SOFIRN would love to add the info to product page or to the manual when new batch is made. I need to confirm, which is the exact information need to be added?
Received the BLF Q8 Anduril light today, with the diffuser. Quality seems all there, as usual for the many Q8's I've bought and sold/gave away. This one is brighter than the classic Q8's, measurable not that noticeable, about 150 lumens more with bypasses. I took an older Q8's battery assembly and ran it on the new Q8 Anduril and it fit and ran fine.
The difference in LED's/optics though has some pros and cons. Didn't measure throw, but the new light has a well defined hot spot while the older models have got some blurriness in the hot spot definition - this seems to be an improvement. However the tint -- the new Q8 Anduril clearly has a green halo around the hot spot while the old Q8's have a nice white blend. Side by side it's very noticeable. The new LED's sure do appear to be the classic XPL's, not XPL2's. I got a Q8 with XPL2's so know what they look like. I can't see any differences in the reflector or glass. The glass still is non treated, no color, and the reflector cups appear to be same size, same shape from what I can tell by eye.
Without any direct testing, the new XPL's appear to be more like W2 binned 3C's, possibly 2C's or 2B's. The difference is just too great to be a bad batch of 3D's. We picked 3D's specifically because of their superiority over 3C's because of the green in 3C's.
The tint is certainly a big disappointment, specially when the light is listed as having 3D's, and Sofirn seemed to do such a great job in sourcing that tint over the years.
Also what was weird is the light is stamped with "BLF Q8 Anduril" but still comes with the two Narsil manuals, one for folding up into the tailcap. It definitely is running Anduril though.
The necessary info is listed in points 1 and 2 in that post — a message that the product uses copyrighted code published under the GNU Public License v3 (GPLv3), and a link to the source code.
The place to put the information is discussed below — ideally in both the paper manual and on the manufacturer’s page for the product.
The product uses copyrighted code released under the GNU Public License v3 (GPLv3).
To know about the exact source code used in the product, please go to https://tiny.cc/TKAnduril
I know it can seem strange at first, including a license notice with the product… but it’s getting more common every year as more products are made with free software. At least it’s easy to do and costs no money.
Does anybody know where I can purchase the needed equipment to flash Anduril on my BLF Q8 (currently on NarsilM) and update the Anduril of my Sofirn Q8 and LT1 Batch 1?
What sets the Q8 apart from the big floody lights is two things:
a) the price. It is relatively cheap for a light with this output, and you get a robust quality flashlight
b) it is relatively throwy. Because the 4 XP-L’s (or XP-L Hi’s in the Sofirn Q8) are driven hard, the hotspot is pretty bright, not far from some dedicated throwers even.
What happens if you make it 9xLH351D is that the dies are larger, the reflectors are smaller, and the individual leds are driven less hard. In other words: it will be a very floody flashlight, and there are already many of those. But if the price is good it will still be attractive compared to other floody 10K lumen lights. and the 90 CRI of the LH351D makes the light quality stand out too.
To maintain a bit of throw you could also consider an option for 9x SST-20 leds (my preference would be 3000K 95CRI). You get a bit less light but a brighter hotspot.
Dunno, there are quite a few big LED count flooders in this general size. I'd like to see a thrower head w/SBT90.2, ~80-90 mm head diameter, that fits the 4P battery shell of a Q8. Same driver would work.
I have an LK04 XHP50.2 quad - it's 3 cells but still a lot in common to the Q8 form factor. There have been Q8 quad XHP50.2's mods done - it is a nice upgrade but I'd consider a bigger, wider head and max out the reflector cup widths to boost throw - don't think there's quad XHP50.2 lights out there in the 60-70 mm head size . Like djozz said, the Q8 offers that nice combo of flood and throw and flooders are common already.
Still like the single LED thrower head though - actually a bump up to 90-100 mm head diameter would be ideal. The 4P batteries and the heft of the Q8 design would make a decent host for a SBT90.2.
So a quad XHP50.2 Q8 in NW if possible, little bigger head, bigger reflectors, and a even larger head for a single LED like the SBT90.2. Those two options would be great! I realize of course the cost/price goes quite a bit up.
Let’s try the 9x LH351D… This would be a bit similar to the Fireflies ROT66 gen 1 which has 9x LEDs, but Q8 has bigger body so should be able to handle more heat.
4x XHP50.2 = there’s the Haikelite HK04 that uses 4x XHP50.2, not sure how well it is though… But XHP50.2 seems to produce some “artifacts” in the beam, so I’m not sure if 4x XHP50.2 on the Q8 will also have artifacts or not… 4x XHP50.2 would also be a floody light, wouldn’t it?
I wonder which will be more floody, 9x LH351D or 4x XHP50.2?
