Edit drivers are tested and running in multiple lights. They work great
Couple new FET+1 drivers I’ve shared:
21mm on board e-switch and 5mm AUX LED
designed specifically for an ultrafire AT-008 but if you leave off the switch and 5mm LED its a standard size (actually the switch placement should work in several other lights too, just the 5mm LED is unique)
“17mm FET+1 v2 (first version rendered right but wernt fabbed right, that’s fixed now)
Probably even less use for this one since it uses a switch daughter board but again, if you wire your own switch it is a standard size.
Both use the GT_Mini target for building FW (the 17mm Sc02 can also use the D4 target since it doesn’t have an AUX LED).
Misiek_86
(Misiek_86)
November 4, 2018, 3:42pm
1763
only here is under one AMC, would you give advice so that you can handle up to 8 AMC? as it is in convoy s2/s2+
Niko
(Niko)
November 4, 2018, 5:49pm
1764
Maybe is emisar d1 driver somwhere?
HiTiT
(HiTiT)
December 24, 2018, 7:10am
1765
Big Thanks to ” Cereal_killer”:http://budgetlightforum.com/user/8679 !
Helped me with 29mm and 30mm contact boards.
Original quote from here :
Agro
(Agro)
April 11, 2020, 8:51pm
1766
Thank you Rufusbduck for this thread. I’ve been looking for 10mm drivers and it let me found notably more than I thought was available.
Tom_E
(Tom E)
April 12, 2020, 2:57pm
1767
Pretty old thread, but used to be quite active and was the central main thread for our BLF drivers. Lots of famous names here...
MRsDNF
(MRsDNF)
April 12, 2020, 9:34pm
1768
Yep. Couldn’t agree more Tom E.
Skylight
(Skylight)
April 13, 2020, 3:29pm
1769
Interesting thread. Does anyone know where I can find boards for lighted side switches on Oshpark?
Skylight
(Skylight)
April 13, 2020, 5:30pm
1771
Perfect, thank you Chatika vas Paus. Those are the ones I have been looking for.
FET+1 D4 layout with indicator led support on Pin3. Anduril compatible!
15mm
Tom_E
(Tom E)
August 23, 2020, 11:46am
1773
Been looking this over but can't see pin #2 connected to a pad for the switch - did you run out of space for it?
I know there's not much room on a 15 mm, to say the least.
DEL has a good write up on his 17 mm FET+1 here . He writes these are the mandatory parts:
C1 10 uF
D1 diode
R3 100K ohm to eliminate unintentional flashing during mode changes
R5 4.7 ohm to eliminate unintentional Vcc boosting during PWM
C2 and the R4 47K ohm resistors can be eliminated
Right, no space for pad , just connect straight to pin. Why not?
Scallywag
(Scallywag)
August 24, 2020, 11:03pm
1775
For 15mm, we make compromises
Might make it a pain to re-flash later
Tom_E
(Tom E)
August 25, 2020, 12:14pm
1776
Sure, I've done it before.
lumenzilla
(lumenzilla)
August 25, 2020, 3:48pm
1777
I tried to (quick) read the entire post to find FW3A switch board or contact board but couldn’t find any.
Is it still a rare part?
Tom_E
(Tom E)
August 26, 2020, 1:01pm
1778
Nice! I'm attempting to order from PCBWay - $5 + $8 e-packet shipping for qty 5, total $13. Decent price, no rush.
Looks like PCBWay has to do an approval on the order first. Thinking they will take PP. They also offer a ton of options - hoping the defaults are good for us.
Take 10pcs - same price ! ;))
Tom_E
(Tom E)
August 26, 2020, 1:51pm
1780
Yea, I see that now - thought it didn't work before, but I was tweaking settings.
Unfortunately after the review, they raised the price from $5 to $15. Dunno - I'm re-submitting with qty 10, maybe I made a mistake before.
