I ordered before the 3rd batch was split into different SKUs. I left a note on my order but I’m not sure if I will get the new firmware or not at this point.
There are four options under “size” category. I think they’ve just added the two (new) options, as when I did my order two days ago, there were only two options: LT1 alone and LT1 kit. I had to leave a message noting that I need the latest version.
Edit: First post, so hi guys!
They are both labeled LT1.
The newest ones have updated driver hardware to make it compatible with a few more USB-C chargers.
If I understand correctly, that is the only difference.
If you use the included charging cable (USB A to C), it doesn’t matter. With the included cable, it should work with any charger the cable fits into.
I’ve just received mine 2 weeks ago and i’m very happy with it and use it every day, I specially love reading a book in a dark room with a 2700k headlamp and using the Lighting storm mode paired with rain from https://asoftmurmur.com/ !!! 8) at least it’s not collecting dust like my useless and boring Q8. cheers
Yes. But I still can not understand what the various versions are.
Can you not list the the actual information?
The answer continues to be information free.
I think they meant ‘firmware’ and ‘latest’ instead of fireware/lasted…… but I could be wrong. At least what Tk said.
@alternety, on the LT1 page of the sifirn website there are 4 pics of the lantern. The first 2 are the old version: 1st without batteries, 2nd with batteries.
The second set of pics is for the “new version”: 1st pic is without batteries, 2nd pic is with batteries
New version: Has two resistors added to the driver, to improve compatibility with some USB-C chargers.
Old version: Doesn’t have the two extra resistors.
That’s it. That’s all there is to know.
Although my first batch LT1 is still traveling the world: Can we get a separate USB-C to USB-C charging board to replace the original one?
If you don’t mind shipping from China, you can order it at the end of this month on amazon. But if you want to ship from amazon warehouse, you need to wait longer time.
alternety:Yes. But I still can not understand what the various versions are.
Sofirn:There are old fireware and the lasted fireware in batch 3. If you want to get LT1 lantern with the latest fireware which supports USBC to USBC and USBA-USBC charging, please tell us in your order.
yes
alternety:But which is which and what differences are there.
The one labelled New-LT-1 is the latest, with the C to C charging and latest firmware.
Back read a couple pages or 20 about the firmware changes, because it isn’t that new.
:+1: New-LT-1 is the latest which is compatible with C-C charging (C-C charging cable & charger not included)
Kevin Z: Sofirn: Kevin Z:Is the $49.99 price as standard now or is it going to go up?
We will consider it when LT1 restock.
Thanks :+1:
Any idea if & when a version 2 will be in the pipeline?If you don’t mind shipping from China, you can order it at the end of this month on amazon. But if you want to ship from amazon warehouse, you need to wait longer time.
Anyway of buying it off of Amazon for the same price as it is on the Sofirn store? It’s $20 more on Amazon at the moment.
Sofirn: Kevin Z: Sofirn: Kevin Z:Is the $49.99 price as standard now or is it going to go up?
Thanks :+1:
If you had particapated in our groupbuy, you would get it with same price.
USB-C to USB-C charging board? Do you means new driver?
Those who have expired discount code, if you need new code, please PM me.
CrashOne:Although my first batch LT1 is still traveling the world: Can we get a separate USB-C to USB-C charging board to replace the original one?
If that part is on the driver: Would be nice to be able to purchase a separate new driver
adirondackdestroyer: Sofirn: Kevin Z: Sofirn: Kevin Z:Is the $49.99 price as standard now or is it going to go up?
Thanks :+1:
I did. But now I want to buy one for my brother for his birthday next month.
Sofirn: CrashOne:Although my first batch LT1 is still traveling the world: Can we get a separate USB-C to USB-C charging board to replace the original one?
Would you mind seeing if USB-C to USB-C charging board is on the driver go to https://sofirnlight.com/driver-of-new-lt1-p0080.html
