This may be caused by a high internal resistance somewhere, or it may be a driver problem.
So, to amend the mistake, the post title should be changed… or not?
Tldr;
So, is it possible to buy s21a with biscotti?
oweban:So it’s a Biscotti clone, but not Biscotti. And given that information is being withheld, I can’t modify it and flash my own version like I’ve been able to with Biscotti (custom modes etc). Thanks, no thanks. (I’d strongly suggest using another name - even “Biscuit (Biscotti-clone)” or similar. Because it’s not the same firmware.)
This was my mistake. At first, I thought that the driver manufacturer used the biscotti code. Later, I realized that it was the code he wrote himself. I havent given a name to this, so simply call it 12 groups sst40 driver
Simon - no harm intended. No worries. We are all glad you are involved so much with us and listen. We just like to get the specifics.
That's all true - your listings never said Biscotti.
Again, you with the Convoy brand have been a long time major part of BLF - "quality at budget prices", could be your motto and BLF's.
Simon Mao: oweban:So it’s a Biscotti clone, but not Biscotti. And given that information is being withheld, I can’t modify it and flash my own version like I’ve been able to with Biscotti (custom modes etc). Thanks, no thanks. (I’d strongly suggest using another name - even “Biscuit (Biscotti-clone)” or similar. Because it’s not the same firmware.)
That’s all true - your listings never said Biscotti.
Again, you with the Convoy brand have been a long time major part of BLF - “quality at budget prices”, could be your motto and BLF’s.
I second that.
Myself I’m not a fan of Convoy lights because they tend to be too bulky for my preferences - but nevertheless there is no brand I respect more than Convoy.
Are the groups the same as biscotti? Noticeable PWM?
hodor, SST-40 drivers are regulated linears. Current is regulated by tuning the MOSFETs' VGS with the onboard sense resistor voltage drop feedback. PWM is thus senseless.
Oh right, wasn’t thinking, thanks.
Tldr;
yes, the driver is in production
Thanks, no thanks.
I havent given a name to this, so simply call it 12 groups sst40 driverSo, to amend the mistake, the post title should be changed… or not?
ok
Thanks
it’s non-pwm,friend
Tom E: Simon Mao: oweban:So it’s a Biscotti clone, but not Biscotti. And given that information is being withheld, I can’t modify it and flash my own version like I’ve been able to with Biscotti (custom modes etc). Thanks, no thanks. (I’d strongly suggest using another name - even “Biscuit (Biscotti-clone)” or similar. Because it’s not the same firmware.)
I second that.
I 3rd that
I love convoys whole attitude , Simon your great , and the convoy store I return to often to get drivers and leds for other projects , I have a few c8s and s2 , c8 is good for forests and fishing
S2 with 350 tube is so nice , I’m gonna order some more 350 tubes , and a triple in a 350 size is perfect
Keep up the good work
Simon, will the driver for xhp35 and single cell also be available with Biscotti?
Barkuti:… It is the Biscotti drivers of ∅20 and ∅22 mm which are set for later.
I’m also interested in these… 20 and 22mm, better if they are 6A (or more).
… another name - even “Biscuit (Biscotti-clone)” or similar. Because it’s not the same firmware.
I am still very interested in those “Biscuits”…
+1
In theory, it can be done, but the demand for this driver is very small, and I cannot make a lot of goods.
If you ask me convert all drivers to Biscuits UI.
I need all sizes and XHP35 driver to run GT-FC40
I would love to see a single cell XHP35 driver with 20mm or smaller diameter. 12V boost drivers less than 22mm are difficult to find.
I’ve been waiting for ages for a single cell XHP35 driver (or boost drivers in general) without mode memory.
Unless reduce the output current, such as 1.5A
