What did you mod today?
Wow!
How much current are you going to be running in that?
I have no idea - electronics is my weak pointā€¦ the driver is an A17dd as in the X6 - itā€™s powerful though and wipes out my fw3a totally when side by side. I thought the fw3a was more powerful, but it would ā€˜lookā€™ not. Maybe it is on paper, I dunno lol (maybe itā€™s coz itā€™s slightly more focussed). I have the hiā€™s in my fw3a too!
Nice work GO0SE :+1:
Looks good. Since you use a lathe, maybe you can widen the bezel opening slightly (without compromising the slot for the o-ring) to get more light out.
Now I discussed thisā€¦ā€¦ā€¦ I thought about ā€˜unholingā€™ the holes lol - as in rounding the bezel to the 3 circles/lenses.
CRX pointed out the o ring (which is kinda square and you can see in the pics) might pop out. I think heā€™s right. It would look funky, but youā€™d have to lose the ring - maybe silicone the optic in around top edge off the optic if waterproofing were a worry - but it could be done.
Still, I donā€™t think Iā€™ll botherā€¦ā€¦.yetā€¦ā€¦
I am looking to put goldish leds on the illuminated tailcap, and am getting some goldy/yellow gitd powder for a gasket.
I may get another one later and sell it/ them now I know whatā€™s involved ā€¦. Iā€™m kinda in love with this one now, itā€™s moved into my 3 favesā€¦.and because i made it, itā€™s all the better lol! (more so it works) :stuck_out_tongue:
Thank mate! :slight_smile:
Wow. Some orsm mods and builds going on. Love the work guys. :+1: :beer:
Stellar pictorial. Just swapped a sw40 R9080 into mine and it looks so much nicer than the low CRI ā€œNWā€ XPL. A little spottier but that offsets the marginal decrease in lumens. Mine also had arctic silver thermal paste (or similar), though it is now replaced with arctic aluminaā€¦
Finally got this one done. Dropped a 4000K 219C in a SPL-120. Unlocked the stock driver.
Is the output noticably higher than before?
Itā€™s pretty significant, especially in the highest mode. I really hated the stock emitter.
What pill was in it?
The one on the right
Cool the good one from my testing. Iā€™m getting 589lm with just an emitter/board swap XP-L V4 3C tested on my T/A muakka tube.
Been removing the good drivers and putting them into the round mcpcb pillsā€¦
Resistor modded a fewā€¦ of the othersā€¦ just to play withā€¦
Wow, how did you get the potting out?! These things are built like tanks
Itā€™s a RTV silicone pottingā€¦ I soak them in a very strong thinner. I take a small drill bit and by hand remove the silicone down to the driver contact board, the 2 holes opposite the lead holes are for filling/ venting the pill, remove the silicone from those 2 areas and soak in thinner. It takes time and patients but eventually the silicone breaks down enough to push the driver out. I used to hot air the spring contact board off, now I just soak them.
Youā€™re a better man than me, I know Iā€™d get frustrated and mess that up.
Iā€™d really like to do a brass bar 18350 conversion next, just trying to plan out how to do it
I made up some brass signal tubes for my FW3 shorty mods and machined the tubing smaller for the FW3/NovaTac mods. So I had 3-4 FW3 signal tubes left over. Now Iā€™m out of brass tubing. But then I figured I would flap out the battery tube of the NovaTac which was about .005ā€ and then I cut down the FW3 tube to fit.
My Last FW3/NovaTac Triple using the FW3 driver and cut down signal tubeā€¦and clipā€¦
That looks awesome! Very cool
Thanksā€¦ :+1:
