What did you mod today?
Looks good. Since you use a lathe, maybe you can widen the bezel opening slightly (without compromising the slot for the o-ring) to get more light out.
Now I discussed this……… I thought about ‘unholing’ the holes lol - as in rounding the bezel to the 3 circles/lenses.
CRX pointed out the o ring (which is kinda square and you can see in the pics) might pop out. I think he’s right. It would look funky, but you’d have to lose the ring - maybe silicone the optic in around top edge off the optic if waterproofing were a worry - but it could be done.
Still, I don’t think I’ll bother…….yet……
I am looking to put goldish leds on the illuminated tailcap, and am getting some goldy/yellow gitd powder for a gasket.
I may get another one later and sell it/ them now I know what’s involved …. I’m kinda in love with this one now, it’s moved into my 3 faves….and because i made it, it’s all the better lol! (more so it works) :stuck_out_tongue:
Thank mate! :slight_smile:
Wow. Some orsm mods and builds going on. Love the work guys. :+1: :beer:
Stellar pictorial. Just swapped a sw40 R9080 into mine and it looks so much nicer than the low CRI “NW” XPL. A little spottier but that offsets the marginal decrease in lumens. Mine also had arctic silver thermal paste (or similar), though it is now replaced with arctic alumina…
Finally got this one done. Dropped a 4000K 219C in a SPL-120. Unlocked the stock driver.
Is the output noticably higher than before?
It’s pretty significant, especially in the highest mode. I really hated the stock emitter.
What pill was in it?
The one on the right
Cool the good one from my testing. I’m getting 589lm with just an emitter/board swap XP-L V4 3C tested on my T/A muakka tube.
Been removing the good drivers and putting them into the round mcpcb pills…
Resistor modded a few… of the others… just to play with…
Wow, how did you get the potting out?! These things are built like tanks
It’s a RTV silicone potting… I soak them in a very strong thinner. I take a small drill bit and by hand remove the silicone down to the driver contact board, the 2 holes opposite the lead holes are for filling/ venting the pill, remove the silicone from those 2 areas and soak in thinner. It takes time and patients but eventually the silicone breaks down enough to push the driver out. I used to hot air the spring contact board off, now I just soak them.
You’re a better man than me, I know I’d get frustrated and mess that up.
I’d really like to do a brass bar 18350 conversion next, just trying to plan out how to do it
I made up some brass signal tubes for my FW3 shorty mods and machined the tubing smaller for the FW3/NovaTac mods. So I had 3-4 FW3 signal tubes left over. Now I’m out of brass tubing. But then I figured I would flap out the battery tube of the NovaTac which was about .005” and then I cut down the FW3 tube to fit.
My Last FW3/NovaTac Triple using the FW3 driver and cut down signal tube…and clip…
That looks awesome! Very cool
Thanks… :+1:
What pill has SPL-120 if you have seen them? I wanna add one to my lab but i’m nit sure about the driver
I have not seen any SPL-120’s just the SPA SPL-120’s and the 3 older ones I had with the SS Black bezel to me is the better ones of the SPA’s from my experience. I don’t know much about the other models.
Edit. Sorry… I misread your question… I had 120M locked in my head… I got a 120M coming… a Black anodized with a clip… my first… All my others have been in the weapon light kit SPA SPL-120’s.
I’ve modded a couple 120s, they can vary.
