This light has me interested. It’s about time we had more lights using decent switching drivers from good-quality manufacturers like Convoy.
It would be nice to see more photos of the driver, though I’m going to guess from the specs and testing that it’s using the tried and tested TPS61088 .
Would also like to see an OP reflector version. I’m usually an e-switch guy, might drill one of these for a side switch…
not brighter as L6,and the diameter of the reflector is a little small ,so the beam is more floody.
The reason I have not used SBT90 is that the brightness is low and the price is very expensive
Simon,
Is there any plan to use the XHP70.2 in the Convoy L21A (which as you know is another light that uses one 21700 cell)? The L21A has a larger head so I assume a larger reflector, but it appears to only be available with the SST40 or XHP35 HI.
Also, can your standard 4-mode (0.1–3–30–100) driver be mated with the XHP70.2 — in either the M21C or L21A? If so, could we still expect about a 4000 lumen output at 100% (like the current driver in this review)?
Why would the XHP70.2 emitter be any less desirable in the L21A than the M21C (that does have it)? I am under the impression that the XHP70.2 has the potential for about twice the lumen output than the SST40. All that said, I could be completely misguided here.
