I won 2 boost HX from led4power on the OL competition but have never used this LEDs.
Any suggestions how to use it?
I have read that it is a "thrower" LED, what lens/reflector should I use?
Is driving it using 2.8A is a waste and I have to over driven it?
To take advantage of the LED’s better thermal resistance relative to the regular 2mm^2 WF and other 2mm^2 LEDs you would need to overdrive it, yes. The regular 2mm WF output peaks at 8ish amps. I don’t think anyone has tested the boost HX to see how much of an improvement there is.
A C8 with convoy’s customizable linear driver (comes stock with 7.8A max) would be a nice compact thrower.
Boost HX should be driven at or above 5A… I’m not sure if I’ve seen a good test of it, but it probably has a sweet spot around 7-8A guessing based on the 2mm flat white vs the 1mm 4040 variant.
It would be best in a large host than can handle that kind of heat adequately. It’s also best with a large reflector or lens (or whatever optic).
It is not a “thrower” LED, it is in fact one of the most extreme best thrower LEDs.
To be bluntly honest, it doesn’t have a place in a headlamp. It is inefficient for light output, it has a very cold tint with low CRI, and it’s far, far too throwy for headlamp use.
The boost HX is the 2mm 4040 variant. The 1mm and 2mm 3030s are somewhat common in throwier enthusiast lights now, and the real advantage of the 4040 versions is how they can take more heat. I have two examples of the 4040 1mm, and while it is fantastic in my Jaxman Z1 host, it is nearly a waste even there.
Anyway, there’s some interesting discussion about the different versions of the LED currently floating around, so I’d be very interested in any testing (if any) you’re able to do of these.
Looks like It is not relay useful for my needs, If someone have the time and equipment to do some tests and post on BLF I can ask them to send him the LEDs
It is a great headlamp LED…supplying the throw part of flood + throw headlamps. It gives quite a few lumens and very good throw. But as noted already, it needs to be driven hard to really shine. Don’t expect to make it great for sustained performance; unless you make quite a big lamp it will be really good only in turbo, to have a look at something specific rather than to use it continuously.
That is exactly what the spot LED in dual optics caving lights is for :) high power for short periods when searching for a continue (or the exit)
I am using a massive aluminum body so I don't think cooling is an issue but I don't think I can drive it more than 6A.
Do you have an advice on what optics to use?
I tested a Boost HX sample for Hank, but did not post it on BLF because Hank thinks that he can source a better bin. At least for my sample, at 5A (3.13V) you are at already 80% of its maximum output so that is a fine performance already, IMO even ideal. (I found the maximum at 9A).
Because of these issues I started building my own headlamps, I can choose the emitters, the optics and UI, best headlamps (for my needs), cost 10% of commercial caving lights and it is fun to build
Maybe try Carclo 10755 or 10756 if you can fit it. And judging by your builds I think it’s no problem for you to build a host that can fit one. Yajiamei also has a lot of tight angle optics options in the 20mm and above range that might work well. I’m using a sliced LH351D under a carclo 10756 for my spot beam for my caving headlamp build (ignivi host). 10755 gives it much more throw but I like 10756 (frosted) better since it makes the beam a lot cleaner with no hard edges and mixes very well with my flood light (mule). Looks better in photos too. I’m still measuring max 300+ meters throw for sliced 351D driven to 5A so it can still throw a bit. It should throw a lot better with boost HX.
I haven’t seen any tests with boost HX + optics but based on experience, using clear tight optics is hit or miss. Most of the times I tried, the beam becomes ugly with lots of artifacts and very difficult to center. But then again, I had success with throwy leds like XPL-HIs and SST-20s with clear 10° optics so it might work with boost HX. I never liked SMO on my spot beam for caving since the edges annoy me when mixed with a floody light. But maybe that’s just me.
They’re made for XML but they work with other leds too. With optics especially throwy ones I find the best way is to try them. Yajiamei also have some optics for XPGs and those might actually work better with that particular led. I’ve used those for SST20s. Another option are those optics Simon sells for convoy S2. Those have smaller openings for the led than the Yajiameis for XMLs.
Centering can be challenging. For clear tight optics you really need it perfectly centered or else the beam would be ugly. I just use trial and error and some patience which I don’t have a lot of. So, many times I end up using beaded or frosted ones. They’re not as throwy as clear ones but the beam is just nicer in general and you don’t have to center them as perfectly.
If you don’t mind the edges I think reflectors are much easier to work with than optics for throwers. Try looking at Kaidomain or Convoy to see if they have the right size reflector and centering gaskets for you. Looking at the boost HX datasheet, it looks like it has the uncommon 4040 size footprint so you might have to use 5050 gaskets and just center it as much as you can. If you’re putting it in your headlamp build then it might be easier since you don’t have to twist to tighten. You can also have one printed.
