As Lexel says, the latest LT1 driver should have 0Ω resistors connecting AMCs 4 & 5 as standard. You can check that with a multimeter - you should see a short-circuit between the ‘4’ contacts, and another short-circuit between the ‘5’ contacts, even though they’re not soldered.
If any of you have a new-model LT1 and a multimeter, please try it and let us know for sure
The 0Ω resistors make it easier for Sofirn to manufacture and do quality control, because they’re less prone to human error compared to manually soldering contacts with a soldering iron.
If you want more output from your LT1, you still need to solder the ‘6’ contacts together yourself. If you want still more output, you need to solder the ‘7’ contacts together as well.
If you want less output, you have to unsolder the 0Ω resistors next to the ‘5’ contacts. If you want still less output, you have to unsolder the 0Ω resistors next to the ‘4’ contacts as well.
If you change your mind afterwards, you can restore higher output by soldering the ‘4’ contacts together again, and then the ‘5’ contacts together again. You don’t have to worry about saving the 0Ω resistors, so it’s not a problem if you destroy them when you unsolder them.
The new driver also includes USB-C charging resistors to make it compatible with USB-C to USB-C charging.
If any of you get a new-model LT1 and have a USB-C to USB-C charging setup, please try it and let us know whether it works
