The only Kershaw that I have is a Double Duty (the one with 2 blades and the wood handle scales) – great knife! I like it’s traditional look, light weight and one hand opening blades.
Finally got a Bareknuckle, takes a little break in time, but now the action is incredible. From the factory the pocket clip was off center, but easy to adjust, and the grind is not even near the tip which is not a deal breaker but I expected better from the USA factory. Very lightweight and thin for a long knife with good ergos, really like the sleek aluminum handles and ZT like appearance.
I have the non a/o natrix also a nice knife, always been a big fan of assisted Kershaws but it’s nice to have some bearing models, they seem a bit more fun to fidget with.
Brother knife should make a re-interpretation of that Double Cross/ Double Duty series.
Traditional shape with one hand opening, I like that a lot.
A Double Duty sized one with the blades of the smaller Double Cross with their fine carbon fiber, I guess that would be mine.
Or they just make the Hungarian shape of the fejesgörbe like Spyderco did but without the hole in the blade
Some one should bring back the concept. It’s real nice to have a traditional styled pocket knife that is lightweight with one hand opening locking blades. I actually like the Double Duty blade shapes better than Double Cross, having one blade with a rounded tip often comes in handy.
I can imagine that the spey blade can be useful, they are just darn ugly for me.
A clip point blade or at least a longer belly would do it better for me
But a traditional with one hand opening is really something, the Case Trapperlock that I got a while ago was a total fail though.
Better if people who know liner locks like Kershaw do that.
For Kershaw, one of my favs is a de-assisted Blur in S30V (pictured in the middle below).
Not a big fan of AO knives, and the Blur is excellent when de-assisted. Action is like buttah when tuned.
I can open it faster than the AO spring, and also have the capability to close it one-handed as well.
RC I hope you don’t mind me posting this in your thread - if you do lemme know and I’ll delete it.
I want to make some knife handles, I have made some before, many years ago that turned out well on a Damascus blank.
This is going to fit my rather good quality, but terrible looking stanley knife -
I am thinking of using these - has anyone else any experience of using them? Luminous Knife Handle Noctilucent Marbled Carbon Fiber Resin
I haven’t used this particular material but I’ve worked a lot with CF.
The dust from it is extremely dangerous for your lungs, so it’s best to work with it on a machine with exhauster and of course only while wearing a mask (and goggles and gloves). The only way to prevent this would be working at the tap with the water running. This is good for a final polish with MicroMesh for example.
When you do rough grinding, try not to overheat the material. The fibres are very good at storing heat but the epoxy with melt at the ground area.
Also don’t be surprised, the glowing material (strontium aluminate) with start to glow from any enery source, so it will glow when you grind it.
Rather funny effect when you see it the first time
