What did you mod today?
I’ve modded a couple 120s, they can vary.
Oh yeah, so anodized bezel ring has lower output than the model with black bezel ring. Bummer...
Mine had the pill that has the skinny straight mcpcb opening.
I think the output is pretty good with the stock driver and an LED swap, it actually turned out better than I anticipated. Really happy with the light now.
I agree on that. Novatac pills with HS opening just for a P4 emitter are the ones with most lumens after emitter swap.
Those with larger opening in the pill for emitter and mcpcb, those are the ones with less powerfull driver.
I hope i’m right but as i read in Kawiboy and CRX posts, it seems it is like that.
Anyone know a good place to buy a clip for these things?
I use a FW3 clip you just have to open up the I.D. a bit…
Ask Neal (neals gadgets) or Victor at Lumintop to hook you up.
I’m an idiot, didn’t even think about that, thanks!
Must look amazing. I’m also very keen on the TH20. I picked mine up for $30 from the Thunite site when they had a sale. A BLF friend here swapped the emitter for me, with a Nichia 219B R9080 R9050 sw30 I supplied to him. It would be warmer than I normally go for, but wow… is it fabulous. Eyes adjust to it easily. Very reminiscent of incandescent. It’s under-powered with a basic AA Eneloop, but the main intention is close range task illumination & it does the job wonderfully. Good spill. Ramping is a touch slow, but I’d rather have that than too fast.
Very nice tint. Your photo does a great job of capturing it. I’ve got a 219B 9080 9050 sw30 (3000k) in my TH20 and it looks very much like that.
Thank you for the encouraging words
The sw30 9080 is a fantastic LED, especially after sunset.
When Im daylight adapted I enjoy the sw45k option:
Yesterday I got some “goodies” and made small mods.
Replaced a XP-L HI (4000K led on my FW1A for a Luxeon V2 4000K too.
The tint is not so much different, but I find it better than the XP-L HI.
Before (compared with a Nichia 5700K, on the right) > After (compared with a Nichia 5700K, on the right)
Comparison betweemn the 3 Luxeon V2 led (3000K, 4000K, 5000K)
I also moded my On The Road i3, through a “lego” with the battery tube with the On The Road M1.
Although there are differences in anodozing and knurling, the tubes fit well.
I used a 16650 (Sanyo UR16650ZTA, 3.7V 2500 mah) battery to put inside the “new” flashlight!
It uses a 15mm diameter driver, with Crescendo, and I am using a Samsung LH351D.
So far so good :wink:
Compared with the FW3A and the FW1A (18500 version)
MCM Underground Mechanical mods:
CRX Underground MCM Triple Nichia 219C 5000K - Lxl TA Driver - 18650 - Piston Drive E-Tail Sw - 2430lm.
CRX Underground MCM Nichia 219C 90CRI - C-MK 3A - 18350 - Rv Clicky Tail Sw - 600lm.
:o :o :o
That is…WOW :open_mouth:
And the “smoke” becomes light!!!
Looks awesome :wink:
CRX, that is absolutely beautiful! I feel ignorant at the moment…so was that originally a vape? I need to know more. What did you fabricate yourself? What is used behind the lens on the triple? Need more info on the tailcap for the 18350 light :smiley:
CRX at first glance, I thought you made it out of Brass ESNA nut’s… I’m like damn I have some of those at work!
Very COOL! :smiley: :+1:
:slight_smile: :+1:
There is a thread with more details
I usually use plumbing nuts :smiley:
CRX: awesome work
Fantastic, love it! Looks so extraterrestrial …
You’re welcome. :beer: Actually, I made a mistake. My TH20 219B emitter is R9050 sw30. So it’s probably a touch warmer. Yes, I fully agree, the sw45 is also a great tint & would be my choice in brighter conditions. I bought 5 that are waiting to be implanted (thinking of using 3 on a triple, 1 on a single, and keep 1 for something later).
