Cheers GOOSE, sometimes I get half way through something and then realise it wont work or could be done a better way I found the 900mm mirror when I did a random ebay search and couldnt resist buying it, it was cheap for what it is and a great addition to my collection of parts and lights.
It has been a steep learning curve and this thread made me realise how little I actually know so I have gone back over things and reassessed what I am doing. Now I have a better understanding of why I decided to build the lens lights like I did. They are based on elipsodial reflector spot lights, telescopes and camera lenses.
A bit of an update I have been sorting things out the last week or 2 and havent done much on the lights. Im also wait for parts from china and that could be a while.
One of the things i did get was a 68mm parabolic mirror from aliexpress with the aim of building a smallish recoil.
The focal point appears to be down in the mirror which makes it hard to use it for what I brought it for. but when I turn it upside down on an LED I get this result.
It looks promising for a shuttering collar to keep light of the internal lens barrel I think a bigger one of these will cut the aperture i just need to do some calculations to work out aperture size. Then destroy one to see if it works.
Australia NSW News—Police in Hunter Valley were called by numerous alarmed citizens who reported UFOs flying in the local sky. Investigation details were not available.
Just 2 x 145mm fl370mm aliexpress lens. I find a single lens doesnt work as well as 2. It did attract attention last night because of the projection onto the clouds
Ah yeah, I think I remember something about multiple spherical lenses vs single aspherical lens having a similar effect on collimation.
That’s prett cool.
I have done a lot of reading and looking to find more information on what im doing and they are pretty much elipsodial reflector spot light without the reflector. There is a thread way way back here
Some lights use a double convex lens this could explain the lens configuration in the W30. It will be interesting to see what these W50 lens is.
At a guess the damage may have come from an exploding globe. Looks like it has had molten glass sprayed on them. Monday I will inquire about getting them resilvered there is a place that restores antique mirrors. I will see if the bloke who gave them to me and probably get a few of his restored aswell.
Im not exactly sure but I think you are close. By the markings and being of high quality I wouldmthink military lights of some sort. The bloke who gave them to me brought them from a bloke on stalkbook who just found them in the back of his shed.
There was another two like them and they were aluminium. Thats why I think maybe they were in the same light. For temporary landing lights or something. The date on most of them was 1940s but it is very hard to find information on them. Only problem is the more you look the more bargains you find.
This is one that I sold. Looks like a ceramic backing
This is the 250mm I kept and hopefully to be restored
Maxabeam is on the left. W30 is same cut one mentioned earlier. i made an adaptor to go in my lens jig. The configuration used primary lens 200mmD 400mmFL, secondary lens 150mmD 200mmFL. No measurements yet but I am working on a setup to take accurate measurements. Another W30 ordered for a lightstorm s90 clone so before I mod it I will take measurements for comparison.
Exactly the same numbers the condition is not as good. This one came from a government research place in sydney the old bloke said it was originally in the searchlight but they were long gone. They must have been a standard light brought in during the second world war. It will be interesting to see if anymore turn up.
Well I have taken a different approach to designing lens lights and now before I try to build it out of alloy this way will give me exact measurements. So i have been playing with W30s and some new lens, i have this combination which was a calculated guess. It is a 75mmx75mmfl condensor and 150mmx600mmfl primary or objective lens. the actual length is still too long for a torch so I need to experiment to shorten it. My apologies for not having measurements but very soon when Im confident they are accurate enough to use.
From my measurements the stock W30 runs at 2.6amp the driver in this W30 runs at 3amp with resistor swap from R025 to R010. my tests point to the laser diode being able to handle 3.5amp and you would be stupid to take my word for it. Does anyone know if W30 has a linear driver?
