14500/AA Host*Kaidomain*
48 posts / 0 new
Lightbringer
Lightbringer's picture
Last seen: 4 hours 10 min ago
He’s wonderful.
Hank33
Hank33's picture
Last seen: 2 hours 43 min ago
Yeah looking at the flashlight comparison above it does look beefy. That’s ok with me. I like the simplistic design and ease of modding. Too bad no other colors though.
I also contacted Simon about the 15mm pcb. Hope he’s around today so I can bug him some.laughing
hodor
hodor's picture
Last seen: 7 hours 11 min ago
Are there any good alkaline/NiMH-only drivers with decent mode spacing and low moonlight / firefly that would fit this host?
buck91
buck91's picture
Last seen: 1 hour 40 min ago
Few and far between. Banggood is about the only source I’ve found for low voltage boost drivers. Haven’t pulled the trigger yet so I can’t comment on quality. Let me know if you find a good source somewhere.
Barkuti
Barkuti's picture
Last seen: 4 hours 52 min ago
So much talk about the host, yet Hank33 “forgot” to link it in the opening post:
http://kaidomain.com/Flashlight-DIY-and-Tools/diy-flashlight-shell-or-flashlight-host/S028651-95mm-x-21mm-DIY-LED-Flashlight-Host-Black
I have also noticed an S3 21700 host, available in black, desert sand and purple:
http://kaidomain.com/Flashlight-DIY-and-Tools/diy-flashlight-shell-or-flashlight-host/DIY-S3-21700-LED-Flashlight-Host-126mm-x-27mm
I have an S21A grey host on the way home from Simon, and I'm not gonna say I want to change it LoL but… Facepalm
Nice to know Simon has weird ∅15 mm MCPCBs for this, he also lists these 3030 reflector gaskets for ∅9 mm hole, whereas 3030 reflector gaskets for ∅7 mm hole are listed at Kaidomain…
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
Hank33
Hank33's picture
I know Sofirn sells just the driver for the SP10S which is also a AA/14500 host. The there's this but I don't think it's got moonlight/firelfly mode.
gchart
gchart's picture
Last seen: 1 day 12 hours ago
Warning, the SP10S is an e-switch light. It’s driver will not work for clickies like the T2.
I’m still waiting for the parts to arrive, but at the recent request of a BLF member, I put together an extremely basic 1-mode 17mm low-output boost driver. I think the T2 is the target host. Kinda “joule thief” style. Intention being simplicity and efficiency with the ability to drain a cell. I hope for the parts to be in within the next week or two. Can’t wait to test it out. If all goes well, I’ll publish the Oshpark boards and can also build a few on request.
Hank33
Hank33's picture
Thanks for the e-switch warning. Smile yeah if you can build some drivers for these host that be coo! Seems there lots of drivers galore for 18650 and up style flashlights but for AA/14500, not so much? Crying
MascaratumB
MascaratumB's picture
Last seen: 5 hours 5 min ago
That would be great Wink
Keep us informed about it please Wink
hodor
hodor's picture
Are there any 14.5/15mm to 17mm driver adaptors? Thinking of using Rey’s Lan/pineapple driver in either this or an AA tool. I think the tool driver is 15mm? Not sure if Rey’s driver would fit.
Blahblahblahhuh
Resurrecting a dead thread, as I’m considering buying some of these hosts to mod.
I want to make a single emitter Lh351d with either a MTN-DDm 17mm FET+7135 or 17mm DrJones driver (using just 14500s).
With this build, I’d like to use the FET channel, as long as it won’t destroy the emitter. And I’m wondering whether I need a DTP MCPCB to accomplish this.
I can’t find a 14mm DTP from mtnelectronics, will this 12mm be way too small to use?
http://www.mtnelectronics.com/index.php?route=product/product&path=63_65...
If I use this 14mm non-DTP MCPCB from Illumn, will I be in danger or overheating the Lh351d?
https://www.illumn.com/leds-drivers-optics-mcpcbs/led-mcpcbs/14mm-xp-ser...
I assume I will have to file down the widths of either of these MCPCBs to around 1mm, as well. Is that a correct assumption?
Finally, is Kaidomain a decent source for some “dogfarts” Lh351d? I can’t find any other source at the moment…
Gunga
Gunga's picture
Last seen: 10 hours 26 min ago
This will answer an old question here. I can confirm the ReyLight driver is too tall for a Lumintop tool AA pill. Too bad.
Lightbringer
If you only need to shave 1mm from the 14mm board (I imagine ½mm around, actually), then unless the 12mm would be sitting precariously on the narrowest of ledges on a dreaded “hollow pill”, the 12mm board should be fine.
I ordered a bunch of weirdo small sizes from… think it was LEDsupply… for just such occasions. Plain Al, not DTP, but small lights aren’t meant to be screamers anyway. LOL
Is MTN still in bidniss, even? Haven’t heard anything from/to/about him in ages.
MascaratumB
I would say that DTP is better than non DTP, be it copper or aluminium.
I recently fried a LH351D on a non DTP board in my Tool AA.
BUT, beside the thinness of the board and pill, I used a Vapcell H10, probably the cell that will deliver more “juice” in the 14500 kingdom.
So, in case you use non DTP boards, don’t use that kind of cell. Use the Vapcell ICR14500 (Gold), which will not power up the FET to it’s top.
Or, use a layer of copper, brass or aluminium below the led board to help on heat dissipation.
Blahblahblahhuh
I guess I’ll buy a 12mm and see. Or try to find a DTP 14mm MCPCB to file down just in case.
I just bought some Convoy C8+ hosts from him to build so he seems to be in business!
Is this just a “spacer” that I buy in the correct diameter? I don’t have the tools to make my own at the moment. Or the skill, I should add.
Your experience makes me think I should be going DTP MCPCB, or with a copper spacer, regardless.
MascaratumB
I would say that DTP is probably better, specially if you don’t have tools or materials to make that “layer”.
If you chose the Jaxman E3, you can use the 16mm DTP MCPCB without issues Wink
Blahblahblahhuh
Thanks y’all! I’ll probably go E3 on this route.
But will buy some cheaper KD hosts for the future.
