I second that.
Myself I’m not a fan of Convoy lights because they tend to be too bulky for my preferences - but nevertheless there is no brand I respect more than Convoy.
Are the groups the same as biscotti? Noticeable PWM?
hodor, SST-40 drivers are regulated linears. Current is regulated by tuning the MOSFETs' VGS with the onboard sense resistor voltage drop feedback. PWM is thus senseless.
Oh right, wasn’t thinking, thanks.
Tldr;
So, is it possible to buy s21a with biscotti?
yes, the driver is in production
Simon Mao: oweban:So it’s a Biscotti clone, but not Biscotti. And given that information is being withheld, I can’t modify it and flash my own version like I’ve been able to with Biscotti (custom modes etc).
Thanks, no thanks.
(I’d strongly suggest using another name - even “Biscuit (Biscotti-clone)” or similar. Because it’s not the same firmware.)
This was my mistake. At first, I thought that the driver manufacturer used the biscotti code. Later, I realized that it was the code he wrote himself.
I havent given a name to this, so simply call it 12 groups sst40 driverSo, to amend the mistake, the post title should be changed… or not?
ok
Simon Mao: oweban:So it’s a Biscotti clone, but not Biscotti. And given that information is being withheld, I can’t modify it and flash my own version like I’ve been able to with Biscotti (custom modes etc). Thanks, no thanks. (I’d strongly suggest using another name - even “Biscuit (Biscotti-clone)” or similar. Because it’s not the same firmware.)
This was my mistake. At first, I thought that the driver manufacturer used the biscotti code. Later, I realized that it was the code he wrote himself. I havent given a name to this, so simply call it 12 groups sst40 driver
Simon - no harm intended. No worries. We are all glad you are involved so much with us and listen. We just like to get the specifics.
That’s all true - your listings never said Biscotti.
Again, you with the Convoy brand have been a long time major part of BLF - “quality at budget prices”, could be your motto and BLF’s.
Thanks
it’s non-pwm,friend
Tom E: Simon Mao: oweban:So it’s a Biscotti clone, but not Biscotti. And given that information is being withheld, I can’t modify it and flash my own version like I’ve been able to with Biscotti (custom modes etc). Thanks, no thanks. (I’d strongly suggest using another name - even “Biscuit (Biscotti-clone)” or similar. Because it’s not the same firmware.)
I second that.
I 3rd that
I love convoys whole attitude , Simon your great , and the convoy store I return to often to get drivers and leds for other projects , I have a few c8s and s2 , c8 is good for forests and fishing
S2 with 350 tube is so nice , I’m gonna order some more 350 tubes , and a triple in a 350 size is perfect
Keep up the good work
Simon, will the driver for xhp35 and single cell also be available with Biscotti?
Barkuti:… It is the Biscotti drivers of ∅20 and ∅22 mm which are set for later.
I’m also interested in these… 20 and 22mm, better if they are 6A (or more).
… another name - even “Biscuit (Biscotti-clone)” or similar. Because it’s not the same firmware.
I am still very interested in those “Biscuits”…
+1
In theory, it can be done, but the demand for this driver is very small, and I cannot make a lot of goods.
If you ask me convert all drivers to Biscuits UI.
I need all sizes and XHP35 driver to run GT-FC40
I would love to see a single cell XHP35 driver with 20mm or smaller diameter. 12V boost drivers less than 22mm are difficult to find.
I’ve been waiting for ages for a single cell XHP35 driver (or boost drivers in general) without mode memory.
Unless reduce the output current, such as 1.5A
size and output current?
id30209:If you ask me convert all drivers to Biscuits UI.
I need all sizes and XHP35 driver to run GT-FC40size and output current?
If you’re asking avout XHP35 then 22mm is perfect but this LED can take 4A without issues. And if Biscotti is available it would be dream combo.
As am reading 17mm is available and i’m only waiting for 20mm and 22mm 6000mA with Biscotti.
I have a quirk in a 20mm “SST40” driver that I recently bought from your AE store. Between modes 1 and 2 there is a bright “pre-flash”. Is this normal? Anybody else experiencing this? It’s installed in an S21a running a triple XPL_HD from an LG M50.
Is this the biscotti clone? Did you work out the cause / fix?
This is the standard 4 mode 20mm SST40 driver. It actually does it every time entering mode 2. That means stepping through modes 1>flash-2>3>4>1>flash-2 . . . and also from off when mode memory starts it on that level. Annoying for sure but it’s in light I don’t really use much so it’s not killing me for now. Plans for it though were to go into a build for a friend once I’m able to make a custom spacer (lost access to my machine shop).
I have not found a cause or fix. Haven’t tried much though, and doubtful anything short of a re-flash would help
