Thanks hodor. Looks like I was missing USBasp driver for the device. Unfortunately, when I follow Hoop’s instructions to “update driver software” I get a message that “the best drviers for my device are already installed”.
Hanks kit will work, it’s just a. USBasp. You need to install a driver for the USBasp. Step 2 in Hoop’s guide, or step 1 in the D4v2 flashing instructions.
Once the driver is installed, avrdude should recognize the programmer. If you still see the device is malfunctioning message, restart your PC and plug the programmer directly into one of the USB ports, not into a hub.
Does it still show up as malfunctioning in the device manager? Try plugging it in without the leads to the micro attached. If it still doesn’t work, maybe you got a bad one?
I somehow managed to get Zadig to show with a USBasp device. When I try the test code in command prompt I get this message -
avrdude: Warning: cannot query manufacturer for device:
avrdude: Warning: cannot query product for device:
avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor=‘www.fischl.de’ product=‘USBasp’
On Arduino IDE you should have installed your MCU library, select USBasp on “Tool->Programmer” and use “Sketch->Upload using programmer” to flash code.
I tried what you said and got the same message with Arduino IDE as with command prompt
An error occurred while uploading the sketch
avrdude: Warning: cannot query manufacturer for device: Input/output error
avrdude: Warning: cannot query product for device: Input/output error
Personally if it were me, I would go back and try to uninstall everything and start again with Hoop’s guide. If you get any errors, ignore them and keep going. I have a feeling my drivers didn’t look like they installed correctly but turned out to work just fine.
Checking the connection with “avrdude -p t13 -c usbasp -n” in Atmel Studio Command Prompt is the only test I need to check the connection is good and everything else is working.
If I unplug the device and plug it back in the pc reverts to “usb device is malfunctioning” and I have to go through the zadig process again to get it to show up. No matter what I do though I cannot get rid of the “device requires further installation” message. I tried disabling the Driver Signature Enforcer and rolling back the driver version but nothing seems to work.
Yes I’ve been trying the “avrdude -p t1634 -c usbasp -n” connection check at every point. I still get the same error message.
Not only does my soldering iron hate me, my pc does as well
I plugged it in to a different usb port. Don’t look at me like that I already tried it. For some reason this time I tried a 3rd port and it woked perfectly fine this time.
So I programmed the ATtiny13a and wired up an led and battery….
Thanks to everyone for your suggestions and helpful advice.
You know if it wasn’t for the virus making shipping super slow lately I probably wouldn’t have tried this. Maybe I’ll explore it a little more now
