The GA came out in 2015 and is the replacement for the B. It is a bit old, but the chemistry is still pretty close to current batteries. The B is rated at 4.8A continuous while the GA is rated at 10A. That’s a big difference plus there is a lot less voltage sag. I’d say the GA is a modern high capacity cell just like the LG MJ1 and Samsung 35E which also came out in 2015. They are all pretty close with max continuous output of 8 to 10 amps. The B model was truly an older generation.
See the comparison at 1A and 3A. A really big difference for about the same capacity.
At 5 amp it’s an even bigger difference. So there’s nothing wrong with the GA. It’s a good choice for when you need the highest capacity.
One factor is when were they manufactured. Just because two batteries have the same name, that does not mean they are identical if from different production lots. At times they make modifications of the electrolyte and its additives, etc. as time passes. So it might not be the same old battery. Wish they would share more with us, but they do not want to share with their competitors.
I’m not so sure about that. If they change the chemical mix then they have to go through the entire testing and safety certification procedure. If they change the mix then they usually change the name also. For example the short lived Samsung 48G that they quickly replaced with the 50E just because it was a tiny bit better.
A Panny B made and bought today should perform just like they did when they first came out. No better or worse. Just my opinion on the subject.
@JasonWW you may right, but it does happen. We do not know how often.
From docware on a different thread-
The study is dated 19.4.2017, cells are Panasonic NCR18650PD. You can read the whole study here :
The study states:
As these cathodic side reactions are not observed in the second study, it is assumed that slight changes in the functional materials, such as modifications of the electrolyte and its additives, have reduced the cathodic side reactions of the cells examined in the second aging study, which were produced several months later.
Contacted Acebeam 1 week ago and no response. I want another carrier for my X65 MINI.
Does anyone know why the K60 battery carrier does not work in the X65 MINI? Carriers[battery config.] look the same. Only difference appears to be the shape and size of contact point at either end.
Could it be the type of metal? Aluminum vs. brass like?
I see the driver spring on the K60 is a lot longer. Maybe the center post of the K60 carrier is too low to contact the shorter spring on the X65 driver.
Yes, there you go. The battery tube needs to push the carrier against the driver to get both positive and negative to make contact. You would need to add a spacer to the X65 tail cap to push it forward more. Maybe some foam or cardboard will work.
This is in my X65vn MINI.I am thinking of getting Molicel P26A/VTC5D as second set of batteries which are much, much better than 30Q/VTC6 or MJ1 on HKJ voltage curve at 15amp and 20 amps.
You rarely see them used with FET drivers. With a Buck driver like in the GT it’s set to 2.5A Turbo. The Boost driver in the MF04 is maybe 2.7A, but that is pushing it. Most drivers limit it to 1.8 to 2 amp. More amperage only gives a tiny bit more output, but a lot more heat.
I don’t know what driver design the X65 mini has, but if the carrier is 12v, then it’s probably a Buck driver. I would guess it’s no more than 2A per led, so maybe 10A draw on Turbo.
If you want more non consecutive Turbo runs, a high drain battery will work well. You don’t want a lot of voltage sag at 10A.
This is Not stock anymore. It is X65vn MINI. I heard he uses FET drivers from Richard. Not sure if it is in all of his lights.
In my type A analyzing brain I try to find the best combo of amp draw and run time. The re wrap VTC6[Acebeam batteries ] do pretty good. MJ1 higher incremental voltages but less output, which probably is not noticeable. Basically getting 15 minutes of turbo in 3 minute increments.
P26A would probably be 12 or 13 but more output. It is crazy how powerful the light is. Eating up 4 X 18650 on turbo in 15 minutes!
Okay, so you have the X65vn Mini from Skylumen? I don’t know what driver it has then. Might be FET. Best thing to do is ask Vin what battery to use. He is the one that knows.
(I thought you had the stock light and was thinking of sending it to Skylumen)
