Interest collect for a new Sofirn design: tube style18650, magnetic ring control, USB-C charging, 500 lm max (AKA grandma light)
536 posts / 0 new
dotBLF
Can I get on the list for 3 please?
Thank you!
Nooner
Last seen: 5 hours 38 min ago
I’d likely take 2.
jkbam
In for 1. thanks
Couchmaster
Last seen: 1 day 17 hours ago
In for 3 please.
VictorB
VictorB's picture
Last seen: 1 year 1 month ago
I’m in! One or two lights sure
asdqqq
In for 1 if it it is infinitely variable, starts at a moonlight level.
bonC
Infinitely variable magnetic ring and NW? Hell yeah I’m in for 2 please!
slowtechstef
slowtechstef's picture
Last seen: 1 month 1 day ago
Djozz: thanks for this great initiative!
I am interested in 2 units.
djozz
djozz's picture
Last seen: 1 day 16 hours ago
I have no idea about the current status of the project. I know that Barry is working and he posts on BLF every now and then, but how the design plans of Sofirn have changed because of the crisis I have no idea. I guess I need to mail Barry.
Moomoomao
In for 1!
My first light was a Sunwayman V11R – still one of my favorites but I’ve grown away from the cool white LED.
Like others have mentioned before, as long as it’s packed well with certain types of grease the ring won’t really loosen up too bad and can always be repacked.
Bwana
Last seen: 15 hours 56 min ago
Both my grandmothers have passed . Can I still get one ?
djozz
djozz's picture
if you can still catch their spirit, yes sure Smile
paosms
Last seen: 11 months 2 weeks ago
I am in for at least 2. Maybe 3. Thanks!
korpzgrinda
korpzgrinda's picture
Last seen: 4 months 1 week ago
Location: Eastern Woodlands in the Wilderness of North America
interested in 2 please
Unheard
Unheard's picture
Last seen: 4 min 11 sec ago
Maybe I should take one. Please add me to the list, djozz.
Spitzbube.
Sari33
Last seen: 18 hours 12 min ago
interested, hope can be more than 500 lumens output
patmurris
patmurris's picture
Interested.
Sorry i haven’t followed the whole thread… and post #1 does not help much understanding where the project is now. Could you add updates to the first post?
djozz
djozz's picture
patmurris wrote:
Interested.
There are no actual updates since the first post apart from that in January Sofirn asked for a draft of how the light should look like and so I made one for them. I decided not to post my draft because it will (of course, this is BLF Smile ) generate lots of discussion on something that Sofirn may not use after all. So the next update will be when Sofirn confirms that they are actually started working on the design, with hopefully first design drawings.
SKV89
Last seen: 2 days 51 min ago
Can you provide me a link of where to find the ipx7 or ipx8 usb-c port? I’m trying to convince a flashlight manufacturer to use usb-c instead of proprietary magnetic charging.
Lagittaja wrote:
Well, I’m interested. Put me down for 3.
I’ll probably repeat a lot of what’s already been said but I’ll leave my few cents anyway.
As far as features go, I would prefer a TIR optic (but not too floody). With a high CRI emitter and an efficient driver. Detented off position would be lovely.
Strategically placed (thicc) knurling would be a good thing and the no-ano/SS ring should be slightly thicker than the rest of the body.
Suggested modes are fine, infinitely variable would be nice but not really necessary.
(Though if it ends up being variable then yes, please start from ~1lm but otherwise no.)
Regarding the charging port, like raven said, IPX7 and even IPX8 rated USB-C receptacles are a thing. The light needs to be designed around one and it needs to be implemented properly but I would pay a little bit extra for that.
Though that might be a bit too much to ask for in a ~20-25$ light, considering the BOM increase.
If someone wonders about the price, cheapest USB-C receptacles are ~0.1$ a piece in 100-1000+ quantities but if you add ingress protection then they start at around 1$.
Certainly not expensive but small things add up quickly and Sofirn needs to make a profit.
Though that was based on LCSC and glancing over some Alibaba listings I guess they could find something closer to 0.3-0.4$.
If an IPX7/8 port is not possible then hiding the charging port in the threads is the next best option in my opinion.
Since personally I find flaps to be fiddly, they will wear over time (no longer water resistant) or better yet just fall off.
Sure, with the in-threads-option an o-ring will wear as well but I’d say they’re lower maintenance? Threads will have grease so there’s probably going to be enough grease on the o-ring itself to reduce the wear rate. And if damaged then it’s relatively trivial to change.
djozz
djozz's picture
This is the USB-C port part link that I sent Barry as an example of what can be used. But I am by no means an expert on such things, I hope that Sofirn can sort out what is usable and affordable.
https://www.digikey.nl/product-detail/en/amphenol-icc-commercial-products/124018612112A/124018612112ACT-ND/9825364
SKV89
Excellent thanks!!!
headburger
In for 2, very worthwhile project!
ChibiM
ChibiM's picture
Last seen: 2 days 10 hours ago
I'm concerned about safety.
I would suggest adding a USB Power adapter as well, and not just a USB-C charge cable. Make it a complete kit if possible.
It's a wise decision to use USB-C instead of Micro USB. Just think about the times they try to connect the cord up-side down.
If you just add a charge cable, you don't know where they try to pry those cables in. Even USB-A cables can give problems. I've seen people trying to put a USB cable in an ethernet port on laptops.. and no, they weren't dumb people. Just couldn't see the holes very well.
I hope Sofirn can guarantee safety and test this rigourosly before production.
artooro
Last seen: 2 years 5 months ago
I want at least two
robbobus
2 please.
bobkido
Looks like a worthy effort. Single unit for sure, soft commitment for another 3 for total of 4.
thanks
Just a simple man.
jon_slider
jon_slider's picture
Last seen: 4 hours 46 min ago
you can dream, I do too.. but that is not what this light is about, afaict
there is also no mention of NW, unless you mean 5000k High CRI:
djozz wrote:
led maybe Samsung LH351D 5000K 90 CRI.
afaict by searching posts by djozz with the word “infinite”…
it is not going to be infinitely variable:
djozz wrote:
Infinitely variable is not a promised feature
djozz wrote:
operation will be a magnetic control ring with off-low10lumen-med100lumen-high500lumen, nothing else (and so not infinitely variable).
djozz
djozz's picture
I have communicated the list of wishes to Barry/Sofirn in Januari, which included the wish for the magnetic ring being infinitely variable. I have not received comments on that list from Sofirn since.
But Sofirn has not even started with the design, so I’m not surprised that there are no answers to the wishes, because only when they start designing they can reflect on ideas and get a first idea of the costs of certain wishes.
The infinitely variable ring is not a key feature for this light, but if it is possible to have one while staying within budget I will certainly try to get that included.
chrisddo
In for 1
m0nk33
Last seen: 1 year 4 months ago
In for 1!
