[quote=valera]
[quote=RollerBoySE]
Dear colleagues! Are there any diffusers for Emisar D4S or maybe some are suitable from others ?
[quote=valera]
[quote=RollerBoySE]
Small Naturehike diffuser is a clear favourite of mine:
https://www.aliexpress.com/item/32974909430.html
Is level 65 similar to the current draw of the small D4, or the full current of all 3x 7135s?
Im attempting to estimate runtime and wasnt sure.
Looking at the ramp table for the D4S, level 65 is a value of 125/255 on the 3x7135 channel. That theoretically works out to about 515 mA if the chip has a linear response curve, but I don’t think it does. It’s probably higher than 350 mA, but the only way to know for sure is to measure it.
Anyone by chance have a set of the small machine screws that align the AUX board and mcpcb and attach them to the mcpcb shelf in the host? I had a light that I bricked apart and apparently I misplaced these.
Edit: Richard at Mtn was kind enough to measure a few for me. Theyre Phillips Pan Head 2mm x 0.4mm x ~6mm machine screws.
I was able to order a few assorted lengths from an online hardware store.
What’s the reset?
Just got a D4Sv2 and it seems to go straight to turbo with 1 press from off, or hold from off to stobe mode, what’s doing on?
Disconnect power, hold switch, reconnect power, wait 3 seconds or until light stops flashing, release switch.
Much thanks!
REVIVING this thread—-D4Sv2 FLASHER for walking at night
My goal was about 1.5 - 2 flashes per second at roughly 400 lumens. The slowest I could get the strobe was around 4 flashes per second at full power. Is there any way to slow it down and reduce lumens?
Brightnorm
You could use beacon mode and set it to one flash per second. It has adjustable brightness too.
IGNORE - Found it. Thanks (Too bad the speed isn’t adjustable)
Are the instructions handy or would I have to scroll through many posts?
Sorry, it doesn’t have anything quite like that. However, there are four things which might get close…
The bike flasher mode is intended for high visibility at night, like walking or biking. Have you tried it?
Hi Toykeeper,
Since Bike flasher mode can’t go faster than 1Hz, Beacon mode seems to be the best. When you said 1Hz or faster, can you tell me how to speed it up? 2Hz-2.5Hz would be ideal.
Are you working on any brilliant projects these days?
Stay safe
Sorry, that was supposed to say slower, not faster. 1 Hz is as fast as beacon can go.
No problem.
Does anyone have the d4sv2 with w2 leds? Im wondering about heat. Sst20 already heats up very fast and im hoping w2 is better, but I dont think this is the case.
I do, from Vinh, and it throws like a monster. I haven’t noticed it getting any hotter than my other ds4v2s with SST20’s. But I haven’t paid attention to the heat aspects of the light, so I can’t guarantee that
observation. But it’s hell of a thrower, and the beam, though rather narrow, is still wide enough for general use, though not ideal for that purpose.
Thanks for the reply. I think I will go for sst20. Still enough throw for me I think.
SST 20 is excellent; you can’t go wrong with it. Enjoy!
