaru
scaru's picture
Last seen: 5 years 9 months ago
Yep, the only difference is a higher charge rate. I know the wall to usb charger that comes with ipads puts out 2000 ma,  and the iphone one 1000 ma.
gerald_clark
My Dell Streak also uses 1A USB charger.  I believe they just short the data pins at the USB port to signal the device that high current is available.
pounder
pounder's picture
ah I did not know the Ipad was so high, but makes sense with the larger battery capacity..
Flashlight Turtle
Flashlight Turtle's picture
Last seen: 5 years 3 months ago
Does it tail stand?
Richie086
Richie086's picture
Flashlight Turtle wrote:
Does it tail stand?
It's very wobbly with the 2 main USB dust plugs I used, but without them it's totally rock solid.  I may look into trimming down the dust plugs I used so it tail stands correctly with them in.
Richie
BetweenRides
Actually, hoping to see pics of the actual dust caps themselves...
Richie086
Richie086's picture
Beam shots added to #1 post.
Richie
Richie086
Richie086's picture
How about direct links to the two companies I purchased them from some months ago.  As I recall, both were received about 2 or 3 days after placing the order.
Richie
dthrckt
dthrckt's picture
Last seen: 3 weeks 3 days ago
great review, thanks.  if I hadn't spent $500 on lawn equipment this weekend I'd be on this instantly.  Time to figure out where to find some cash!
I'll be curious to hear if the dust caps stay in place when the light is handled a lot (pocketed or bagged).
I'd just finished making a 4s6p AA usb charger w/ 3 jacks when this light first popped up.  Timing is everything Yell
Richie086
Richie086's picture
Hi Dthrckt, they are perfectly secure no matter how much handling you do thanks to the soft rubber each type is made from.  You won't have any problems with them falling out.
Richie
benckie
benckie's picture
Last seen: 9 years 5 months ago
Most usb's put out 500 ma not enough for an iphone, i have burned out some cheap multi cigarette lighter adapters with 500 ma usb ports charging iphones.
I use this while play music in my man cave and plug the iphone into the cigarette lighter sockets not the usb port as it can not supply more then 500 ma, then plug the cigarette lighter adapter into my hobby charger's power supply.
I brought a XTAR - WP2 II Li-ion Battery Charger  for my old man to charge is Torch batteries we tested it for charging Iphone 4's even though its usb out put is rated for 500 ma only, it fully drained a single  trustfire flame 2400 mAh to charge the phone 75% and took a long time but did not burn out on the test.
So this torch really interest's me since it can charge our apple products correctly with decent speed and becuase there is 3 cell's in parrallel you could charge a couple of phones no problem and would be good for camping, but will need dust covers, i have added this to the wish list thanks for the great review.
hazna
I agree about the xtar wp2 II.  I bought this as a li-ion travel charge and was planning on using with my ipod and htc phone.  My ipod nano is a little older (4th gen?) and seems to charge this pretty easily.  It also charges my htc phone, but very inefficient.  Draining a panasonic 2900mah down to 3V (it seems to pretty much stop drawing current at 3V), it probably only charges it to 90%.  I believe the battery in the htc phone is only ~1500mah; so its pretty inefficient.
I'm interested in tests to see how the USB output performs for this light.  This might be a handy travel charger/flashlight.
Also what are the medium and low outputs for this light?  having trouble finding that information.
A blog on keychain gadgets, pocket tools and more:
http://keychainpockets.blogspot.com/
benckie
benckie's picture
Yes the usb on the xtar wp2 II stops at 3 volt and struggles to charge an iphone 4.
Richie086
Richie086's picture
Since some are using the xtar wp2 II that has to plug into an outlet, then connecting that to cigarette lighter adapters, this Wagen Tech AC Adapter that I use is another fantastic item I'd be lost without.  I purchased mine about 6 months ago from Walmart, which was the best price around.  After using it for numerous projects, I don't know how I ever did without it.
My personal uses for it in the house are as follows:
Software updates for my Beltronics GX-65 radar detector.
Software updates for my GPS (Garmine Nuvi 255W)
Programming my Marine GPS (Raymarine A65)
Basically I use it to power any automotive item that plugs into a cigarette lighter that I need to use for extended periods of time.
http://www.walmart.com/ip/Wagan-5-Amp-AC-to-12v-DC-Power-Adapter/10928407
Update for Wagen Power Adapter - I also use it to rechage the battery in my Garmin Nuvi 255W prior to going on a trip so the cigarette lighter cord isn't necessary to use.  I don't like wires strung over my dashboard in the car, so this is just another convenient use for it.
Richie
BetweenRides
Thanks for digging those links up. That was a good find.
Richie086
Richie086's picture
Just an IPAD2 charging update:
My wife was going to recharge her IPAD2 this morning,  she said it was completely discharged.  I removed the Redilast 3100's from the USB charger flashlight since I need them for the SRKing and didn't want to age 3 of the 4 cells.  So I tossed in my 3 Redilast 2600's fully charged to 4.2v each.  They were able to recharge the IPAD2 up to 84% before the battery protection circuit kicked in and stopped charging.  To get the IPAD to 84% required about 2 hours 45 minutes.  I'd have to assume had I left the 3100's in it, it may very well have fully charged the IPAD.  I'm pretty impressed since the Redilast 2600's put out more power than the NewTrent portable charger we have.
Richie
benckie
benckie's picture
Redilast 2600's are good batteries in my books
Boro
Last seen: 14 hours 41 min ago
Thank you for the review.
Richie086
Richie086's picture
Your all very welcome, thanks.
I decided to attempt recharging my Redilast 2600's in the flashlight today after they were depleted from recharging our Ipad2. I tossed them momentarily into the Pila to reactivate them after the protection was tripped on all 3 batteries, and then loaded them back into the flashlight.
Keeping a close eye on the flashlight while plugged into my desktop computer's USB port, after about 5 1/2 hours the blue LED illuminated on the flashlight signifying the charge current has been terminated and the batteries fully charged. I removed the batteries from the carrier to check the static voltage of each battery to find each one was exactly 4.19 volts.
This flashlight has impressed me yet again today.
Richie
Richie086
Richie086's picture
Just a quick update.  I've been playing around with this flashlight the last few nights.  Just like my SkyRay KING, this light can run on 1 to 3, 18650 batteries thanks to the parallel carrier configuration.  The flashlight can be used to recharge 1 to 3 batteries too.
Even better now, Rather than plug the USB charge cable into my computer, I've been using my Apple 1000mAh wall charger that came with the iPod Touch, and even the 2000mAh Apple USB charger worked perfectly as well.
Best part about this, my flashlights that require 2 or 3 or even 4 18650 batteries, I've been using this flashlight to balance charge all the cells.  They always come off charging inside the light at 4.19v, whether one is being recharged or 3 of them, again thanks to the parallel battery configuration.  For the first time in well over a year, my Genuine Trustfire Flames 2400mAh cells actually have a static voltage exactly the same.
Lastly, the brightness of this light is attributed to its constant current regulated output of 2.8A (8*7135)
Thanks all for now.
Richie
