Test/review of Vapcell INR26650 5000mAh (Purple) 2020
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 4 days ago
DSC_1985
Official specifications:
  • Model:INR26650 5000mah 20A
  • Size: 26.1*65.5mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Typical Capacity: 5000mAh (0.2C discharge)
  • Min capacity: 4900mAh (0.2C discharge)
  • Weight: Max:95g
  • Internal resistance: Max:15mOhm AC 1kHz
  • Standard Charge: 2000mA,CCCV 100mA cut-off
  • Quick Charge Current: 3000mA
  • Max Continuous Discharge Current: 20A
Vapcell%20INR26650%205000mAh%20(Purple)%202020-info
This is a 26650 LiIon battery with fairly good capacity and current capability.
DSC_1983 DSC_1984
DSC_1986 DSC_1987
DSC_1988
DSC_1989
DSC_1990
Vapcell%20INR26650%205000mAh%20(Purple)%202020-Capacity
The two cells match nicely and do easily have the rated capacity. As usual I try a bit above rated current, on this battery it was not a good idea. It has some sort of fuse (Probably temperature based) that blows when continuous overloaded, it is good good safety, but I could not finish my test on the first battery. For the second I reduced maximum test current.
Vapcell%20INR26650%205000mAh%20(Purple)%202020-Temp-15.0
Vapcell%20INR26650%205000mAh%20(Purple)%202020-Temp-20.0
Vapcell%20INR26650%205000mAh%20(Purple)%202020-Temp-30.0
Vapcell%20INR26650%205000mAh%20(Purple)%202020-CapacityTimeHours
Vapcell%20INR26650%205000mAh%20(Purple)%202020-Energy
Vapcell%20INR26650%205000mAh%20(Purple)%202020-PowerLoadTime
Vapcell%20INR26650%205000mAh%20(Purple)%202020-TripCurrent
Vapcell%20INR26650%205000mAh%20(Purple)%202020-Charge
Discharge-Vapcell%20INR26650%205000mAh%20%28Purple%29%202020-pulse-1.0%2010%2010-IR
Conclusion
It is a good battery that can deliver a lot of current and capacity and it has protection against getting too hot.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Superstocker
Superstocker's picture
Last seen: 1 min 4 sec ago
Thanks HKJ!
d_t_a
Last seen: 29 min 46 sec ago
Just wondering, have you tested other unprotected batteries that also have this kind of safety feature? (sorry, I can’t remember reading battery reviews of your unprotected batteries that behave like this.. or I might have missed it).
HKJ
HKJ's picture
Yes, you can usually spot them in my test because I am missing the power and protection test for at least one of the batteries.
