How much would be the cost, bare unit, and kit?
Interested in 1 piece LT1M-Mini Lantern
Thanks DBSAR for developing a mini lantern as well.
Interested in 1 please
Please add me to the list for 3 lanterns. Thank you.
Additions to the interest list since post number 429:
Post# / Added / User Name
431 / 03/23/2020 / nightshark
433 / 03/24/2020 / bobkido
436 / 03/27/2020 / slowtechstef
437 / 03/29/2020 / creynolds
438 / 03/29/2020 / KnotSoMuch
interested in 2 please
Interested
Interested in 1
I’m interested in two please.
Count me in please
I doubt that’s known yet
I apologize if this has already been discussed, but I just watched the video and it looks like the top, lantern portion either is or easily could be threaded on to the flashlight portion, such that it could be easily removed. And the remainder of the flashlight still has an optic and everything so that it could be used like a normal flashlight with the lantern portion removed. If possible, that dual functionality would certainly make it a more appealing option for backpacking purposes. And I think it’d also be a great selling point for those who might not see themselves using a dedicated lantern that often but would appreciate getting a solid light that also offers lantern functionality should it be needed. Everything could still be optimized for lantern purposes while leaving a solid flashlight, right? Is that or could it be part of the plan?
To take that idea a step further, maybe the stability plate for the bottom could have a slightly raised area to center the light that the lantern portion could also screw into, so they could be easily stored together when the light is being used as a flashlight. It looks like the lantern portion goes around, rather than inside the bezel, so the inner diameter of the raised area could match the diameter of the bottom of the flashlight, while the outer matches the bezel and has a couple threads for the lantern. But it could potentially also work with the inside being threaded if the lantern portion attaches inside the bezel. This would also help prevent any gunk from getting into the lantern portion while it is removed.
Interested in 1 piece, thanks!
Thanks Funtastic. So, I’m interested for one (for now) please.
Imho the above are excellent suggestions.
Since the optic is already inside the device, no good reason seems to exist for the diffuser to be non-removable, unless a decision has been made to deliberately preclude a dual (lantern & flashlight) use possibility.
It would be good to get a definitive answer as to whether the diffuser will in fact be removable, unless the issue is taboo for one reason or another.
I’m definitely interested in two (2) of the LT1M!
Interested count me in
Interested in 3
Additions to the interest list since post number 438:
440 / 03/29/2020 / Itsme
441 / 03/29/2020 / write2dgray
442 / 03/29/2020 / iwandutchy
443 / 03/30/2020 / Chappy
444 / 03/30/2020 / JorisFRST
447 / 03/30/2020 / Julez
448 / 03/31/2020 / Wave180
450 / 04/02/2020 / Nismo
451 / 04/02/2020 / billy
452 / 04/03/2020 / ulfm1
I’m in for 6
