Test/review of Vapcell INR14500 L10 1050mAh (Purple) 2020
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 3 days ago
DSC_2685
Official specifications:
  • Model: INR14500 L10
  • Size: 14.0*49.0mm
  • Type: Flat top
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 1050mAh (0.2C discharge)
  • Min capacity: 1000mAh (0.2C discharge)
  • Weight: Max: 22g
  • Internal resistance: Max:66mOhm (AC 1kHz)
  • Standard Charge: 500mA,CCCV 50mA cut-off
  • Quick Charge Current: 1000mA
  • Max Continuous Discharge Current: 3A
  • Operating Temperature: Charging, 0°C ~ 45°C, Discharging, -20°C~75°C
  • Storage Temperature: -5°C~35°C
  • Storage Humidity:
Vapcell%20INR14500%20L10%201050mAh%20(Purple)%202020-info
This is a high capacity 14500 LiIon cell frm Vapcell.
DSC_2683 DSC_2684
DSC_2689 DSC_2690
DSC_2686
DSC_2687
DSC_2688
Vapcell%20INR14500%20L10%201050mAh%20(Purple)%202020-Capacity
The two cells match nicely and the cell has lots of capacity for a 14500 cell, but the cell is not for high current.
Vapcell%20INR14500%20L10%201050mAh%20(Purple)%202020-Temp-2.0
Vapcell%20INR14500%20L10%201050mAh%20(Purple)%202020-Temp-3.0
Vapcell%20INR14500%20L10%201050mAh%20(Purple)%202020-Temp-5.0
Vapcell%20INR14500%20L10%201050mAh%20(Purple)%202020-CapacityTimeHours
Vapcell%20INR14500%20L10%201050mAh%20(Purple)%202020-Energy
Vapcell%20INR14500%20L10%201050mAh%20(Purple)%202020-PowerLoadTime
Vapcell%20INR14500%20L10%201050mAh%20(Purple)%202020-TripCurrent
Vapcell%20INR14500%20L10%201050mAh%20(Purple)%202020-Charge
Discharge-Vapcell%20INR14500%20L10%201050mAh%20%28Purple%29%202020-pulse-0.5%2010%2010-IR
Conclusion
This is the highest capacity 14500 cell I have tested to data (Spring 2020), but it is for moderate current draw (Preferable not more than 1-2A), not for high current.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
vapcell Dennis
vapcell Dennis's picture
Last seen: 1 hour 36 min ago
Thanks very much for the test Smile
thefreeman
thefreeman's picture
Last seen: 1 min 56 sec ago
Thank you for the test.
So with these we are now at 31% more energy than Eneloops pro, 72% more than standard Eneloops at the same power (1A vs 3A), this is becoming quite significant.
HKJ
HKJ's picture
Not only more energy, but also higher voltage. Boosting a single 1.5V cell to the same voltage will loose a significant amount of energy.
Superstocker
Superstocker's picture
Last seen: 46 min 12 sec ago
Thanks HKJ! As always, much appreciated.
djozz
djozz's picture
Last seen: 8 hours 9 min ago
Thanks for the test. The comparator shows that at low current these have a bit more capacity than the “gold” 14500 Vapcell from last year, but at 3A the L10 holds a slightly lower voltage than the gold ones.
I hope for a test of the H10 sometimes, although they are most likely the same as the orange Shockli’s that you recently tested.
SKV89
Last seen: 3 days 11 hours ago
Here are my test results:
Discharge capacity tested on a Xtar Dragon VP4 Plus:
Vapcell 1000mah gold – 993, 995 mah
Vapcell H10 1000mah purple – 962, 961, 943, 962 mah
Vapcell L10 1050mah purple – 1063, 1063 mah
Orbtronic 1000mah protected – 990, 972, 967 mah
Shockli 1000mah button top – 957, 921, 947, 950 mah
Shockli 1000mah flat top – 889 mah
Lumen on direct drive (highest output) tested with Texas Ace Lumen Sphere calibrated with Maukka lights:
GT Micro XP-L HI 4000K
(flat top no contact) Sanyo UR14500P 840mAh Battery
(flat top no contact) Vapcell 1000mah gold
964 lumens -14500 KeepPower 840mAh Sanyo UR14500P Protected Button Top
951 lumens – EVVA Protected Button Top 800mah
974 lumens – Orbtronic 1000mah protected button top
1194 lumens – Windyfire 600mah button top
1195 lumens – Shockli 1000mah button top
1155 lumens – Shockli 1000mah flat top
1247 lumens – Vapcell H10 1000mah button top purple
948 lumens – Vapcell L10 1050mah flat top purple
Kronos X5
903 lumens – Sanyo UR14500P 840mAh Battery
1110 lumens – Windyfire 600mah button top
1104 lumens – Shockli 1000mah button top
1086 lumens – Shockli 1000mah flat top
842 lumens – Orbtronic 1000mah protected button top
931 lumens – Vapcell 1000mah gold
1180 lumens – Vapcell H10 1000mah button top
930 lumens – Vapcell L10 1050mah flat top
The Vapcell H10 is a monster! It is both a high drain and high capacity cell, which is just incredible! It even managed to beat the Shockli and Windyfire which was the previous 14500 amp king. Hope to see more flashlights that can take advantage of the high current. Both button top and flat top version outputs the same.
The Vapcell L10 is the highest capacity 14500 in existence. Output is equal to the previous Vapcell 1000mah gold.
The former 14500 king Shockli 1000mah just lost the throne but it is still an excellent high current and high capacity cell and besides these two flashlights, you won’t see any output difference vs the Vapcell H10.
Seems like the Orbtronic uses the same cell as the Vapcell gold and that they used an extremely high quality protection circuit because the output on the X5 is about the same between the Orbtronic and Vapcell. These two cells still have their uses because in lower power regulated lights, you won’t gain any lumens by using high drain cells and the Vapcell gold and Orbtronic is still the highest capacity 14500 by a small margin in low amp modes that would give you a bit more run time.
