I’m not 100% sure, but I doubt any fw update will change the way the light charges I don’t believe any pin on the controller interfaces with the charger chip. I’ll happily accept correction on this opinion.
No. The firmware is completely unrelated to C-to-C charging. That’s entirely a hardware matter, and cannot be affected by firmware on the attiny85.
As for firmware though, some changes relevant to the lantern are:
2019-09-24: Added version check function (15+ clicks from off), and an automatic ramp-down if button is stuck.
2019-09-28: Added automatic lockout if button remains stuck long enough.
2019-10-02: Increased brightness of LT1’s muggle mode ceiling.
2019-11-18: Added SOS mode.
2019-11-19/20: Rewrote interrupt handling system to fix several infrequent issues like occasionally missing a button click while asleep. This also changed how it handles electrical noise conditions, by making it attempt to boot normally after an error instead of staying in a blinking error mode.
2019-11-29: Adjusted LT1 tint ramping brightness correction formula (was using measurements from a prototype, adjusted to match people’s reported values for production units).
2019-12-03: Adjusted LT1 tint ramping brightness correction again, based on more accurate measurements. Should keep power use and brightness closer to flat while changing the tint now.
2020-03-16: Rewrote all ADC-related code. Almost no effect on the lantern though; basically it should just make voltage readouts more stable.
2020-04-13: Recalibrated internal timing loop; time-based functions like strobe and beacon should be a little more accurate now.
There were lots of other changes too, but not relevant to the lantern.
Seeing as how colored versions are now problematic due to constraints, here I am voting again for focusing on adding the powerbank feature. Seems a waste to lug around 4x18650 and not be able to dip into those power reserves if light is not needed in a particular situation. Nitecore and Fenix both have lower priced lanterns with powerbank features so shouldn’t too much of a stretch. Thanks again!
Finally pulled the trigger on this. As a diehard camper (many times solo), I’m really looking forward to receiving this.
Currently I have a Coleman propane lantern (large, delicate, propane is bulky, noisy), a Coleman LED 4xD battery lantern (large, batteries suck, cold white), and some cheap Amazon 4xAA (bare cold white LEDs makes for extremely harsh light).
Awesome. Thanks for creating this light man! We’ve been using it almost every night on its lowest brightness mode when we’re watching movies. It’s nice to be able to see our snacks and find the remote when needed.
I don’t know if I know what it means but here is what I observed.
I acquired a C to C cable, a C to lightning cable and a C charger.
My wife has an android phone with a C connector I have an apple.
I tested each device with higher and lower state of charge than the device connected to it.
With the C to lightning connector no matter which device was higher or lower no current would pass between the iphone and the LT1.
With the C to C cable between the LT1 and the android phone the phone would always charge the lantern no mater which device had the higher state of charge.
I understand that but the there was some talk earlier in the thread about powerbank functionality in a future iteration.
Then there was this from a Sofirn Rep.
Not knowing exactly what this meant It got my wishful thinking up. So I decided to do some experiments of my own to determine what it meant if anything.
ordered mine without batteries. purchased 4 Samsung 35Es (protected) that will be dedicated to the LT1.
while the included ones i’m sure are of good quality, i want max run time.
It’s graphical ui (I never did get any of the text based ones figured out)
I used one called progisp 1.72
there is a button to select the chip
then under “file” select load flash then navigate to your hex file
connect your chip clip and then hit the “auto” button
there is a place on the bottom of the window that reports progress or errors
it does a lot of other stuff that I know nothing about, but this was all I had to do to re-prog, the Lt1 a Q8 an fw3a and several convoys.
