Test/review of Vapcell ICR14500 1000mAh (Gold) 2018
38 posts / 0 new
Barkuti
Barkuti's picture
Last seen: 1 day 21 hours ago
EasyB wrote:
SKV89 wrote:
I doubt they are the same cell. The Vapcell measures higher capacity but noticeably less output in FET lights. So if you are using FET lights, then the Shockli 14500 is better for max output. But for most 14500 lights, there will not be any difference in output and Vapcell has the advantage of more capacity. Both are the best 14500 you can get.
http://budgetlightforum.com/comment/1539656#comment-1539656
Agreed. Comparing the discharge curves of the shockli and vapcell they are obviously different cells; different shapes and IRs.
I didn't take a look at this until now, and indeed they're different. The Shockli seems to be very overrated, I say this because good battery OEMs do rate their cells consistently and usually stick to the common 0.2C rating standard (Power Long Battery, using a 1C rating standard, is an exception). According to HKJ's test, the newer 14500 Shockli cell is probably a 900 mAh OEM rated cell (versus a 950 mAh OEM rating for the Vapcell).
Looking at HKJ's energy output report charts, the Vapcell 1000mAh is best suited for light loads, up to ≈2 A or so. From there on the Shockli 1000mAh overtakes. For those of you who don't drain your cells much, the load drain rate “turnaround point” could be lower (≈1 A).
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
svicar1
Last seen: 3 weeks 1 day ago
Thanks
I will buy Vapcell ICR14500 1000mAh from nkon.nl
Henk4U2
Henk4U2's picture
Last seen: 7 hours 27 min ago
svicar1 wrote:
Thanks I will buy Vapcell ICR14500 1000mAh from nkon.nl
Good call.
Good battery
Good seller.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
toni31
Last seen: 4 months 1 week ago
Good battery but for some reason the official aliexpress vapcell store they can’t send it to Greece
Ventsi
Last seen: 3 days 17 hours ago
Get it from nkon instead then.
Res Bri
Hi HKJ,
What’s your opinion on Keeppower 14500 800mAh, 1100mAh and Orbtronic 14500 1100nAh ?
Thanks,
Bri
Sillen
Sillen's picture
Last seen: 1 hour 19 min ago
Res Bri wrote:
Hi HKJ,
Thanks,
Bri
Hi Bri, welcome to BLF. You can find HKJ’s tests/comparisions here https://lygte-info.dk/review/batteries2012/CommonSmallcomparator.php
