Looks good. Since you use a lathe, maybe you can widen the bezel opening slightly (without compromising the slot for the o-ring) to get more light out.
Now I discussed this……… I thought about ‘unholing’ the holes lol - as in rounding the bezel to the 3 circles/lenses.
CRX pointed out the o ring (which is kinda square and you can see in the pics) might pop out. I think he’s right. It would look funky, but you’d have to lose the ring - maybe silicone the optic in around top edge off the optic if waterproofing were a worry - but it could be done.
Still, I don’t think I’ll bother…….yet……
I am looking to put goldish leds on the illuminated tailcap, and am getting some goldy/yellow gitd powder for a gasket.
I may get another one later and sell it/ them now I know what’s involved …. I’m kinda in love with this one now, it’s moved into my 3 faves….and because i made it, it’s all the better lol! (more so it works)
Stellar pictorial. Just swapped a sw40 R9080 into mine and it looks so much nicer than the low CRI “NW” XPL. A little spottier but that offsets the marginal decrease in lumens. Mine also had arctic silver thermal paste (or similar), though it is now replaced with arctic alumina…
It’s a RTV silicone potting… I soak them in a very strong thinner. I take a small drill bit and by hand remove the silicone down to the driver contact board, the 2 holes opposite the lead holes are for filling/ venting the pill, remove the silicone from those 2 areas and soak in thinner. It takes time and patients but eventually the silicone breaks down enough to push the driver out. I used to hot air the spring contact board off, now I just soak them.
I made up some brass signal tubes for my FW3 shorty mods and machined the tubing smaller for the FW3/NovaTac mods. So I had 3-4 FW3 signal tubes left over. Now I’m out of brass tubing. But then I figured I would flap out the battery tube of the NovaTac which was about .005” and then I cut down the FW3 tube to fit.
My Last FW3/NovaTac Triple using the FW3 driver and cut down signal tube…and clip…
I have not seen any SPL-120’s just the SPA SPL-120’s and the 3 older ones I had with the SS Black bezel to me is the better ones of the SPA’s from my experience. I don’t know much about the other models.
Edit. Sorry… I misread your question… I had 120M locked in my head… I got a 120M coming… a Black anodized with a clip… my first… All my others have been in the weapon light kit SPA SPL-120’s.
