I second that request ! :laughing: :heart_eyes:
This is my only grip with the SP10S.
i would buy the SP10S V2 for sure and Later the Andúril version as my 4th sp10 :sunglasses:
ditto on the “Pretty please!”
YESSSS! Just picked up the LH351D SP10S and its a nice little light. Granted, I strongly prefer tail clickies but I’m getting used to this. With a nimh its nice that it always comes on in low, too bad you have to cycle through all the high modes to get to moonlight, though.
Interested.
interested
I ordered a driver for the sp10s to see what chip was on it without tearing my light apart.
I was hoping it was something we already had a fancy .hex file for.
Well I dont know squat about micro controllers but I know most of the hex files in the repository are for attiny chips.
This one is marked
12LF1822
SN1912
STA
It is an 8 pin chip.
Datasheet is available online.
Maybe someone can do something with this and we can flash our own.
OH BTW the driver is one of the T shaped 2 board configurations making the chip inaccessible to a programming clip.
there are multiple connections on both sides of the joint of the 2 boards so it would be difficult to separate them.
Still not easy but I think better to solder prog. wires to the pins individually.
ETA: minor correction
Interested for 1!
Yes I hope.
interested
Interested
Yep, I am interested, depending on what the features are. Only problem is, I want it now!
Interested
Also interested in this
Interested!
TK, or I, can't do much without a driver. So the driver is the first thing we need developed, and we need a fairly good electronics designer for this.
Of course loneoceans with a lume1 variant would be great for this.
Need to have the switch on a right angle board. There is actually a little slot for the switch board in the body, at least as designed.
Factory driver.
https://imgur.com/lM312oD
INTERESTED!
There's some good news - Sofirn contacted me to order the stock SP10S to have as reference. I find this to be a step in the right direction, so hoping the ball will start rolling on this project! I also recently picked up a ThruNite T10T V2 on the special deal offered on Amazon, which is a similar AA light in that it takes any AA size battery, e-switch with a decent UI, similar design.
The UI of the T10T V2 is very similar to Anduril/Narsil:
From OFF:
From ON:
I prefer the click/hold to switch brightness levels, and the 1 click to turn it OFF. This matches up so well with Anduril in non-ramping mode. The current SP10S uses click to cycle thru levels, click/hold to turn OFF, though the SP10S has more levels/modes.
Great news!
Staying tuned!
