After flashing Anduril to my q8 the driver screws when installed short the light and it’s always on. Is this a common thing? Everything works great without them, and the light worked fine beforehand.
A wire is caught under the driver board. The driver may need a half turn to take up slack in the wires, before the driver is seated again with care.
Yep, happens all the time with I pop the driver out on my Q8. You need to pay attention when re-seating the driver board to not pinch wires.
I hope it was an easy fix, just moving a wire out of the way. I haven’t had that happen in this particular model, but I’ve seen it occasionally in other lights.
