can you please make the AUX LEDS “USABLE”. like we can turn it on to use as reading light or whatnot… right now the aux leds are only for “decoration” purpose for a lack of a better term…
pls make it usable with its own mode… click and hold from off maybe. just an example… just make it usable
thanks… that changed my mind… haha… i was just thinking about the idea to use the red leds to “preserve” night vision like in the nitecore ec11. but then again the ec11 does not have a moon mode like the d4, which makes the red leds somewhat useful… but your point is spot on… no need for the aux leds as illumination anymore as there is a moon mode…
I've had my D4V2 since last summer and have EDCed it since then. I've put on various different firmwares since I got it and noticed a newer one 2020_03_18. I put it on this morning and verified that's the version installed via 15 clicks. After reading about setting the aux LEDs to show voltage the last few posts, I've decided that's what I want when my light is off. Previously, I had red set for off and blue set for lockout to distinguish between the two.
Maybe I'm doing something wrong but I never get just blue even with the voltage of my battery showing 4.1 via 3 clicks. The aux just show blue and red on at the same time with the light off. I stopped holding on 7 clicks when it seems rainbow is done and that is the result (tried it numerous times). I get red/blue aux on at the same time. I thought there were just 3 colors for the voltage- blue, then green, then red as voltage drops over time.
Oh, right. When I merged the Noctigon K1 code, it also merged in the higher-resolution voltage colors. From high to low voltage, it goes: white, purple, blue, cyan, green, yellow, red, off. But “white” is unlikely to happen since it’s only for an over-charged cell. So really, it follows the colors of a rainbow as voltage drops.
Excellent and thank you for the explanation! Will this info make it into the text user manual and graphical cheat sheet at some point? I have to refer to those every time I flash new firmware because I have CRS. ;)
Hey, TK and everyone else! I am new to the world of enthusiast flashlights and to this forum, and my research on a flashlight that would be pocketable, versatile, and fun lead here after a month or so. I am excited about this flashlight, and I have been enjoying skimming this thread (I’m only up to page 30 so far). I have loved flashlights since I was a child, but never bothered to do much about it until now.
The reason I am posting is that I have a safety question about the flashlight for anyone who is educated in this: what happens if a standard, low-discharge cell (4.4A, for example) from a laptop is used in this flashlight? Would the flashlight over-stress the cell and possibly cause it to fail, overheat, or explode? Or would it merely limit the ramping and turbo based on the cell’s limits? Would the max ramp and turbo merely be limited to around 700-800 lumins? If so, by what mechanism is this achieved? I have read that vapes can cause low-discharge cells to burst due to trying to pull more amps than the cells can safely deliver. That is why I am concerned about the flashlight.
The cells I intend to use are Samsung ICR18650-22F from an aftermarket laptop battery. They are unprotected and have a max discharge of 4.4A from what I have read.
I do not care about ultra-brightness right now (I may later, just to show off). I just want a fun and functional flashlight for tasks that will rarely require more than a few hundred lumins. I do, however, want to find a use for the nine 18650 cells I harvested that still hold 88% of their capacity. That was actually what motivated me to start shopping for a new flashlight. I have an old single-AA Fenix LD12 that mostly serves my needs, but I would like a brighter flashlight. On a partly depleted alkaline cell (I know I’m supposed to use NiMH) it can only achieve 27 lumins (mode 2 of 4, 4 being 115 lumins). These cells gave me the motivation to finally get a better flashlight, and one based on a Li-Ion cell.
I would assume that the Fenix fails to achieve its max brightness due to the low voltage of a partly depleted AA cell. All modes the cell cannot power simply output the same brightness. So eventually the upper three modes are equal to the first mode in output. There must be something in the circuitry that causes the flashlight to output a brightness equal to the previous mode rather than a partial step up. I do not know enough about Li-Ion technology or electrical engineering to know if what is happening in the Fenix and its alkaline cell would also happen with a hot rod flashlight and an 18650 cell, especially since the limitation here is not primarily voltage, but amperage. And alkaline cells are not known to burst when stressed. Li-Ion cells are. EDIT: I just went for a walk and found that the Fenix actually does do partial step ups. I never noticed that before. I put a fresh cell in and the step from 2 to 3 is much greater than with the depleted cell.
By the way, I’m planning to get the Nichia 219C 5000K 83CRI emitter. I want to experience this high CRI, neutral white the enthusiasts rave about, and avoid the green tint that reportedly plagues the SST20. I would try the 4000K 219C if it were available. But maybe that would seem too warm for daytime use. I will be using this flashlight for all purposes, night and day.
In the regulated modes (up to ~140 lm or so), almost any li-ion cell should be fine. It only draws up to 350mA in those modes, and they’re typically bright enough for daily use.
In moderate levels above that, most cells should still be fine.
It’s only really at turbo and really high levels that weak cells become an issue. It can potentially cause cells to overheat and become unstable or damaged. But it can’t sustain those levels for long anyway, due to heat, so it ramps down to a more reasonable level within the first minute.
If you’re using questionable batteries, I’d suggest avoiding turbo. Or at least, probably don’t use it for more than a few seconds at a time. Lower modes should be fine though.
That’s nice! May I ask starting which firmware version/date did it have this feature?
Also, does this feature only apply to the Noctigon K1, Emisar D4v2 and Emisar D4Sv2, at least for now?
Or do any other Anduril flashlights have this aux-LED-voltage feature?
I think the first builds with that were 2020-03-18, aside from the K1 which had it since launch. It applies to anything with a “voltage” mode for RGB aux LEDs… which currently means just Emisar and Noctigon products.
I just updated the firmware on my D4V2 to 2020-03-18. Is there any documentation that has all of the changes that have been made recently (like the 15 click to get the firmware level) ?
Are the D4V2’s Aux emitters wired/coded in such a way that they will not vampire a cell past typical LVP? I remember TK confirming way back when that the original D4S’s aux had no intelligence with battery voltage, but I was hoping that the D4V2 did with the voltage aux setting.
