13,000 lumens from a single 21700 cell. Yes, it also has normal modes.
richbuff wrote:
Yeah, so we can see it coming, right? A well-lit demise…. :stuck_out_tongue:
Lightbringer wrote:
I always thought they were synonyms. :wink:
I would love to have a 20k pocketable light even if it is only good for 7 seconds. “Turbo” is not meant to be sustained.
Rexlion wrote: "Yeah, so we can see it coming, right? A well-lit demise…. :) "
I have some lights that have lots of battery capacity and one little teensy eensy weensy led sitting on top of all that battery power. However, due to some kind of off-beat personality profile that is all my fault, I don't feel excited about them. One day, science will develop a pill that will cure me. I will probably take two pills, get very excited about uber practical lights, and destroy my liver. Until then, give me single cell lights with enough multiple emitter power to blast me off to Heaven!
By the way, 444 posts, nice! My fav TC Contender is JD Jones SSK hand Cannon in .444 Marlin, throated long, so the bullet does not take up precious case capacity.
en.wikipedia.org/wiki/.444_Marlin
edit: SKV89 posted when I was posting. His post, diectly above this post: "I would love to have a 20k pocketable light even if it is only good for 7 seconds. “Turbo” is not meant to be sustained." Yes, I agree. Turbo is meant to be there, when need be.
Bbtw: I ordered two of these from my fav modder/supplier. My guess is that he won't be able to boost them.
Hard to say because HL drivers aren’t that good. Maybe even a spring bypass from your fav modder might bump up the output a bit.
so why the need for so much lumens in the blink of an eye ?
You’ll sound like my kids. Just admit it we’re here because we like bright shinny hand held lights. Some of you posting all the critiques are going to buy it anyway. I’ll probably get it and tell my non flashlight cohorts “It’s takes a Tesla battery and produces 13,000 lumens, as much as 10 headlights.” I’ll have it for grins and giggles for awhile then probably sell it to someone who wants it more.
Exactly !
Well said
Personally 10k+ lumens that are as floody as they’ll be from this light isn’t any more impressive than half that number or less.
I’d take the single emitter version of this (DM70 IIRC?) that still is high output and with a MUCH more balanced beam any day.
Plus there are options with similar output, size and much better light quality anyway. I just don’t see the appeal, especially for this price.
MoreLumens said: "I like to have turbo modes when I need to see bigger areas at once in darkness like when camping, exploring caves and fields etc. Usually flooder for those occasions. ..."
That is almost exactly where I am at. I like to use Turbo mode for two seconds, when I need to quickly scan a large area, mostly width, but also some depth. The more raw power the better, to get the width of the area, and also some depth. Being that this is my situation, I want this in the smallest size flashlight possible, because I am only using Turbo for two seconds.
Because I am an enthusiast about this, getting max power flood and some throw from the smallest light for two seconds, to quickly scan an area, from the smallest size flashlight, I have kept up with recent advances in this area for the past five and a half years. My journey, starting October, 2014:
MMU-X3: 1,600 lumens.
MM15, 5,000 L
Meteor XP-L, 7,500 L
TN36UT, 13,400 L
TK75vn quad 70, 16,000 L
X45vn, 25,000 L
Next, recently, I started looking for The Most Powerful Single Cell Light, to do the same thing: Quickly scan large area for two seconds, from the smallest size flashlight:
TM9K, 9,500 L
NSX53, 9,000 L
D4V2vn quad W2, 4,000 L
FW4vn quad W2, 3,850 L
Next, we have this: Single 21700, triple 70.2, 13,000 L, for two second burst to quickly scan the largest area with the smallest size flashlight.
Yes, it has normal modes for normal runtime and normal heat generation, for use that involves longer than two second quick scan.
I have 28 high performance lights, because I like to help support the folks who provide recent advances in things that I like: Very small, small, medium, large and very large dedicated throwers, power throwers, depth flooders and power flooders.
Price/cost? I don't own any "Jewelry" class lights or any USA made custom or semi-custom items or any exotic metals lights, even though I like to look at pics of them, and read posts about them.
New photos about the Imalent MS03 you find here :slight_smile:
Stay healty my friends
Thorsten
Gatzetecteam.de
flashlights for friends
13,000lm, 324m FL1 is 2cd/lm. Id really just rather take a light that has more reach and move my wrist a tiny bit more. Super floody lights are much more useful up close. That much output from a floody light just blasts away your vision from how bright everything up close is.
A little OT, but has anyone come up with an active heat management system in a flashlight that’s also capable of achieving IPX8? I’m thinking of some kind of internal sealed liquid cooling system, but not sure if it would be effective enough for the typical pill size. Other thought is an air channel embedded in the surface of the head with two exit holes, and micro fans mounted inside with gaskets to shield the wiring.
“liquid cooling” does not magically make things cooler by just adding liquid.
Liquid cooling works by using liquid to move the heat away to radiators.
Flashlights are way to small to have any kind of radiator other than the body itself and the fins on it.
Since the LED is literally inches away from the body and fins, the metal the flashlight is made of already carries the heat from the LED to the fins for dissipation.
The area of the fins and body is what determines the cooling, not whether the heat is brought there by liquid or metal.
Also, a pump would have to be extremely small to fit in a flashlight and also adds another point of failure.
Cooling can be improved by using copper instead of aluminum and by increasing the outer area of the flashlight by adding more fins.
There are 2 new flashlights you might want to know about:
Emisar D4V2 8 LED mule 7,400 L estimated $45
Noctigon KR4 8 LED mule 7,400 L estimated $55
Not sure if anyone has real world lumen measurements yet. 18650 format. 18350 tubes are available, though you will not get as many lumens out of a 18350 battery.
if nobody bought this kind of useless lights they would understand not many are interested…. and they are dangerous too… this one sure is stupid designed and stupid dangerous
Have you personally used this specific model? Doesn’t seem too far off from the single cell 3x XHP50.2 that Lumintop and Astrolux are both developing.
No but we’ve used lights with twice the mass and the same effective size/number of emitters and know how hot those get in the blink of an eye. Not to mention the stress that sort of current load puts on every component including the battery.
I understand what you’re saying but I still appreciate something new that hasn’t been done before. If new designs aren’t tried won’t things get stale? Of course this light won’t appeal to everyone and I can respect that. Personally I think it’s neat but I’d prefer a NW tint and I would like to see some runtime graphs to verify the claims.
I think a Samsung 30T or 40T would do ok pushing 3x XHP70’s. Heat and component health are a concern and hopefully Imalent took that into account. As others mentioned, having the OPTION to use turbo is a nice feature, if your goal was only run this at max lumens all the time another option would be better.
I got a "measured" 11,000 lumens out of a compact modded Amutorch X9 with triple XHP50.2's on A GOLISI - should do better on a 21700 30T or 40T.
