My Vapcell S4+ Analyzing Charger photos and observations
137 posts / 0 new
hammerJoe
Last seen: 1 year 6 months ago
How annoying is the bell reminder when the battery is charged?
How well does the auto mode really works?
tatasal
Last seen: 51 min 26 sec ago
hammerJoe wrote:
How annoying is the bell reminder when the battery is charged? How well does the auto mode really works?
I have not tested to a fully-charged cell yet so I haven’t heard it yet. So far what I heard is soft, pleasant sound upon plugging, so I don’t know if the sound is the same or not.
Comparing this charger with my other charger that features an Auto mode (specifically the Miboxer C4-12)…most times with the C4-12 I get to change it into the Manual mode because it is very inconsistent in IR readings which run into the hundreds regularly. As you know with these Auto mode charger, the higher the IR the lower the charging rate, so low that it will only charge .3A.
The Vapcell S4 has so far not shown to have the C4-12’s usual inconsistent mistaken high IR readings and will charge at a much higher rate in Auto mode.
hammerJoe
I know all about the C4-12. Worst chargers I have had in my hands.
ChibiM
ChibiM's picture
Last seen: 1 day 6 hours ago
Thanks for the clarification Tatasal. Might keep an eye on this one as a second (in reality 5th ; ) battery charger. Thanks for sharing.
hammerJoe
In Auto mode does it use different currents other than 250/500/1000/1.5/2A?
tatasal
I assume you are asking about Charging current:
In Auto mode, current is dependent on the cell’s IR…for example, the 25R I just tested had 21mohm and it chose 2.5A… it will go as high as 3A if a lower IR’d cell is used.
In my C4-12, the notice as the cell is going up in voltage, it IR goes down and as such, the charging current also goes up. I have not observed this yet in the S4 since I have not tested a cell from a fully discharged state until its full.
In Manual mode, current is adjustable from 250, 500, 1000, 1500, 2000, 2500 and 3000ma. X 4 or any combination per bay/cell, as needed.
RobertB
RobertB's picture
Last seen: 2 days 6 hours ago
tatasal wrote:
ChibiM wrote:
So this could be a replacement for the Opus BT C3100?  Or would it be an upgrade from the Opus?
Well, to guys who do a lot of niMh ‘refresh’ or ‘capacity’ test, the Maha Powerex MH- 9000 is more appropriate, which l also use.
But in my case that l never ‘refresh’ my lithium-ions (since it will only hasten its demise), the answer to your question is yes.
If it can’t be manually set to 3.7v to discharge and store cells, or charge to 4.35v, then I certainly wouldn’t consider it an upgrade to the Opus.
tatasal
The S4 does not have a Storage mode, nor 4.35v termination voltage.
tatasal
Actually, personally I don’t think getting the cell off a charger when it displays 3.75 voltage is a proper storage process. ( though it won’t hurt!)
Why? For people who also own a hobby charger like myself, when I use the Storage mode of my iCharger, the Storage process is done differently: Once the 3.75v is reached, the charger exists the CC stage and goes into the CV stage as the current steadily goes down till properly termination. The portion from CC to CV takes still takes quiet a long time still (IIRC perhaps 10min?) and keeps on adding more mAh until it finally terminates.
tatasal
Last night I did a capacity test session and I can confirm that the high rates I earlier posted as Discharge rates were incorrect but are indeed the Charging rates chosen on the Charging phase of the Capacity test (charge-discharge-portion). Sorry about it.
It should be noted that when the Manual mode in Capacity test is chosen, if you want faster Capacity test process, the charging rates selection can go as high as 3A on all 4 bays during the Charging phase and when the phase goes into the Discharge phase, the S4’s default .5A is used, regardless of the number of bays used.
geneticplasma
Is it a good choice for Ni-MH batteries?
tatasal
Quoted from HKJ’s review:
“ With NiMH it worked perfectly for charging. It can also discharge, test batteries and repair batteries, but there are a few inconvenience in some of these modes. A slide switch is used to select between manual or automatic current selection, I like this solution.”
It’s here:
http://budgetlightforum.com/node/70565
vapcell Dennis
vapcell Dennis's picture
Last seen: 7 hours 58 min ago
Thank you very much for your review Thumbs Up
Happy New Year everyone
hammerJoe
I got mine a couple days ago.
It seems to be working good.
The beeping sound is very subtle and not disruptive. It can be used in a working environment with no issues imo.
The big criticism so far for me is the display. Without the backlight on its almost impossible to read.
But we do have to press a button to cycle between the cells so that will turn the backlight.
The IR readings is super fast and compared to my opus bc700 not too far off so that’s good news.
The minimum charging current is 250ma, I wish it offered 100mah.
It’s the first charger that offers wh (watt/hour) readings, I’m still trying to think how i can use it to determine when it’s time to dispose a cell??
Overall so far it’s working.
d_t_a
Last seen: 4 hours 49 sec ago
Re: watt-hour readings, the SkyRC MC3000 can also display charged and discharged capacity in watt-hours.
But that seem still rare in chargers. Haven’t gotten a Vapcell S4+ charger yet (they don’t ship to our country in economical shipping rate for now)..
malkoff junkie
malkoff junkie's picture
Last seen: 4 hours 24 min ago
deciding between this, and XTAR Dragon .
Malkoff !
whatsthepoint
whatsthepoint's picture
I was thinking of ordering this charger from liionwholesale for $35.99.
USPS Priority Mail shipping to Texas is $11.26.....a bit high shipping cost
Anyone purchase one there?
https://liionwholesale.com/collections/chargers/Vapcell
never underestimate the power of stupid people in large groups
SlvrDragon50
USPS Priority Mail shipping to Texas is $11.26…..a bit high shipping cost
It’s $35 shipped from nealsgadgets.com with tatas4
whatsthepoint
Yes,shipped from China in about a month.I buy as little as possible from China.I give a domestic seller the 1st grabs at my wallet.
Free shipping really means it's already included in the price.
Nothing is free.
SlvrDragon50
I’m confused. I thought you were trying to find a cheaper price. If you want to buy domestic, $12 to ship via USPS Priority is a pretty fair price. Priority Mail shipping prices have gone up a ton over the past 1-2 years.
tkmm
Last seen: 1 year 8 months ago
Can you tell me if it’s possible to fit there 4 × 26650 ?
tatasal
The Vapcell S4+ could accommodate 2 26650 in the 2 outer bays and 2 21700 in the inner two bays:
tkmm
Thanks
whatsthepoint
The Vapcell S4+ is now available at 18650batterystore for $34.99
USPS ground shipping to Texas is $5.61
https://www.18650batterystore.com/Charger-p/vapcell-s4-plus.htm
toni31
I see some test that it draw 4.5A while charging 4 batteries at 3A, could be work with a proper car charger (12V 5A)?
tatasal
Yes, it will work, IIRC, most car lighter 12v receptacles are rated up to 10A.
toni31
Thanks
stephenk
stephenk's picture
Last seen: 2 hours 48 min ago
The Vapcell 4+ is also available from Neals Gadgets – here
Whilst far more expensive, my XTAR Dragon VP4 Plus served me well for nearly 3 and half years now. It’s a solid bit of kit.
dolevu
I feel when test battery capacity using Vapcell S4 Plus, the batteries are too hot. Is that normal?
When I test the same batteries using Lii-500, they don’t even get warm.
Both tests were set at 500 mA current.
bcm00re
Last seen: 1 month 1 day ago
Anyone know if there are any coupon codes available — like for BLF users?
